I NEED HELP! Trying to use Stage VI heads with Blower #1603811
04/06/14 02:00 AM
04/06/14 02:00 AM
Texas, USA
K
kryogenic Offline OP
K
Texas, USA
My question is, I want to run my stage VI mopar performance heads and a blower. From my underdtanding there is no blower intake that will fit it properly. I have some spacer place, but do i need my blower intake modified to fit the stage VI heads, or is there a blower intake made for this setup?
Re: I NEED HELP! Trying to use Stage VI heads with Blower [Re: kryogenic] #1603812
04/06/14 02:27 AM
04/06/14 02:27 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Are you running the Chapman Stage VI heads on an RB block?, if so a Max Wedge port blower manifold should be the likely candidate, if you have the heads on a B motor, nothing available that I know of...I don't have my RB (440) blower manifold here for measurements, but I don't think there's enough meat around the ports to open them up to MW/Stage VI specs...Might want to try Indy to see if they have a blower manifold, I assume old-school 6-71/8-71?
Re: I NEED HELP! Trying to use Stage VI heads with Blower [Re: DAYCLONA] #1603813
04/06/14 02:59 AM
04/06/14 02:59 AM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
do you have the standard 440 port heads or the MW port heads ??
I am truckless..
Re: I NEED HELP! Trying to use Stage VI heads with Blower [Re: 340SHORTY] #1603814
04/07/14 01:41 PM
04/07/14 01:41 PM
dogdays Offline
dogdays  Offline
This really would work better in the "race" section.
What Stage VI heads are they? I know you said MP but that doesn't help that much.
Some Stage VI heads were cast to allow use of a 440 intake on a 383, then you had to use the spacers to use a 440 intake on a 440. But I seem to remember they also had some Stage VI heads that were straight replacements for the 440.
Also, although I'm assuming you're talking about a 440 or other RB, what engine are you talking about?
R.
Re: I NEED HELP! Trying to use Stage VI heads with Blower [Re: kryogenic] #1603815
04/07/14 03:39 PM
04/07/14 03:39 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
What block and exacty which head ?
If this is on an RB block then you need the spacer and a 440 manifold .
If this is on a B block then you can run a 440 intake , no spacers required , if you have a 383/400 blower intake then you will need the spacers.
If these are the std port window location 311 heads then it's 440 intake on RB , 383/400 intake on a B block , no spacers for either would be needed.
Can't say what you would need to do if they are 6's with a max wedge port window.
