Re: Cuda hood pin question
[Re: Pacnorthcuda]
#1604610
04/08/14 12:51 AM
04/08/14 12:51 AM
Posts: 821 NW Ohio
6pkaar
NW Ohio
As far as cutting the hole the best method is a green lee punch, but they are expensive
There's always the Harbor Freight version of Greenlee punches.... they call them "knockout punches" and are $24.99 a set.
[Re: ebodyseast]
#1604615
04/08/14 02:40 PM
04/08/14 02:40 PM
Posts: 4,832 Star Idaho
67vertman
Star Idaho
10 minutes on the search here got me other good tips for other installs and a factory drawing but 5 seconds on google got this article...if that info doesn't help 100% can spend some time in the search pages ![](/ubbthreads/images/graemlins/scope.gif)
http://www.hotrod.com/techarticles/hrdp_1303_step_by_how_to_install_hoodpins/
Thanks ebodyseast, I need to post some pictures of it now that I have resprayed it flat black and blacked oy the bumpers.
Thats a good article you found on the hood pins!
Your Cuda is really looking nice 67vertman
[Re: 1971 Gran Coupe]
#1604616
04/08/14 07:19 PM
04/08/14 07:19 PM
Posts: 18,160 Mass
DAYCLONA
Mass
A 1/2" conduit punch makes a 7/8" hole. That is too large so be sure and do homework before cutting. I am away from my car and not able to send any detailed info. Good Luck.
The 7/8" hole is just what I measured on my bare Cuda hood, so that conduit knock out would do the trick, the pin hole location is: measuring from the SIDE edges of the hood, 4 1/4" from the DRIVER"S/PASSENGER"S SIDE edge to the center of the pin hole, and 3 1/4" from the front edge of the hood to the center of the hole, the smaller bezel/screw holes can be located by centering the hood pin bezel hole over the hood hole, the screw orientation is an X pattern if your standing in front of the hood
