8 3/4 Rear Drum Brake help... #1600222
03/29/14 07:37 PM
03/29/14 07:37 PM
SoCal
MuuMuu101 Offline OP
I got lucky at Woodward!
SoCal
So I've got an 8 3/4 that came out of a '70 Dart. I took one side of the drum brake all apart but am now stuck putting it back together. I have two primary problems regarding my old shoe. The first is I'm not sure how to remove the horse clip that big chunk of metal that holds in the anti-rattle spring/beam thing.
Also, did I make a mistake by ordering '68 shoes. I've got a pin on my old drums to hold the adjusting lever but they're not on my new ones. Am I supposed to remove this somehow, if so, how?
Re: 8 3/4 Rear Drum Brake help... [Re: MuuMuu101] #1600223
03/29/14 07:41 PM
03/29/14 07:41 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
LOL
that the lever for the parking brake. Pry it apart. The new shoes should have a new 1 in the box. 68 should be the same.
I am truckless..
Re: 8 3/4 Rear Drum Brake help... [Re: 340SHORTY] #1600224
03/29/14 07:43 PM
03/29/14 07:43 PM
SoCal
SoCal
LOL
I was trying to judge what it was by my service manual and what you know, it was in the box!
Horse clip is still giving me troubles though...
Re: 8 3/4 Rear Drum Brake help... [Re: MuuMuu101] #1600225
03/29/14 07:56 PM
03/29/14 07:56 PM
SoCal
SoCal
Ok, I got it... Thanks.
Re: 8 3/4 Rear Drum Brake help... [Re: MuuMuu101] #1600226
03/29/14 08:13 PM
03/29/14 08:13 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
LOL
a little oil and either a very small screwdriver (jeweler) or a dental pick will do it. dental picks are the cat's butt for stuff like that!
whoops, never mind! you got it!
Re: 8 3/4 Rear Drum Brake help... [Re: mikemee1331] #1600227
03/29/14 09:30 PM
03/29/14 09:30 PM
SoCal
SoCal
I think I finished one side. Does this look right?
Re: 8 3/4 Rear Drum Brake help... [Re: MuuMuu101] #1600228
03/29/14 09:37 PM
03/29/14 09:37 PM
Alberta
rustbuckett68 Offline
Alberta
Uhh, maybe pinch the "horse shoe" clip ends together.
Re: 8 3/4 Rear Drum Brake help... [Re: MuuMuu101] #1600229
03/29/14 09:40 PM
03/29/14 09:40 PM
Big Sky Country
MO_PA Offline
MO_PA  Offline
Big Sky Country
Close up the horseshoe clip before it comes off, looks to me that black spring is wrong, should be a second spring like the yellow one in the other hole below where the black spring is in the shoe. Something don't look right with the spring at the bottom of the shoes, it serves two purposes, return spring to pull the shoes against the adjuster and it keeps the adjuster from turning freely.
Re: 8 3/4 Rear Drum Brake help... [Re: MuuMuu101] #1600230
03/29/14 09:55 PM
03/29/14 09:55 PM
Minn
SportF Offline
SportF  Offline
Minn
Also, are both those shoes the same size? You should have a "short" shoe on the front side, and a longer shoe on the rear side.
Re: 8 3/4 Rear Drum Brake help... [Re: MO_PA] #1600231
03/30/14 01:04 AM
03/30/14 01:04 AM
SoCal
SoCal
I ended up pinching the horse clips afterwards. Yeah, I kind of figured I screwed up somewhere. Just took a look and I used the two short shoes. I don't think I was supposed to punch that one pin into the short one. Luckily, I accidentally bought two kits. Also, the parking brake cable protrudes past the spring that sits right above the adjuster and I couldn't figure that out for the life of me.
I'll work on it Monday most likely. Here is a picture of the other side from this morning...
Re: 8 3/4 Rear Drum Brake help... [Re: SportF] #1600232
03/30/14 01:13 AM
03/30/14 01:13 AM
Western Md.
skicker Offline
"The Champ"
skicker  Offline
"The Champ"
Western Md.
Think of it like a mullet...long in the back and short in the front. That's the only way I remember how they're supposed to go.
...FAFO...
Re: 8 3/4 Rear Drum Brake help... [Re: skicker] #1600233
03/30/14 01:20 AM
03/30/14 01:20 AM
SoCal
SoCal
That's good to know... So far, all I have to say is I like disc brakes way better. They're so much nicer to work on. No springs for your springs on top of springs connected to springs.
Re: 8 3/4 Rear Drum Brake help... [Re: MuuMuu101] #1600234
03/30/14 01:29 PM
03/30/14 01:29 PM
Canada
Dons Dart Offline
Dons Dart  Offline
Canada
your aduster is on the wrong way also turn it around.
Re: 8 3/4 Rear Drum Brake help... [Re: Dons Dart] #1600235
03/30/14 01:59 PM
03/30/14 01:59 PM
SoCal
SoCal
Which adjuster? The bottom one? If I turn that around the lever wouldn't even contact it to hold it in place.
Re: 8 3/4 Rear Drum Brake help... [Re: MuuMuu101] #1600236
03/30/14 03:21 PM
03/30/14 03:21 PM
Graham, WA
P
Polarapete Offline
Polarapete  Offline
P
Graham, WA
The stamped metal piece at the bottom of the assembly has to contact the adjuster that spreads the brake shoes to maintain close contact to the brake drum. There is a right and a left to these parts and they are marked with "L" and "R". When the car is reversed the metal piece drops down and picks up a tooth on the adjuster and pulls it upwards when the brake is released, if you have reversed the pieces, they won't engage. These parts do wear out and are commonly available new.
I like to put a small dab of anti-seize on the contact points on the backing plates (where the brake shoe metal touches) and on the threads of the adjuster. Old backing plates will have a groove worn in the metal from contact at 6 places, you can grind it smooth if it is a small groove or fill it with weld if it is deep and then grind smooth. Disc brakes are great on the front and drum brakes are better on the rear for parking brake, wedging effect, simplicity, etc. etc..
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction
1998 Ram 2500 QuadCab, new daily driver.
2008 Honda Element
2014 Carry-On 7x14 Cargo Trailer
Re: 8 3/4 Rear Drum Brake help... [Re: MuuMuu101] #1600237
03/30/14 03:21 PM
03/30/14 03:21 PM
Nunya CA
CR8CRSHR Offline
CR8CRSHR  Offline
Nunya CA
Surprising that no one here has asked if you have a FSM...Factory Service Manual???? A good reference for getting those brakes re-done right...But we are also here to help and what was mentioned above is correct
Re: 8 3/4 Rear Drum Brake help... [Re: CR8CRSHR] #1600238
03/30/14 03:24 PM
03/30/14 03:24 PM
SoCal
SoCal
That's what I was using while referencing the other side of the rear end.
Re: 8 3/4 Rear Drum Brake help... [Re: MuuMuu101] #1600239
03/30/14 04:07 PM
03/30/14 04:07 PM
Georgia
Steve Bryant Offline
Georgia
Here is how mine looks
Re: 8 3/4 Rear Drum Brake help... [Re: Steve Bryant] #1600240
03/30/14 08:12 PM
03/30/14 08:12 PM
tennessee
P
pushbutton Offline
pushbutton  Offline
P
tennessee
Mullet?
Re: 8 3/4 Rear Drum Brake help... [Re: Steve Bryant] #1600241
03/30/14 08:32 PM
03/30/14 08:32 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
1. The triangular washer at the top of the backing plate is missing.
2. The parking brake lever retainer is not crimped.
3. The wavy washer under the retainer is missing.
4. The brake shoes are on backward.
