8 3/4 leak #160576
12/03/08 04:47 PM
12/03/08 04:47 PM
VA
DAMOPARS Offline OP
DAMOPARS  Offline OP
VA
I need to repair a small leak in my 8 3/4
I did not use a gasket last time, just sealer.
Anybody use the Right Suff for the rear?
Or get a gasket?
Can I get it done without taking the axles out?
Re: 8 3/4 leak [Re: DAMOPARS] #160577
12/03/08 04:50 PM
12/03/08 04:50 PM
So Cal
HealthServices Offline
Why would you even post that?
So Cal
RightStuff
no probs here
Allen Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first. Life was a little easier when I was just a wrench.
Re: 8 3/4 leak [Re: DAMOPARS] #160578
12/03/08 04:52 PM
12/03/08 04:52 PM
NY usa
540challenger Offline
NY usa
Or get a gasket?
You have to pull the axles out to get the pumpkin out no way around it.
I always used a gasket and put a light bead of black silcone on and smear it on with my finger and wipe off the extra.
Makes sure you clean the mating surfaces make them spotless and you should ne good to go.
i never used the rightstuff on the third member it should seal fine on it on with or with out a gasket but if you ever have to take the pumpkin out to clean it it will give you hell.
Re: 8 3/4 leak [Re: DAMOPARS] #160579
12/03/08 05:00 PM
12/03/08 05:00 PM
Axles must come out aways.just enough so you can pull the pumpkin, if you take them out all the way without putting some electrical tape around the splines they're likely to cut the seals & they for sure dont need to come out anywhere near that far. I prefer a gasket/permatex #3, many prefer sealant/no gasket & if so make sure you have a uniform bead around the perimeter expecially on the insides of the studs.
Re: 8 3/4 leak [Re: RapidRobert] #160580
12/03/08 05:11 PM
12/03/08 05:11 PM
VA
DAMOPARS Offline OP
DAMOPARS  Offline OP
VA
Thanks guys
Lots of work for a drip now and then. oh well its winter.
Re: 8 3/4 leak [Re: DAMOPARS] #160581
12/03/08 08:16 PM
12/03/08 08:16 PM
USA
Suregrip391 Offline
Suregrip391  Offline
USA
I used "The Right Stuff" with no gasket, Sealed Perfect! No issues.
