Help--70 Challenger 19" radiator to a 26" conversion? #1598680
03/26/14 03:16 PM
03/26/14 03:16 PM
USA
l13 Offline OP
l13  Offline OP
USA
I am looking to convert a 19" radiator to a 26" in a 1970 Challenger. I have had several suggestions offered to make this happen and yet still not sure how to proceed. Ultimately, I would like this to look stock and not hacked up or converted.
Several individuals say I need the 22" conversion panel only (left panel), another mentions that both left and right radiator support panels need to be replaced and yet another says only a complete support assembly repalcement will work.
Has anyone done this type of conversion correctly and if so are you willing to share the process?
Re: Help--70 Challenger 19" radiator to a 26" conversion? [Re: l13] #1598681
03/26/14 06:36 PM
03/26/14 06:36 PM
Welcome aboard . I hope that someone who has done it sees this & can give you some info so that you can make the right mods
Re: Help--70 Challenger 19" radiator to a 26" conversion? [Re: l13] #1598682
03/26/14 08:14 PM
03/26/14 08:14 PM
North Dakota
Azzkikrcuda Offline
Azzkikrcuda  Offline
North Dakota
I did this on a 70 Challenger went from a 22" to a 26" radiator. Bolted the stock 26" radiator in on the drive side using the factory bolt holes. Drilled new holes on the passenger side core support to line up with the radiator mount holes. You will need to add washers or make spacers to get it even on the passenger side. You can cut out the passenger side core support opening to get more air flow across the wider radiator. Doing this I used the stock shroud and fan and they lined up perfectly. If you want the original look you will have to replace the passenger side core support. If you make nice spacers that run the full length up and down on the passenger side radiator mounting flange and cut the core opening wider it looks good.
The only Carbs I care about are under the hood!
Re: Help--70 Challenger 19" radiator to a 26" conversion? [Re: l13] #1598683
03/26/14 08:26 PM
03/26/14 08:26 PM
San Francisco
dilvoy Offline
dilvoy  Offline
San Francisco
Both sides need to be changed to make it look original, because both sides are different than the small radiator type. You'll need to remove the fenders to completely change them.
Re: Help--70 Challenger 19" radiator to a 26" conversion? [Re: RapidRobert] #1598684
03/27/14 12:24 PM
03/27/14 12:24 PM
USA
l13 Offline OP
l13  Offline OP
USA
Hi Rapid Robert,
Thank you for the greeting and comment.
L13
Re: Help--70 Challenger 19" radiator to a 26" conversion? [Re: dilvoy] #1598685
03/27/14 12:35 PM
03/27/14 12:35 PM
USA
l13 Offline OP
l13  Offline OP
USA
Good morning Dilvoy & Azzkikcuda,
Thank you for your time and efforts to respond to my need for help on this project.
Obviously, I would prefer to keep it original looking and not have to hack up the panels or take the frontend apart.
If I went to a 22" radiator does this change anything in regards to replacing one or both panels?
Thanks again,
Re: Help--70 Challenger 19" radiator to a 26" conversion? [Re: l13] #1598686
03/27/14 01:39 PM
03/27/14 01:39 PM
East Aurora (Buffalo) NY
RoadRunner Offline
RoadRunner  Offline
I wasn't sure if there was a 19" and 22" radiator. I do know that there are only two openings for the core supprot. One being the 22" and the other for the 26" wide unit. I would guess the 19" wide radiator probably has wider side mounts to fit the same 22" wide opening. As mentioned both sides are different, though the drivers side is only about 1/2" different. I have seen folks slot the holes in the mounting brace to slide over the radiator. you still need to change the passenger side.
Another option may be to find a radiator shop that can recore your stock radiator with an extra row of tubes and higher fin count. I did this on my 68 Road Runner and it kept my nicely built 440 cool even in the summer.
68 Road Runner (383/4speed, post car w/decor pkg) - Major Project
69 Road Runner w/472 Hemi & 4 speed.
70 Challenger R/T SE EF8 w/ V9J, U - A32 - Major Project
2023 Ford Mach 1
Re: Help--70 Challenger 19" radiator to a 26" conversion? [Re: RoadRunner] #1598687
03/27/14 02:11 PM
03/27/14 02:11 PM
I do know that there are only two openings for the core supprot. Another option may be to find a radiator shop that can recore your stock radiator with an extra row of tubes and higher fin count.
If I wanted a stock rad that's what I would do. get the bigger one that will fit without cutting things then having a shop recore it. There's always the "champion" alum (non stock) radiator option. Shroud/properly spaced (into it) MP thermal clutch fan/anticav plate/180 hi flow stat
Re: Help--70 Challenger 19" radiator to a 26" conversion? [Re: l13] #1598688
03/27/14 02:16 PM
03/27/14 02:16 PM
State of Fascism
52savoy Offline
52savoy  Offline
State of Fascism
It just so happens I have a set(E-body) ..left and right for a 26" radiator that I was going to use on a project.. Send me pm if your interested.
Re: Help--70 Challenger 19" radiator to a 26" conversion? [Re: l13] #1598689
04/01/14 11:01 AM
04/01/14 11:01 AM
Wausau Wisconsin USA North Ame...
radiatorman Offline
radiatorman  Offline
Thanks again,
19" and 22" radiators use the same radiator support. The brackets that solder to the radiator are the difference as they are wider on the 19" radiator.
Bob
Re: Help--70 Challenger 19" radiator to a 26" conversion? [Re: radiatorman] #1598690
04/01/14 04:31 PM
04/01/14 04:31 PM
USA
l13 Offline OP
l13  Offline OP
USA
Hi Bob,
Thank you for the information. This helps.
Re: Help--70 Challenger 19" radiator to a 26" conversion? [Re: l13] #1598691
04/04/14 10:47 AM
04/04/14 10:47 AM
near New Haven, CT
fireeng Offline
fireeng  Offline
near New Haven, CT
I just changed the passenger side section on my radiator support to go from a 22 to a 26 in my 71 challenger it looks completely stock.
2016 Diesel Ram 3500 Mason Dump
1971 Challenger
2013 Jeep Wrangler
1979 Dodge Ram Power Wagon 400 Mini Pumper
My other car is a Fire Truck.
Re: Help--70 Challenger 19" radiator to a 26" conversion? [Re: fireeng] #1598692
04/04/14 04:32 PM
04/04/14 04:32 PM
USA
l13 Offline OP
l13  Offline OP
USA
Hi Fireeng,
Thank you for the photo,looks good. 52Savoy has been very helpful with info as well and had the side panels I needed. I will install them when they arrive. Did you spot weld yours or mig them with a fill?
Re: Help--70 Challenger 19" radiator to a 26" conversion? [Re: l13] #1598693
04/04/14 04:38 PM
04/04/14 04:38 PM
near New Haven, CT
fireeng Offline
fireeng  Offline
near New Haven, CT
Hi Fireeng,
Not sure, the guys at the shop did it, but I believe it was migged..
1971 Challenger
2013 Jeep Wrangler
