k frame #'s #1597874
03/24/14 03:49 PM
03/24/14 03:49 PM
Loganville GA.
K
kdsmith07 Offline OP
K
Loganville GA.
hi all,
i have a k frame that we think is out of a 70 challenger r/t bb.the oval tag has the upside down # 72 on it.i know it's the last 2 didits of the part # but i can't find a k frame ending in 72.any help would be greatly appreciated,kent
Re: k frame #'s [Re: kdsmith07] #1597875
03/24/14 03:56 PM
03/24/14 03:56 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Does it have a skid plate? Probably a mis-stamped 74.
Re: k frame #'s [Re: John_Kunkel] #1597876
03/24/14 08:43 PM
03/24/14 08:43 PM
Loganville GA.
K
K
Loganville GA.
no skid plate but he's pretty sure it is a bb k frame.any other way to tell?thanks
Re: k frame #'s [Re: kdsmith07] #1597877
03/24/14 08:47 PM
03/24/14 08:47 PM
Western Md.
skicker Offline
"The Champ"
skicker  Offline
"The Champ"
Western Md.
I can't speak to an E body but the 70 B body K frames are the same big to small block. I thought the only differences between B and E was the angle of the steering box mount???
...FAFO...
Re: k frame #'s [Re: skicker] #1597878
03/24/14 10:32 PM
03/24/14 10:32 PM
Loganville GA.
K
K
Loganville GA.
i really don't know.that's why i came to the mopar brain trust
Re: k frame #'s [Re: skicker] #1597879
03/24/14 10:34 PM
03/24/14 10:34 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Could it be 52 ?
If so, mid year 318, 340, 340-6 & 383.
Re: k frame #'s [Re: Alaskan_TA] #1597880
03/24/14 10:51 PM
03/24/14 10:51 PM
Detroit Michigan
stinger Offline
stinger  Offline
Detroit Michigan
my 70 barracuda that was born with a 318 has a 72 tag on the K,hope this helps.
Re: k frame #'s [Re: stinger] #1597881
03/24/14 11:25 PM
03/24/14 11:25 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
For you guys with the 72, what are the scheduled production dates of your cars?
I checked some early broadcast sheets for 1970 318, 340 & 383 cars & found 12 & 76, so give me a date range & I can did deeper.
Also, if you have your broadcast sheets, what numbers are printed under FRAME on line 4?
Re: k frame #'s [Re: Alaskan_TA] #1597882
03/25/14 02:25 AM
03/25/14 02:25 AM
Loganville GA.
K
K
Loganville GA.
it's a 72 for sure.he swears it came from his 70 chally r/t 383 car.i don't know.appreciate all the info.though.this is good stuff,thanks
Re: k frame #'s [Re: kdsmith07] #1597883
03/25/14 04:37 PM
03/25/14 04:37 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
A '70 E-body V-8 without skid plate would be 3583074.
Re: k frame #'s [Re: John_Kunkel] #1597884
03/25/14 07:35 PM
03/25/14 07:35 PM
Home of the Bluegrass
MoparJunkie Offline
MoparJunkie  Offline
My '70 U code Challenger R/T, which is a LA plant car with a spd of 4/1 has a 77 on the build sheet.
"It takes a Mopar to catch a Mopar”
1971 Roadrunner FJ6 Sassy Grass 505"RB, 18 spline 4 speed, and Dana 60 with 3.54
2022 Hellcat Charger Widebody Redeye Jailbreak: Hellraisin with 8 speed auto
Re: k frame #'s [Re: MoparJunkie] #1597885
03/25/14 11:46 PM
03/25/14 11:46 PM
Detroit Michigan
stinger Offline
stinger  Offline
Detroit Michigan
my car was originally a 318 car built in LA. I've owned the car since 82 but I don't have the build sheet,sorry. I do have the original order sheet from northland dodge and I'm the second owner.
If this is the tag you guy's are referring to.
Re: k frame #'s [Re: stinger] #1597886
03/26/14 12:30 AM
03/26/14 12:30 AM
Loganville GA.
K
K
Loganville GA.
that's the one i have.thanks for all the info.everyone.
Re: k frame #'s [Re: kdsmith07] #1597887
03/27/14 01:05 PM
03/27/14 01:05 PM
USA
l13 Offline
l13  Offline
USA
Good morning,
I have an original 70 6 pack Chally. The "Coin" on the front of the"K" member has a 12 stamped on it. I have seen this (12) on several 70/71 BB and SB cars previously. My "K" member has the skid plate however my understanding is that the skid plate was not always installed on 6 pack cars but was for the Hemi cars.
I am fairly new to Mopars so I am always open to correction and learning new information, just wanted to share this.
Hope this helps.
Re: k frame #'s [Re: Alaskan_TA] #1597888
03/27/14 03:09 PM
03/27/14 03:09 PM
pa.
dan9 Offline
dan9  Offline
pa.
I have a 70 Challenger. Door sticker says 6/70, k member is 52. Was a 318/904.
Re: k frame #'s [Re: dan9] #1597889
03/27/14 05:15 PM
03/27/14 05:15 PM
MoparJunkie Offline
MoparJunkie  Offline
Forgot to add that my K frame has no coin...Can anyone explain this?????
Re: k frame #'s [Re: MoparJunkie] #1597890
03/27/14 05:47 PM
03/27/14 05:47 PM
central il.
second 70 Offline
second 70  Offline
central il.
my 2-70 Hamtramck Cuda has #12 on k-frame. was 383 4-speed now 426 hemi with big block ears and 4-speed.
