Challenger brake caliper question
#160485
12/03/08 02:11 PM
12/03/08 02:11 PM
Posts: 85 alton, ill
Desoto
alton, ill
Are there different calipers for the 70-74? I'm using a disk brake conversion kit for my '51 Plymouth and it calls for these calipers. Problem is that the caliper is sitting too high in the bracket. If the ears were cast higher it would fit. Just trying to figure out if my problem is caliper related or bracket related. Thanks [image]http://i51.photobucket.com/albums/f381/haywood2/IMGP7162.jpg [/image] link to picture
Re: Challenger brake caliper question
[Re: Desoto]
#160486
12/03/08 04:12 PM
12/03/08 04:12 PM
RapidRobert
The (pin type) calipers are the same. The problem is bracket related.
[Re: Desoto]
#160487
12/03/08 04:47 PM
12/03/08 04:47 PM
Posts: 1,568 Omaha, Nebraska
Scott Carl
Omaha, Nebraska
link to picture
sorry, I dont have an answer but a tech tip for future reference on your "[image]" link. It didn't work because there is a space between the .jpg and the left bracket on the "[/image]"
As for the caliper question, Does your wheel fit? If it does then I'd say caliper problem. If not then I would say, bracket problem.
