use gaskets between aluminum intake and cast heads??
#159725
12/01/08 06:26 PM
12/01/08 06:26 PM
Posts: 106 Oakbank, MB Canada
mbmopar
Oakbank, MB Canada
should i use paper intake gaskets with an aluminum intake on my 440 as well as using a stamped steel valley pan ????
any info is greatly appreciated, as i am ready to install the intake.
Thanks !
Derek
"Put a Dodge in your garage!"
Re: use gaskets between aluminum intake and cast heads??
[Re: mbmopar]
#159726
12/01/08 06:28 PM
12/01/08 06:28 PM
I did, got a set of fel pros for my performer rpm. they're included for a reason.
#159728
12/01/08 07:58 PM
12/01/08 07:58 PM
mbmopar
Oakbank, MB Canada
i bought the intake new, but did not come with a box or gaskets, it's a holley street dominator....i have a set of paper gaskets i'll use as well i guess, thanks !
derek
[Re: MoparforLife]
#159731
12/01/08 08:52 PM
12/01/08 08:52 PM
RapidRobert
You'll get alot of diff opinions on this. I dont feel that a metal gasket is pliable enough to seal 16 in hg of vacuum. Alot of times the added thickness of the paper will throw off the alignment & the bolts wont line up. My preference is to use the valley pan with #2 permatex,the brown goo in the toothpaste tube. It stays pliable, especially with the diff expansion rates of iron & aluminum. works for me.
[Re: mbmopar]
#159733
12/02/08 07:06 AM
12/02/08 07:06 AM
mbmopar
Oakbank, MB Canada
after trying to line up the mounting holes using the gaskets..i ditched them and resorted to some of the permatex #2 sealer.
THANKS !!!!!!!!!!
Best, Derek
