How to remove spray on bed liner? #1599906
03/29/14 12:28 AM
03/29/14 12:28 AM
ND
dodgedon Offline OP
dodgedon  Offline OP
ND
I bought a different truck bed for my 85. It has some type of spray on bed liner that is peeling. I would like to strip the whole inside of the box and start over. I scraped on it for a couple of hours today and did a 12" by 12" area. Would sand blasting strip this off? Without damage to the inner bed floor and walls? Some places it just peeled off by hand, others it was pretty tough. Anyone ever do this?
67 Charger 383 auto
75 Dodge CNT 800 CAT Diesel
2012 Ram Crew cab 5.7 4x4
Re: How to remove spray on bed liner? [Re: dodgedon] #1599907
03/29/14 12:38 AM
03/29/14 12:38 AM
East Texas
Mopar2DBone Offline
Mopar2DBone  Offline
East Texas
What about a heat gun?????
Re: How to remove spray on bed liner? [Re: Mopar2DBone] #1599908
03/29/14 12:47 AM
03/29/14 12:47 AM
ND
dodgedon Offline OP
dodgedon  Offline OP
ND
I tried some heat but it seemed to smear like tar.
67 Charger 383 auto
Re: How to remove spray on bed liner? [Re: dodgedon] #1599909
03/29/14 12:53 AM
03/29/14 12:53 AM
East Texas
Mopar2DBone Offline
Mopar2DBone  Offline
East Texas
Paint stripper??? IDK but I don't see a sand blaster doing any good...
Let us know when you find what it takes.. Maybe Google is your friend??
Re: How to remove spray on bed liner? [Re: dodgedon] #1599910
03/29/14 12:54 AM
03/29/14 12:54 AM
Amarillo, Tx
old_goat Offline
Six Abuser
old_goat  Offline
Six Abuser
Amarillo, Tx
If heat smeared it, I would try some paint stripper. Blasting might warp it.
84 D150 440/727
79 /6 swb D150
1964 A100 window van. Just because it has spark plug tubes doesn't mean it's a Hemi.
If ya haven't been there, ya just wouldn't understand.
Re: How to remove spray on bed liner? [Re: old_goat] #1599911
03/29/14 01:00 AM
03/29/14 01:00 AM
scratchnfotraction Offline
try some of the aircraft stripper it works good.
use a cup wire wheel and knock the loose stuff off and spray over the stuck on stuff.
couple nice thick coats should level it out and seal it off good.
Re: How to remove spray on bed liner? [Re: dodgedon] #1599912
03/29/14 04:56 AM
03/29/14 04:56 AM
Sunny South Florida
Golden-Arm Offline
Golden-Arm  Offline
Sunny South Florida
have access to a steam jenny? if you had a real steam cleaner, with high pressure, i bet it would peel off, in sheets.
Re: How to remove spray on bed liner? [Re: Golden-Arm] #1599913
03/29/14 03:49 PM
03/29/14 03:49 PM
SK,Canada
gregsrt Offline
gregsrt  Offline
SK,Canada
I asked about removing one at a sandblasting place once, they said blasting is the only effective way to do it.
An association of men who will not quarrel with one another is a thing which has never yet existed, from the greatest confederacy of nations down to a town meeting or a vestry. Thomas Jefferson
Re: How to remove spray on bed liner? [Re: Golden-Arm] #1599914
03/30/14 09:16 AM
03/30/14 09:16 AM
Greenville, PA
redraptor Offline
redraptor  Offline
Greenville, PA
Depends on type of liner and prep work done. The professional shop stuff should not come off at all, that's what you paid for.
The DIY stuff and a lazy azz who slathered on a gallon, maybe.
Like Scratch said, possibly identify what you have and recoat it.
Re: How to remove spray on bed liner? [Re: redraptor] #1599915
03/30/14 12:30 PM
03/30/14 12:30 PM
ND
dodgedon Offline OP
dodgedon  Offline OP
ND
This looks like a DIY job. Its very thin in places. Thick with runs and sags in others. I would try to recote it but theres suface rust under it on the floor. Its peeling really bad. I'm going to try a high power pressure washer first... Where I can peel it by hand. Then maybe the wire cup on a grinder as suggested above. I will keep you guys posted...
67 Charger 383 auto
Re: How to remove spray on bed liner? [Re: dodgedon] #1599916
03/30/14 01:05 PM
03/30/14 01:05 PM
last one we redid we wire cupped it good and used the rustoleum spray in bed liner.
on my 440 truck I used a roll in that is faded and peeling in thin spots. so it get wire cupped and resprayed with the rustoleum.
my 85 truck with the 91 cab got 6 gallons inside and out..I bet that don't come off anytime soon. LOL!
Re: How to remove spray on bed liner? [Re: redraptor] #1599917
03/30/14 02:39 PM
03/30/14 02:39 PM
N
NITROUSN Offline
NITROUSN  Offline
N
If its prepped correctly its going to be one SOB to remove.
Re: How to remove spray on bed liner? [Re: Golden-Arm] #1599918
03/31/14 10:29 AM
03/31/14 10:29 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Re: How to remove spray on bed liner? [Re: Challenger 1] #1599919
04/01/14 01:20 AM
04/01/14 01:20 AM
IN
ahy Offline
ahy  Offline
IN
Agree a cup wire wheel on a stout angle grinder should do it. Dust mask, eye protection and have at it. Paint stripper would work also but I would personally prefer the cup wheel. Follow with a good rust stop primer and coating of your choice.
Re: How to remove spray on bed liner? [Re: ahy] #1599920
04/01/14 01:51 PM
04/01/14 01:51 PM
Sioux Falls, SD
Matt Butler Offline
Matt Butler  Offline
Sioux Falls, SD
Best way I have done it is a 3-4,000 lb pressure washer with a 0 degree tip... you usually have to ask for that when you rent it. It cost me $45 for 4 hours and it was way better than trying to scrape off the DIY Kits.
Re: How to remove spray on bed liner? [Re: Matt Butler] #1599921
04/02/14 02:35 PM
04/02/14 02:35 PM
Cincinnati, Ohio
Cincinnati, Ohio
Those who have used them know better now and would never recommend a wire wheel or similar.
I own mine it's so handy.
Re: How to remove spray on bed liner? [Re: redraptor] #1599922
04/02/14 02:51 PM
04/02/14 02:51 PM
Cincinnati, Ohio
Cincinnati, Ohio
I can tell you have never used a steam pressure washer.
Mine can blast mortor out of brick walls...it'll remove any kind of coating with the right tip and temperature.
I have been using 3 different steam pressure washer since 1983. I wore one out and replaced it and now have one at work and at home.
This is one of if not the most valuable and useful tools I own. It get's used for many cleaning and stripping jobs. It'll remove truck bed liner I promise better and faster than anything else including sand blasting.
Re: How to remove spray on bed liner? [Re: Challenger 1] #1599923
04/02/14 11:06 PM
04/02/14 11:06 PM
Sunny South Florida
Golden-Arm Offline
Golden-Arm  Offline
Sunny South Florida
i used one to clean locomotive engine blocks, before painting them. you have to be careful with them, as they can actually blow through gaskets, and do some real damage. strips a locomotive diesel block to bare metal, in a very short time. traction motors use a gear lube, that is similar to warm tar, in viscosity. a steam jenny will cut through decades of the stuff, baked onto the gearbox, and slung all over the underside of the frame, where it leaks out. awesome for getting stains off the driveway, but again, the ability to actually damage the concrete is possible. high pressure steam, is really a super cleaning tool.
