fastest et with a production 400 block?
#1603901
04/06/14 11:34 AM
04/06/14 11:34 AM
Posts: 97 Florida
johnmilner
Re: fastest et with a production 400 block?
[Re: Thumperdart]
#1603903
04/06/14 01:59 PM
04/06/14 01:59 PM
Posts: 2,429 Weatherford, Texas
RapidusMaximus
Weatherford, Texas
4.86 @ 140 in the 1/8th in this: 1978 400 filled to the freeze plugs, aluminum main caps, eagle crank and rods, 496 CI, mains and heads studded, stage 6 heads, comp roller cam, M-1 intake injected on alcohol, shifted at 6800.
1968 Plymouth GTX 1974 Dodge P/U Long Bed Stepside 318 2019 Ram 2500 6.4, auto, 4WD
[Re: Thumperdart]
#1603904
04/06/14 11:30 PM
04/06/14 11:30 PM
Posts: 6,591 Canton, Ohio
Sport440
Canton, Ohio
and 440 crank?
My sig is my fastest so far and will be in the 9.60`s soon but I know of way faster guys in the 8`s w/nos and one w/turbo..........
Hey now, ProSports old 451 3150# combo MP .590 cam beast still has you beat. But , not if you run a 9.60
[Re: Sport440]
#1603905
04/06/14 11:39 PM
04/06/14 11:39 PM
Posts: 20,279 PA.
pittsburghracer
"Little"John
"Little"John
PA.
8.80's NA in my Daytona but it was a 440 block and stock crank.
1970 Duster Edelbrock headed 408 5.984@112.52 422 Indy headed small block 5.982@112.56 mph 9.38@138.67
[Re: Thumperdart]
#1603907
04/07/14 12:19 AM
04/07/14 12:19 AM
Sport440
Canton, Ohio
and 440 crank?
Yes he did............but wasn`t it a t-ram and BIG tires? Don`t remember the suspension either..........just sayin.
Yep, T Ram and big tires, But a 451 and not a 470.
But forget that, because Im coming after both of your guys fast ETS
Ive got something finally coming together, that might compete But its not a 400 based build, its a 440. So I cant/shouldnt post anymore about it on this thread. 448 mp 590/12.5 maybe 9.5 @ 3000# NA
[Re: johnmilner]
#1603910
04/07/14 07:06 AM
04/07/14 07:06 AM
Posts: 10,150 Frostbitefalls MN (Rocky&Bullw...
gregsdart
At the Mopar Nats in 1995 I talked to a guy with a 1970(?) Dart running mid to low eights, (heavy nitrous)said he had a pile of broken blocks by his shop! It sounded like he was getting maybe five passes per block?
8.582, 160.18 mph best, 2905 lbs 549, indy 572-13, alky
[Re: Thumperdart]
#1603918
04/07/14 01:07 PM
04/07/14 01:07 PM
Posts: 684 St. Charles, MO.
Slingshot383
St. Charles, MO.
408 cu. in. Indy 440-1C heads, Ross pistons, GRP 6.535" rods, Comp Cams solid roller cam, fuel injected, Glide, 4.56 gears, 12" X 33" slicks, 1660 lbs. 7.95 @ 170 mph.
1994 Undercover Chassis 125" altered
stack injected big block, soon blown and injected
Member of The Torque and Recoil Club
[Re: johnmilner]
#1603919
04/07/14 07:35 PM
04/07/14 07:35 PM
Posts: 2,540 Milwaukee WI
TRENDZ
Milwaukee WI
8.80s @155 with turbos 3700lbs 3.50 gear
