85w-90 or 84w-140 or Penn Syncromesh GL-4 for 833 ? #1602600
04/03/14 12:31 PM
04/03/14 12:31 PM
USA
SSAAHemiFan Offline OP
USA
Getting ready to rebuild 3 833's
Looking for lube recommendations before I buy a quantity
Cars won't be driven in cold weather so I am wondering if the heavy lube would be more durable (cushioning) but I know technology changes also
Re: 85w-90 or 84w-140 or Penn Syncromesh GL-4 for 833 ? [Re: SSAAHemiFan] #1602601
04/03/14 12:50 PM
04/03/14 12:50 PM
dogdays Offline
dogdays  Offline
Heavy lube will not flow into the small nooks and crannies like the lighter viscosities will.
You don't need any 140 in a manual transmission. And, you don't want to use a GL-5 gear lube in a transmission that depends on synchronizers. It should be a GL-4.
I'd use Redline MTL.
R.
Re: 85w-90 or 84w-140 or Penn Syncromesh GL-4 for 833 ? [Re: dogdays] #1602602
04/03/14 02:42 PM
04/03/14 02:42 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
I run 80/90 in mine.Its been in since 69 when I bought my 65.No problems at all.Some will say ATF but no way will I run that.Rocky
Chrysler Firepower
Re: 85w-90 or 84w-140 or Penn Syncromesh GL-4 for 833 ? [Re: therocks] #1602603
04/03/14 03:50 PM
04/03/14 03:50 PM
Az
69hemibeep Offline
69hemibeep  Offline
Az
I use Penn Syncromesh in mine. Seems to shift real nice.
1969 Hemi Roadrunner 2nd owner
Re: 85w-90 or 84w-140 or Penn Syncromesh GL-4 for 833 ? [Re: 69hemibeep] #1602604
04/03/14 04:05 PM
04/03/14 04:05 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
I used Passons lube, its thin maybe like a 5/30. i hear the redline mtl and the syncromesh is good. i also would not want ATF in there.
Re: 85w-90 or 84w-140 or Penn Syncromesh GL-4 for 833 ? [Re: therocks] #1602605
04/03/14 06:31 PM
04/03/14 06:31 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Agreed, same here, 80/90,in my Challenger T/A 4 spd, run nothing but since the 70's
Re: 85w-90 or 84w-140 or Penn Syncromesh GL-4 for 833 ? [Re: DAYCLONA] #1602606
04/03/14 07:34 PM
04/03/14 07:34 PM
Walnut Creek, CA
blown340 Offline
blown340  Offline
Walnut Creek, CA
redline MTL for me.
70 challenger convertible. 340/5 speed. blown, intercooled, efi, blah blah blah 71 valiant scamp 318/A833OD/AC/PS 00 dakota RC 4.7L 5 spd autoX'r. SRT10/T56 swap in process 73 W200 Power wagon, PTO winch, 4 spd
Re: 85w-90 or 84w-140 or Penn Syncromesh GL-4 for 833 ? [Re: blown340] #1602607
04/03/14 08:23 PM
04/03/14 08:23 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
Re: 85w-90 or 84w-140 or Penn Syncromesh GL-4 for 833 ? [Re: SSAAHemiFan] #1602608
04/03/14 09:28 PM
04/03/14 09:28 PM
Benton, IL.
DaveRS23 Online rolleyes
Special needs idiot
DaveRS23  Online Rolleyes
Special needs idiot
Benton, IL.
I just had my 833OD freshened up last fall. It had ATF in it before. I put 80/90 GL-4 in it, but I just didn't like the way it shifted. It seemed stiff, especially 1st and 2nd. So I drained some gear oil out and added some ATF to replace it. It's maybe 60/40 or 50/50 gear oil to ATF.
That made a noticeable improvement. And is the way I left it.
If I had it to do over again, I think I would use Passon's oil.
Master, again and still
Re: 85w-90 or 84w-140 or Penn Syncromesh GL-4 for 833 ? [Re: DaveRS23] #1602609
04/05/14 08:18 PM
04/05/14 08:18 PM
near Harrisburg, Pa
440trk Offline
440trk  Offline
near Harrisburg, Pa
Redline MTL or Jamie Passon's trans fluid.
I've run both, and I like Jamie's trans fluid better.
Re: 85w-90 or 84w-140 or Penn Syncromesh GL-4 for 833 ? [Re: SSAAHemiFan] #1602610
04/06/14 01:03 AM
04/06/14 01:03 AM
mt. pleasant, PA
Diplomat440 Offline
Diplomat440  Offline
mt. pleasant, PA
Who makes a gl-4 lube? I looked at a few places today and every thing I found was the gl-5.
Napa has penn syncromesh, its not very cheap though.
Re: 85w-90 or 84w-140 or Penn Syncromesh GL-4 for 833 ? [Re: Diplomat440] #1602611
04/06/14 01:33 AM
04/06/14 01:33 AM
SoMd, USA
135sohc Offline
135sohc  Offline
SoMd, USA
Amsoil makes a 75W90 manual transmission oil. Retail is around $15/quart and it is rated as GL-4 oil.
They also make a '5w30 equivelent' manual transmission oil marketed for the newer generation of manual transmissions. I have used that stuff in my FWD new process transmissions and found it was no different in shift quality vs regular non synthetic 5w30 engine oil.
Re: 85w-90 or 84w-140 or Penn Syncromesh GL-4 for 833 ? [Re: 135sohc] #1602612
04/06/14 01:49 AM
04/06/14 01:49 AM
Kirkland, Washington
Pacnorthcuda Offline
I run Red Line MTL in my 18 spline. It's a tranny that when you're driving hard you don't baby..the name of the game is grab the gear hard during a quick shift.
