How to remove spray on bed liner?
#1599906
03/29/14 12:28 AM
03/29/14 12:28 AM
Posts: 516 ND
dodgedon
ND
I bought a different truck bed for my 85. It has some type of spray on bed liner that is peeling. I would like to strip the whole inside of the box and start over. I scraped on it for a couple of hours today and did a 12" by 12" area. Would sand blasting strip this off? Without damage to the inner bed floor and walls? Some places it just peeled off by hand, others it was pretty tough. Anyone ever do this?
67 Charger 383 auto 75 Dodge CNT 800 CAT Diesel 2012 Ram Crew cab 5.7 4x4
Re: How to remove spray on bed liner?
[Re: Mopar2DBone]
#1599908
03/29/14 12:47 AM
03/29/14 12:47 AM
Posts: 516 ND
dodgedon
ND
I tried some heat but it seemed to smear like tar.
[Re: dodgedon]
#1599910
03/29/14 12:54 AM
03/29/14 12:54 AM
Posts: 1,652 Amarillo, Tx
old_goat
Six Abuser
Six Abuser
Amarillo, Tx
If heat smeared it, I would try some paint stripper. Blasting might warp it.
84 D150 440/727 79 /6 swb D150 1964 A100 window van. Just because it has spark plug tubes doesn't mean it's a Hemi.
If ya haven't been there, ya just wouldn't understand.
[Re: Golden-Arm]
#1599913
03/29/14 03:49 PM
03/29/14 03:49 PM
Posts: 2,431 SK,Canada
gregsrt
SK,Canada
I asked about removing one at a sandblasting place once, they said blasting is the only effective way to do it.
An association of men who will not quarrel with one another is a thing which has never yet existed, from the greatest confederacy of nations down to a town meeting or a vestry.
Thomas Jefferson
[Re: Golden-Arm]
#1599914
03/30/14 09:16 AM
03/30/14 09:16 AM
Posts: 5,961 Greenville, PA
redraptor
Greenville, PA
have access to a steam jenny? if you had a real steam cleaner, with high pressure, i bet it would peel off, in sheets.
Depends on type of liner and prep work done. The professional shop stuff should not come off at all, that's what you paid for. The DIY stuff and a lazy azz who slathered on a gallon, maybe. Like Scratch said, possibly identify what you have and recoat it.
[Re: redraptor]
#1599915
03/30/14 12:30 PM
03/30/14 12:30 PM
Posts: 516 ND
dodgedon
ND
This looks like a DIY job. Its very thin in places. Thick with runs and sags in others. I would try to recote it but theres suface rust under it on the floor. Its peeling really bad. I'm going to try a high power pressure washer first... Where I can peel it by hand. Then maybe the wire cup on a grinder as suggested above. I will keep you guys posted...
[Re: Golden-Arm]
#1599918
03/31/14 10:29 AM
03/31/14 10:29 AM
Challenger 1
Cincinnati, Ohio
[Re: Matt Butler]
#1599921
04/02/14 02:35 PM
04/02/14 02:35 PM
Challenger 1
Cincinnati, Ohio
Best way I have done it is a 3-4,000 lb pressure washer with a 0 degree tip... you usually have to ask for that when you rent it. It cost me $45 for 4 hours and it was way better than trying to scrape off the DIY Kits.
Those who have used them know better now and would never recommend a wire wheel or similar.
I own mine it's so handy.
[Re: redraptor]
#1599922
04/02/14 02:51 PM
04/02/14 02:51 PM
Challenger 1
Cincinnati, Ohio
I can tell you have never used a steam pressure washer.
Mine can blast mortor out of brick walls...it'll remove any kind of coating with the right tip and temperature.
I have been using 3 different steam pressure washer since 1983. I wore one out and replaced it and now have one at work and at home.
This is one of if not the most valuable and useful tools I own. It get's used for many cleaning and stripping jobs. It'll remove truck bed liner I promise better and faster than anything else including sand blasting.
[Re: Challenger 1]
#1599923
04/02/14 11:06 PM
04/02/14 11:06 PM
Posts: 10,570 Sunny South Florida
Golden-Arm
Sunny South Florida
i used one to clean locomotive engine blocks, before painting them. you have to be careful with them, as they can actually blow through gaskets, and do some real damage. strips a locomotive diesel block to bare metal, in a very short time. traction motors use a gear lube, that is similar to warm tar, in viscosity. a steam jenny will cut through decades of the stuff, baked onto the gearbox, and slung all over the underside of the frame, where it leaks out. awesome for getting stains off the driveway, but again, the ability to actually damage the concrete is possible. high pressure steam, is really a super cleaning tool.
