How NOT to weld. LOL #1597902
03/24/14 04:03 PM
03/24/14 04:03 PM
PA.
pittsburghracer Online work OP
"Little"John
pittsburghracer  Online Work OP
"Little"John
PA.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: How NOT to weld. LOL [Re: pittsburghracer] #1597903
03/24/14 04:13 PM
03/24/14 04:13 PM
dogdays Offline
dogdays  Offline
Looking at it made me literally feel sick to my stomach.
R.
Re: How NOT to weld. LOL [Re: dogdays] #1597904
03/24/14 04:31 PM
03/24/14 04:31 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I dont even know what they would call that... it sure
isnt welding
Re: How NOT to weld. LOL [Re: MR_P_BODY] #1597905
03/24/14 04:48 PM
03/24/14 04:48 PM
sweden
sshemi Offline
sshemi  Offline
sweden
Re: How NOT to weld. LOL [Re: sshemi] #1597906
03/24/14 05:05 PM
03/24/14 05:05 PM
Finally a HUSKER again
Moparnut426 Offline
Moparnut426  Offline
Dad used to call that chicken S#@T, or chicken scratching LOL
Re: How NOT to weld. LOL [Re: Moparnut426] #1597907
03/24/14 07:12 PM
03/24/14 07:12 PM
Q
Quicktree Offline
Quicktree  Offline
Q
doesn't look like a weld to me, looks more like a rust pile
Re: How NOT to weld. LOL [Re: Quicktree] #1597908
03/24/14 07:18 PM
03/24/14 07:18 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
I've seen worse.
Re: How NOT to weld. LOL [Re: rickraw] #1597909
03/24/14 07:38 PM
03/24/14 07:38 PM
FastOne Offline
FastOne  Offline
Re: How NOT to weld. LOL [Re: FastOne] #1597910
03/24/14 08:03 PM
03/24/14 08:03 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Are those parts from the Titanic?
Re: How NOT to weld. LOL [Re: dvw] #1597911
03/24/14 08:36 PM
03/24/14 08:36 PM
Pittsburgh PA
Eric Offline
Eric  Offline
Pittsburgh PA
Eh...nothing a good grinder couldn't fix...
5.53 @ 125 1/8th on the launch control..more left in her!
Re: How NOT to weld. LOL [Re: Eric] #1597912
03/24/14 09:13 PM
03/24/14 09:13 PM
in front of the computer
8
80arrow Offline
80arrow  Offline
smear some silicone over it and some paint, good to go
Re: How NOT to weld. LOL [Re: 80arrow] #1597913
03/24/14 09:23 PM
03/24/14 09:23 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Naaa... paint dont like to stick to silicone.. grind
smooth.. as good as possible.. bondo smooth.. paint it..
all better... till the first time out
Re: How NOT to weld. LOL [Re: pittsburghracer] #1597914
03/24/14 10:23 PM
03/24/14 10:23 PM
Randolph, Ohio--N.E. Ohio
Goat330 Offline
Goat330  Offline
looks like a bunch of barnacles
Re: How NOT to weld. LOL [Re: Goat330] #1597915
03/24/14 10:31 PM
03/24/14 10:31 PM
Manistee, Michigan.
High Impact Offline
High Impact  Offline
Manistee, Michigan.
A buddy of mine always says..."you dont have to be a good welder.....Just a good grinder"
Re: How NOT to weld. LOL [Re: High Impact] #1597916
03/24/14 10:51 PM
03/24/14 10:51 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Only one problem with that... if you get your chassis
certed, they dont allow any grinding on any welds
Re: How NOT to weld. LOL [Re: MR_P_BODY] #1597917
03/24/14 11:10 PM
03/24/14 11:10 PM
8
80arrow Offline
80arrow  Offline
lol, that's true paint don't stick to silicone. Bondo is better for that "weld"
Re: How NOT to weld. LOL [Re: pittsburghracer] #1597918
03/24/14 11:24 PM
03/24/14 11:24 PM
Andrews,In. U.S.of A.
67_Satellite Offline
Looks like it was welded by dipping it in molten lava,then adding a topsoil based flux.
Re: How NOT to weld. LOL [Re: 80arrow] #1597919
03/24/14 11:29 PM
03/24/14 11:29 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I had a odd ball weld job the other day.. one of my
neighbors brought over the lever to the rear blade
for his tractor... it had broken off right at a larger
boss area.. I knew the handle was steel and I thought
the boss was as well... well it didnt want to tack together
so by chance I pulled out a magnet to check what I
had... the boss area was cast alum and the handle
was steel... I said.. what the hell is this.. after
cleaning it a bit with a die grinder I seen the handle
was either pressed into the casting or it was cast
around the handle.... I ground back the alum on one
side to get to the steel about 1/8" then I tigged on it to build
up some material then I added a reinforcement piece
and welded that to it then welded the handle to both
the original steel and the reinforcement metal...
turned out real nice and was as strong if not stronger
than before... but it took way more time than I figured,,
but it was a freebie anyways
Re: How NOT to weld. LOL [Re: MR_P_BODY] #1597920
03/25/14 01:50 PM
03/25/14 01:50 PM
Norwalk Ohio
cudasteve68 Offline
cudasteve68  Offline
Norwalk Ohio
I heard a rumor of an older SS/AH that would not pass tech anymore because of the welds??? Not sure if it was true or not, but that car won Indy, a few times if I recall......
This would be in the early 1990's
Re: How NOT to weld. LOL [Re: 80arrow] #1597921
03/25/14 02:06 PM
03/25/14 02:06 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
I see you've read the Jeff Lutz thread on Yellowbullet....
