Cuda hood pin question #1604608
04/08/14 12:03 AM
04/08/14 12:03 AM
Central Pa.
Cloned_Cuda Offline OP
Central Pa.
What size hole for the pin and the size for cover plate mounting screws.
Is there a template available for layout?
The hole for the pin use a hole saw to get a clean edge?
I don't have a hood that has the holes in it that I can transfer from.
Thanks!!
Re: Cuda hood pin question [Re: Cloned_Cuda] #1604609
04/08/14 12:17 AM
04/08/14 12:17 AM
Kirkland, Washington
Pacnorthcuda Offline
I've done it, but don't have the dimensions. As far as cutting the hole the best method is a green lee punch, but they are expensive and you or I don't own them.
That said use a step bit, you know, the ones that look like a Christmas tree. That is capable of making a big hole without catching the sheet metal and making an ugly warp
Re: Cuda hood pin question [Re: Pacnorthcuda] #1604610
04/08/14 12:51 AM
04/08/14 12:51 AM
NW Ohio
6pkaar Offline
6pkaar  Offline
NW Ohio
There's always the Harbor Freight version of Greenlee punches.... they call them "knockout punches" and are $24.99 a set.
Re: Cuda hood pin question [Re: Pacnorthcuda] #1604611
04/08/14 12:51 AM
04/08/14 12:51 AM
Star Idaho
67vertman Offline
67vertman  Offline
Star Idaho
Here are some pictures when I did mine.
http://s710.photobucket.com/user/67vertm...823196447697792
It has been awhile since I did them, but I am pretty sure i drill the pin holes 5/8" and screw holes 1/8. The step drill worked great.
Re: Cuda hood pin question [Re: 67vertman] #1604612
04/08/14 01:06 AM
04/08/14 01:06 AM
NoVa
E
ebodyseast Offline
ebodyseast  Offline
E
NoVa
10 minutes on the search here got me other good tips for other installs and a factory drawing but 5 seconds on google got this article...if that info doesn't help 100% can spend some time in the search pages
http://www.hotrod.com/techarticles/hrdp_1303_step_by_how_to_install_hoodpins/
Your Cuda is really looking nice 67vertman
Re: Cuda hood pin question [Re: ebodyseast] #1604613
04/08/14 01:56 AM
04/08/14 01:56 AM
Nebraska
4406bbl Offline
4406bbl  Offline
Nebraska
A Klien tools 1/2" knockout punch for 15.00 shipped on Ebay is a good way. Cuts about a 5/8 hole.
Re: Cuda hood pin question [Re: 4406bbl] #1604614
04/08/14 02:13 AM
04/08/14 02:13 AM
Washington/Las Vegas
1971 Gran Coupe Offline
A 1/2" conduit punch makes a 7/8" hole. That is too large so be sure and do homework before cutting. I am away from my car and not able to send any detailed info. Good Luck.
Re: Cuda hood pin question [Re: ebodyseast] #1604615
04/08/14 02:40 PM
04/08/14 02:40 PM
Star Idaho
67vertman Offline
67vertman  Offline
Star Idaho
Thanks ebodyseast, I need to post some pictures of it now that I have resprayed it flat black and blacked oy the bumpers.
Thats a good article you found on the hood pins!
Re: Cuda hood pin question [Re: 1971 Gran Coupe] #1604616
04/08/14 07:19 PM
04/08/14 07:19 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
The 7/8" hole is just what I measured on my bare Cuda hood, so that conduit knock out would do the trick, the pin hole location is: measuring from the SIDE edges of the hood, 4 1/4" from the DRIVER"S/PASSENGER"S SIDE edge to the center of the pin hole, and 3 1/4" from the front edge of the hood to the center of the hole, the smaller bezel/screw holes can be located by centering the hood pin bezel hole over the hood hole, the screw orientation is an X pattern if your standing in front of the hood
Re: Cuda hood pin question [Re: DAYCLONA] #1604617
04/08/14 07:22 PM
04/08/14 07:22 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
And you'll need the CUDA specific hood pin bracket to mount the pin also
Re: Cuda hood pin question [Re: Cloned_Cuda] #1604618
04/08/14 07:25 PM
04/08/14 07:25 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
You didn't say what year Cuda your doing, so I'll assume 70?...if so here's the 70 cable/pin factory print
Mike
Re: Cuda hood pin question [Re: DAYCLONA] #1604619
04/08/14 10:05 PM
04/08/14 10:05 PM
Thanks for the assist to my post, as it is difficult to remember the correct size needed. Always better to research before removing too much metal.
Re: Cuda hood pin question [Re: DAYCLONA] #1604620
04/08/14 10:51 PM
04/08/14 10:51 PM
Central Pa.
Central Pa.
Thanks to everyone!! and yes it is a 70. Thank you Mike for the factory print.
