leaf spring question #1600619
03/30/14 03:08 PM
03/30/14 03:08 PM
maryland
buck440 Offline OP
buck440  Offline OP
maryland
ok guy's need some help here! recently narrowed a rear for my duster stock springs upon putting back together. I noticed my drivers side wheel sits closer to the wheel opening then the pass side. guess my question is are the springs different right to left ? the only other change was cal tracs n mancini rear roller shackles solid leaf bushings!
Re: leaf spring question [Re: buck440] #1600620
03/30/14 03:16 PM
03/30/14 03:16 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
Did you move the spring axle pads?
Re: leaf spring question [Re: B G Racing] #1600621
03/30/14 03:22 PM
03/30/14 03:22 PM
maryland
buck440 Offline OP
buck440  Offline OP
maryland
no sir!
Re: leaf spring question [Re: buck440] #1600622
03/30/14 03:25 PM
03/30/14 03:25 PM
What your seeing is not unusual on these dang Mopar unibody Anytime I move the springs or narrow the rear ends now I measure the tires in the wheelwells before and compensate to get them centered between the inner and outer sheet metal
Re: leaf spring question [Re: Cab_Burge] #1600623
03/30/14 04:04 PM
03/30/14 04:04 PM
maryland
buck440 Offline OP
buck440  Offline OP
maryland
ok I didn't notice if it was like that before. I can get my fingers between the tire n opening on the pass side but not on the drivers.
Re: leaf spring question [Re: buck440] #1600624
03/30/14 10:33 PM
03/30/14 10:33 PM
Seminole County FL to Plymouth...
Barry70GTX Offline
Barry70GTX  Offline
My Demon was the same way,then I centered it. Now it's just closer to the rocker on the left and the rear end is perfectly square to the body. A little harder to correct.
NMCA NSS 67 Coronet
Re: leaf spring question [Re: buck440] #1600625
03/30/14 10:58 PM
03/30/14 10:58 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Thats pretty close any how... that was a common thing
back then.. its actually in the 1/4 panels... if you
were to start measuring thats where you will find
the issue
Re: leaf spring question [Re: MR_P_BODY] #1600626
03/30/14 11:35 PM
03/30/14 11:35 PM
maryland
buck440 Offline OP
buck440  Offline OP
maryland
my springs were relocated by a former owner. where should I measure from the original front spring mounts? to where drum or? I have 325 50 15 drag radials also if that makes a diff.
Re: leaf spring question [Re: buck440] #1600627
03/30/14 11:43 PM
03/30/14 11:43 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Did he center the pinion or is it still off set..
but you can measure from the pinion... I dont have
a stock housing to measure off of to give you any specs
Re: leaf spring question [Re: MR_P_BODY] #1600628
03/31/14 12:50 AM
03/31/14 12:50 AM
maryland
buck440 Offline OP
buck440  Offline OP
maryland
I did the rear the 8.75 is just as factory only shorter. the unit is factory off set correct?
