Re: Indy 440-1's on a B block question
[Re: Benforsp]
#1604407
04/08/14 04:52 PM
04/08/14 04:52 PM
Posts: 2,008 Sweet Home Alabama
MRMOPAR622
Sweet Home Alabama
It has been so long ago since I run a stock 440 that I can't remember if it was a .040 or .055 over engine,but I put them on with no problems on a new build.I would like to tell you that them being 440-1 heads they were made to bolt on a stock bore 440 but I have never done it so I won't,but you can call Indy and they will tell you.They have always tried to be helpful and the one time they could not answer my question they told me they would have Russ call me and believe it or not he did.
"To Be The Man'You Have Got To Beat The Man"
"T/D and Pro-Bracket Racer"
[Re: AndyF]
#1604408
04/09/14 01:19 AM
04/09/14 01:19 AM
Posts: 197 Nor-Cal
loaderpro
Nor-Cal
Depends on the valve lift. You might need to notch the bores like the old Max Wedge engines. Always a good idea to mock it up before firing the engine.
I agree, a simple bore notch will fix this if it is needed. As stated, You should always mock it up and check all aspects!
