home 8&3/4 shortening decision
#1603020
04/04/14 01:45 PM
04/04/14 01:45 PM
RapidRobert
Assuming I can chop saw cut a section out of each side/square up the cut pieces/weld em so both end flanges are parallel, would this suffice or do I need to bite the bullet & send it all in to Moser. I'd sure like to avoid the ~3 bills that will set me back .. Online threads refer to the locating mandrel shaft with the locating bushings on each end to locate the housing pieces before welding them & talk about out of round in thousands. If I get the end flanges parallel wouldn't I be OK? Your thoughts please. thank you for your time.
Re: home 8&3/4 shortening decision
[Re: Polarapete]
#1603022
04/04/14 04:35 PM
04/04/14 04:35 PM
RapidRobert
Pete, Ok, coming up with a round straight bar of say 1" dia will be easy then 2 round alum pucks, one to fit the housing end and the other to fit in the cap with it bolted down with the 2 bolts then drill a 1" hole in both of em to fit the bar. All three together to locate the ends for tack welding. Sound Ok so far? Getting the right dia pucks is the only part that'll take some effort.
[Re: RapidRobert]
#1603025
04/04/14 05:04 PM
04/04/14 05:04 PM
Posts: 9,826 las vegas
70AARcuda
las vegas
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
[Re: RapidRobert]
#1603028
04/04/14 06:45 PM
04/04/14 06:45 PM
Posts: 22,696 Bitopia
jcc
Bitopia
See pic #47 https://board.moparts.org/ubbthreads/show...e=0#Post7972701The ebay puck deal looks like a cost effective solution, let us know.
[Re: jcc]
#1603029
04/04/14 07:39 PM
04/04/14 07:39 PM
RapidRobert
I will do bro. EDIT What rubbed you the wrong way on welding on the LCA stiffing plate? I'd think that'd be a good deal (cheap/easy/lightweight/beneficial)
[Re: RapidRobert]
#1603030
04/04/14 07:53 PM
04/04/14 07:53 PM
Posts: 9,859 MI, usa
dvw
MI, usa
I did it this way 25 years ago. The axle is still in my Road Runner today. Thousands of street miles, hundreds of passes. Never an issue. Doug
[Re: RapidRobert]
#1603032
04/04/14 08:24 PM
04/04/14 08:24 PM
Posts: 1,751 Graham, WA
Polarapete
Graham, WA
My first Dana narrowing job was done with a friend in 1997. We threw it together w/o a jig. He welded it with his Mig. I used the early "green" bearings on the axles that allow for a lot of misalignment. I made two trips from Seattle to Reno and back and it rested in the garage a lot. The last time I drove it, the right axle bearing was talking to me. I have learned that perfect alignment is the answer to a lot of problems. Use a jig, you will be glad you did.
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction 1998 Ram 2500 QuadCab, new daily driver. 2008 Honda Element 2014 Carry-On 7x14 Cargo Trailer
[Re: John_Kunkel]
#1603034
04/04/14 09:39 PM
04/04/14 09:39 PM
RapidRobert
Yeah I initially missed the offset concept & was just thinking about parallelism. thanks a bunch guys . the eBay kit (the cheaper one) is on it's way. Now to locate a straight bar & a buddy is a pro welder
[Re: John_Kunkel]
#1603037
04/05/14 01:48 AM
04/05/14 01:48 AM
dvw
MI, usa
Here's why you need an alignment bar....parallel is irrelevant if it's offset. [/quote
That is one tweaked housing.
[Re: dvw]
#1603038
04/05/14 03:42 AM
04/05/14 03:42 AM
Posts: 1,652 Amarillo, Tx
old_goat
Six Abuser
Six Abuser
Amarillo, Tx
1 1/4 keyed shafting for pto applications is easy to come by at most any truck garage. Hard steel and usually straight even used. New stuff is about 80.00 for a 6 ft stick.
84 D150 440/727 79 /6 swb D150 1964 A100 window van. Just because it has spark plug tubes doesn't mean it's a Hemi.
If ya haven't been there, ya just wouldn't understand.
[Re: old_goat]
#1603039
04/05/14 11:07 AM
04/05/14 11:07 AM
RapidRobert
Goat I will check into that as I do need it
