Re: Help--70 Challenger 19" radiator to a 26" conversion?
[Re: l13]
#1598681
03/26/14 06:36 PM
03/26/14 06:36 PM
RapidRobert
Welcome aboard . I hope that someone who has done it sees this & can give you some info so that you can make the right mods
[Re: l13]
#1598682
03/26/14 08:14 PM
03/26/14 08:14 PM
Posts: 1,809 North Dakota
Azzkikrcuda
North Dakota
I did this on a 70 Challenger went from a 22" to a 26" radiator. Bolted the stock 26" radiator in on the drive side using the factory bolt holes. Drilled new holes on the passenger side core support to line up with the radiator mount holes. You will need to add washers or make spacers to get it even on the passenger side. You can cut out the passenger side core support opening to get more air flow across the wider radiator. Doing this I used the stock shroud and fan and they lined up perfectly. If you want the original look you will have to replace the passenger side core support. If you make nice spacers that run the full length up and down on the passenger side radiator mounting flange and cut the core opening wider it looks good.
The only Carbs I care about are under the hood!
[Re: l13]
#1598686
03/27/14 01:39 PM
03/27/14 01:39 PM
Posts: 5,138 East Aurora (Buffalo) NY
RoadRunner
I wasn't sure if there was a 19" and 22" radiator. I do know that there are only two openings for the core supprot. One being the 22" and the other for the 26" wide unit. I would guess the 19" wide radiator probably has wider side mounts to fit the same 22" wide opening. As mentioned both sides are different, though the drivers side is only about 1/2" different. I have seen folks slot the holes in the mounting brace to slide over the radiator. you still need to change the passenger side.
Another option may be to find a radiator shop that can recore your stock radiator with an extra row of tubes and higher fin count. I did this on my 68 Road Runner and it kept my nicely built 440 cool even in the summer.
68 Road Runner (383/4speed, post car w/decor pkg) - Major Project 69 Road Runner w/472 Hemi & 4 speed. 70 Challenger R/T SE EF8 w/ V9J, U - A32 - Major Project 2023 Ford Mach 1
[Re: l13]
#1598689
04/01/14 11:01 AM
04/01/14 11:01 AM
Posts: 433 Wausau Wisconsin USA North Ame...
radiatorman
Good morning Dilvoy & Azzkikcuda,
Thank you for your time and efforts to respond to my need for help on this project. Obviously, I would prefer to keep it original looking and not have to hack up the panels or take the frontend apart.
If I went to a 22" radiator does this change anything in regards to replacing one or both panels? Thanks again,
19" and 22" radiators use the same radiator support. The brackets that solder to the radiator are the difference as they are wider on the 19" radiator.
Bob
[Re: l13]
#1598691
04/04/14 10:47 AM
04/04/14 10:47 AM
Posts: 915 near New Haven, CT
fireeng
near New Haven, CT
I just changed the passenger side section on my radiator support to go from a 22 to a 26 in my 71 challenger it looks completely stock.
2016 Diesel Ram 3500 Mason Dump 1971 Challenger 2013 Jeep Wrangler 1979 Dodge Ram Power Wagon 400 Mini Pumper My other car is a Fire Truck.
