Re: replacing fuel pump on 06 ram 2500
[Re: mopars4ever]
#1603520
04/06/14 10:36 AM
04/06/14 10:36 AM
Posts: 21,074 Niles , Ohio
therocks
Niles , Ohio
The less fuel the better.I did a bunch of pumps at work.Seems most were over 1/2 full.We had a pump to empty them but it took time and wore your arm out.Sometimes the lines are stuck.I always sprayed them with penetrating fluid.But most were older and living in the rust belt.Test the pump before you get the tank all buttoned down.I usually hooked them all up and got them high enough to connect to the line and electrics then with say a few gallons tried them.Had a few new bad pumps.Rocky
Chrysler Firepower
[Re: therocks]
#1603521
04/06/14 09:38 PM
04/06/14 09:38 PM
Posts: 13,601 md
mopars4ever
md
[Re: NITROUSN]
#1603527
04/08/14 10:01 PM
04/08/14 10:01 PM
therocks
Niles , Ohio
Hey now I did that on my old Ram Charger.The outlet was leaking and the guard for the tank which is plastic was rusted solid.I couldnt cut the bolts off without a big fire.So I cut the rear floor bent it up and changed the sender.Pushed the piece back down and sealed it.With the carpet over it you never knew it was done.It was my plow hunting truck so it was pretty beat with 300K on it.Rocky
Chrysler Firepower
