fastest et with a production 400 block? #1603901
04/06/14 12:34 PM
04/06/14 12:34 PM
johnmilner Offline OP
and 440 crank?
Re: fastest et with a production 400 block? [Re: johnmilner] #1603902
04/06/14 12:47 PM
04/06/14 12:47 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
and 440 crank?
My sig is my fastest so far and will be in the 9.60`s soon but I know of way faster guys in the 8`s w/nos and one w/turbo..........
Re: fastest et with a production 400 block? [Re: Thumperdart] #1603903
04/06/14 02:59 PM
04/06/14 02:59 PM
Weatherford, Texas
RapidusMaximus Offline
Weatherford, Texas
4.86 @ 140 in the 1/8th in this: 1978 400 filled to the freeze plugs, aluminum main caps, eagle crank and rods, 496 CI, mains and heads studded, stage 6 heads, comp roller cam, M-1 intake injected on alcohol, shifted at 6800.
1968 Plymouth GTX
1974 Dodge P/U Long Bed Stepside 318
2019 Ram 2500 6.4, auto, 4WD
Re: fastest et with a production 400 block? [Re: Thumperdart] #1603904
04/07/14 12:30 AM
04/07/14 12:30 AM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
and 440 crank?
Hey now, ProSports old 451 3150# combo MP .590 cam beast still has you beat. But , not if you run a 9.60
Re: fastest et with a production 400 block? [Re: Sport440] #1603905
04/07/14 12:39 AM
04/07/14 12:39 AM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
8.80's NA in my Daytona but it was a 440 block and stock crank.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: fastest et with a production 400 block? [Re: Sport440] #1603906
04/07/14 12:48 AM
04/07/14 12:48 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
and 440 crank?
Yes he did............but wasn`t it a t-ram and BIG tires? Don`t remember the suspension either..........just sayin.
Re: fastest et with a production 400 block? [Re: Thumperdart] #1603907
04/07/14 01:19 AM
04/07/14 01:19 AM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
and 440 crank?
Yep, T Ram and big tires, But a 451 and not a 470.
But forget that, because Im coming after both of your guys fast ETS
Ive got something finally coming together, that might compete But its not a 400 based build, its a 440. So I cant/shouldnt post anymore about it on this thread. 448 mp 590/12.5 maybe 9.5 @ 3000# NA
Re: fastest et with a production 400 block? [Re: johnmilner] #1603908
04/07/14 01:39 AM
04/07/14 01:39 AM
WA
JD Dart Offline
JD Dart  Offline
WA
Mine ran 8.69 at 156.50 499ci 2850 lbs
Re: fastest et with a production 400 block? [Re: Sport440] #1603909
04/07/14 02:47 AM
04/07/14 02:47 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
and 440 crank?
Come get some big boy.......... Good luck on that! Was ProSport on ladder bars and I know it was a 451 and definately impressive for sure.
Re: fastest et with a production 400 block? [Re: johnmilner] #1603910
04/07/14 08:06 AM
04/07/14 08:06 AM
gregsdart Offline
gregsdart  Offline
At the Mopar Nats in 1995 I talked to a guy with a 1970(?) Dart running mid to low eights, (heavy nitrous)said he had a pile of broken blocks by his shop! It sounded like he was getting maybe five passes per block?
Re: fastest et with a production 400 block? [Re: johnmilner] #1603911
04/07/14 09:59 AM
04/07/14 09:59 AM
Mo.
racerx Offline
racerx  Offline
Mo.
9.50's
Re: fastest et with a production 400 block? [Re: racerx] #1603912
04/07/14 11:55 AM
04/07/14 11:55 AM
nj pine beach
dart9ss Offline
dart9ss  Offline
nj pine beach
NO Joke went 8:12 with 511 cubes stock block indy 440-1s 14-1 comp. 2300lbs that motors still running.
Re: fastest et with a production 400 block? [Re: dart9ss] #1603913
04/07/14 01:26 PM
04/07/14 01:26 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
So I guess the lighter cars like this and the rail above are easier/less stressfull on stock blocks................is that the deal? Kinda like 8 3/4`s and light cars.............
Re: fastest et with a production 400 block? [Re: johnmilner] #1603914
04/07/14 01:32 PM
04/07/14 01:32 PM
Q
Quicktree Offline
Quicktree  Offline
Q
7.80s @ 175 in a dragster
Re: fastest et with a production 400 block? [Re: Quicktree] #1603915
04/07/14 01:46 PM
04/07/14 01:46 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
With an 8 3/4...........
Re: fastest et with a production 400 block? [Re: Thumperdart] #1603916
04/07/14 01:48 PM
04/07/14 01:48 PM
PA.
"Little"John
"Little"John
PA.
BUT the pinion angle was dead nuts on.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: fastest et with a production 400 block? [Re: pittsburghracer] #1603917
04/07/14 01:53 PM
04/07/14 01:53 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Of course and was measured from the lower shock mount and the watchamacallit veenerschlider...........
Re: fastest et with a production 400 block? [Re: Thumperdart] #1603918
04/07/14 02:07 PM
04/07/14 02:07 PM
St. Charles, MO.
Slingshot383 Offline
St. Charles, MO.
408 cu. in. Indy 440-1C heads, Ross pistons, GRP 6.535" rods, Comp Cams solid roller cam, fuel injected, Glide, 4.56 gears, 12" X 33" slicks, 1660 lbs. 7.95 @ 170 mph.
1994 Undercover Chassis 125" altered stack injected big block, soon blown and injected Member of The Torque and Recoil Club
Re: fastest et with a production 400 block? [Re: johnmilner] #1603919
04/07/14 08:35 PM
04/07/14 08:35 PM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
8.80s @155 with turbos 3700lbs 3.50 gear
Re: fastest et with a production 400 block? [Re: TRENDZ] #1603920
04/07/14 08:39 PM
04/07/14 08:39 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
That`s what I`m talkin about...........
