replacing fuel pump on 06 ram 2500 #1603519
04/05/14 05:22 PM
04/05/14 05:22 PM
md
mopars4ever Offline OP
md
Anything I should be aware of before I replace the fuel pump on my 06 ram 2500? Does the tank need to be completely empty before dropping it down? Any tips?
Re: replacing fuel pump on 06 ram 2500 [Re: mopars4ever] #1603520
04/06/14 10:36 AM
04/06/14 10:36 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
The less fuel the better.I did a bunch of pumps at work.Seems most were over 1/2 full.We had a pump to empty them but it took time and wore your arm out.Sometimes the lines are stuck.I always sprayed them with penetrating fluid.But most were older and living in the rust belt.Test the pump before you get the tank all buttoned down.I usually hooked them all up and got them high enough to connect to the line and electrics then with say a few gallons tried them.Had a few new bad pumps.Rocky
Chrysler Firepower
Re: replacing fuel pump on 06 ram 2500 [Re: therocks] #1603521
04/06/14 09:38 PM
04/06/14 09:38 PM
md
md
OK, thanks for the help.
Re: replacing fuel pump on 06 ram 2500 [Re: mopars4ever] #1603522
04/07/14 12:01 AM
04/07/14 12:01 AM
Kansas
cascius Offline
cascius  Offline
Kansas
Are you sure it needs replaced? The '06 trucks really don't have the issues with them that the earlier trucks did.
Re: replacing fuel pump on 06 ram 2500 [Re: cascius] #1603523
04/07/14 12:22 AM
04/07/14 12:22 AM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
I've heard of guys lifting the box, anyone tried it that way?
Re: replacing fuel pump on 06 ram 2500 [Re: WO23Coronet] #1603524
04/07/14 09:47 AM
04/07/14 09:47 AM
USA
3
360view Offline
Moparts resident spammer
360view  Offline
3
USA
On a 1995 I removed the cargo box bolts to the frame on the drivers side and loosened the bolts on the passenger side, took loose the hoses to the fill cap door, then used the tire change jack and two blocks of wood to raise the cargo box at a 45 degree angle to expose the top of the pump assembly. Watch that you dont pinch wiring near the license plate.
Also be very careful and gentle when removing the "Roll Over Valve" as most new pump assemblies don't have one and expect you to reuse the old one. I ended up using a Dremel tool to cut the old plastic away to free it.
Have a fire extinguisher nearby,
and several rags to wipe up gasoline.
When i examined the fuel tank level sensor the ceramic had cracked. My fuel level gauge had been working but never went as high as it had new.
On the 1995 pump assembly the fuel pressure regulator looked like it was fairly easy to change to one of higher pressure.
Re: replacing fuel pump on 06 ram 2500 [Re: 360view] #1603525
04/08/14 05:26 PM
04/08/14 05:26 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
Tony
70 AARCuda Vitamin C
Re: replacing fuel pump on 06 ram 2500 [Re: 70AARcuda] #1603526
04/08/14 08:01 PM
04/08/14 08:01 PM
N
NITROUSN Offline
NITROUSN  Offline
N
the fastest way to do it...
https://www.youtube.com/watch?v=arfmFIi49q8
What a hack job.
Re: replacing fuel pump on 06 ram 2500 [Re: NITROUSN] #1603527
04/08/14 10:01 PM
04/08/14 10:01 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Hey now I did that on my old Ram Charger.The outlet was leaking and the guard for the tank which is plastic was rusted solid.I couldnt cut the bolts off without a big fire.So I cut the rear floor bent it up and changed the sender.Pushed the piece back down and sealed it.With the carpet over it you never knew it was done.It was my plow hunting truck so it was pretty beat with 300K on it.Rocky
Chrysler Firepower
