tire size #160260
12/02/08 06:44 PM
12/02/08 06:44 PM
London,Ontario,Canada
1962Savoy Offline OP
anyone have an idea how big a tire I can put on the back of my 62 Savoy with out modifing the suspension???
I was looking at the Coker 1000-15 DOT drag tire or the 850-15 one. I kinda wanted the retro drag car look. Any opinions out there???? will they fit???
Re: tire size [Re: 1962Savoy] #160261
12/02/08 10:07 PM
12/02/08 10:07 PM
Greer, SC
TooMany62s Offline
TooMany62s  Offline
Greer, SC
I hope this will help. On my '62's I have 255/70-15's. The specs are: 8.3" tread, 10.5" cross section and 29.1" high. They are mounted on 7" standard back-spaced wheels. They are within 1/4" of the springs on the inside and about the same both on the inside and outside of the wheel house. I guess you could conclude that anything less than 10.5" of cross section width would fit. Again, I hope this helps.
Re: tire size [Re: TooMany62s] #160262
12/02/08 10:27 PM
12/02/08 10:27 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Not sure if my 63 is the same but I have Hoosier QTP 29 x 11.5 tires in my stock wheelwell's on my 63 and it's the biggest I can fit in there. My springs are not moved and I have about 1/2" on the inside and outside of the tires. The tread is actually only about 10.5 as the 11.5 stands for the tire width. I could actually fit a 30" tall I believe as I have room to go taller but not wider. Ron
Re: tire size [Re: TooMany62s] #160263
12/03/08 12:08 PM
12/03/08 12:08 PM
yes thanks this should help some what
Re: tire size [Re: 383man] #160264
12/03/08 12:17 PM
12/03/08 12:17 PM
Looks good Ron,It should be the same if not close. With Bias ply tires its hard to figure out what is what in the numbers from radials.
I think I'll go with the Coker 850-15 as it is the same size as you have. but they are 30" tall
