Indy 440-1's on a B block question #1604402
04/07/14 03:29 PM
04/07/14 03:29 PM
Bradenton, FL
Benforsp Offline OP
Benforsp  Offline OP
Bradenton, FL
Hey Guys,
I have been doing some research on this build up and I noticed the CNC 345 version of these -1 heads it recommends a 4.375 bore. Why is that? Will the valves contact the cylinders? Would this hold true for any -1 with a 2.25 valve? My setup has a 4.350 bore. I don't need the 345's but I have seen a few sets of heads available but they all seem to have big valves.
Thanks!
Re: Indy 440-1's on a B block question [Re: Benforsp] #1604403
04/07/14 04:00 PM
04/07/14 04:00 PM
Mo.
racerx Offline
racerx  Offline
Mo.
Mine is 4.39 with the 2.25vales in the -1's with no problem
Re: Indy 440-1's on a B block question [Re: Benforsp] #1604404
04/07/14 04:40 PM
04/07/14 04:40 PM
AndyF Offline
AndyF  Offline
Depends on the valve lift. You might need to notch the bores like the old Max Wedge engines. Always a good idea to mock it up before firing the engine.
Re: Indy 440-1's on a B block question [Re: AndyF] #1604405
04/07/14 10:23 PM
04/07/14 10:23 PM
Bradenton, FL
Benforsp Offline OP
Benforsp  Offline OP
Bradenton, FL
Hey Andy,
I am sure you don't recall, but years ago I bought a welded stroker crank from you to build a 499. Regardless, the motor is for a street engine. It will have a solid roller but certainly nothing exotic regarding lift. I just don't know if I need to chase the smaller valve head or if the larger valve will work. Any input is appreciated.
Re: Indy 440-1's on a B block question [Re: Benforsp] #1604406
04/08/14 03:20 PM
04/08/14 03:20 PM
Bradenton, FL
Benforsp Offline OP
Benforsp  Offline OP
Bradenton, FL
Any other experiences or thought?
Thanks!
Re: Indy 440-1's on a B block question [Re: Benforsp] #1604407
04/08/14 04:52 PM
04/08/14 04:52 PM
Sweet Home Alabama
MRMOPAR622 Offline
MRMOPAR622  Offline
Sweet Home Alabama
It has been so long ago since I run a stock 440 that I can't remember if it was a .040 or .055 over engine,but I put them on with no problems on a new build.I would like to tell you that them being 440-1 heads they were made to bolt on a stock bore 440 but I have never done it so I won't,but you can call Indy and they will tell you.They have always tried to be helpful and the one time they could not answer my question they told me they would have Russ call me and believe it or not he did.
"To Be The Man'You Have Got To Beat The Man" "T/D and Pro-Bracket Racer"
Re: Indy 440-1's on a B block question [Re: AndyF] #1604408
04/09/14 01:19 AM
04/09/14 01:19 AM
Nor-Cal
loaderpro Offline
loaderpro  Offline
Nor-Cal
I agree, a simple bore notch will fix this if it is needed. As stated, You should always mock it up and check all aspects!
