Over flow/Catch cans mounting location #1597025
03/23/14 12:11 AM
03/23/14 12:11 AM
Menomonee Falls
DemonDust Offline OP
Menomonee Falls
I rent part of huge shop and one of the other tenants was walking thru my area as I was getting my duster ready for this year. He noticed under my hood I had a catch can from late model vehicle. He then told me this was very bad. The catch can should be in the trunk and a reservoir under the hood with a line running from the reservoir to the catch can in the trunk. Then a hose out by the rear bumper to drain any fluid that should overflow. He's an old racer so I'm assuming these are one of the tricks you learn over the years. Do any of you do this, or have you seen this done? Pics?
SDG Motorsports
Hellcat Demon and Redeye Supercharger CNC Porting
https://www.sdgmotorsports.com/
Re: Over flow/Catch cans mounting location [Re: DemonDust] #1597026
03/23/14 12:31 AM
03/23/14 12:31 AM
Plymouth Meeting, PA
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
trunk is the correct location according to me also
BB, TT5,Procharged 3300lb Street Car 4.79/154
Re: Over flow/Catch cans mounting location [Re: DemonDust] #1597027
03/23/14 12:45 AM
03/23/14 12:45 AM
Cab_Burge Online work
Cab_Burge  Online Work
I use to use a 1 quart gear lube plastic bottle tie rapped to the radiator cross suport with the over flow hose stuck into the bottom of it, never had any isues with it that way or with tech.
Re: Over flow/Catch cans mounting location [Re: DemonDust] #1597028
03/23/14 01:34 AM
03/23/14 01:34 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I understand what he is saying about the hose out the
back but I use the catch can up front I have NEVER
filled that can where it would dump fluid on the track...
I do check it regularly but its only had a few drops
in it
Re: Over flow/Catch cans mounting location [Re: MR_P_BODY] #1597029
03/23/14 09:40 AM
03/23/14 09:40 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Mine is on the front also.I think the most thats ever been in it is a few ounces.Stock 65 rad.Rocky
Chrysler Firepower
Re: Over flow/Catch cans mounting location [Re: therocks] #1597030
03/23/14 01:10 PM
03/23/14 01:10 PM
Indiana
Scott58 Offline
Scott58  Offline
Indiana
I think the most important thing is to have the outlet of the overflow hose (not the tank drain), be it in front or out back, approximately on the centerline of the vehicle and at a location that track personnel can see it if there is overflow coming out. Keeps the spill (if any) away from your tires!
Re: Over flow/Catch cans mounting location [Re: Scott58] #1597031
03/23/14 01:19 PM
03/23/14 01:19 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Yeah.. my outlet hose is tie rapped to the trans
coolant line almost dead center in the car at the
radiator.. so if it were leaking the track guy could
see it EASILY... I use to use a Summit plastic catch
tank but later I built a nice alum one
Re: Over flow/Catch cans mounting location [Re: MR_P_BODY] #1597032
03/23/14 02:41 PM
03/23/14 02:41 PM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
Good safe options for sure. But I've gotta think that the odds of a catch-can overflow ever coming into play are far less than the odds of a busted radiator hose, or a rod coming through the side of your block. (Guess thats what diapers are for....)
Re: Over flow/Catch cans mounting location [Re: StealthWedge67] #1597033
03/23/14 02:50 PM
03/23/14 02:50 PM
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
most rules and common sense are for safety for you. It all depends on how you perceive it. I use no hose clamps, no plastic bottles, no tie wraps and a belly pan in case of a disaster. If something happens to one of my cars or one of my customers I know I did everything possible to make sure that guy and his car comes home.
Re: Over flow/Catch cans mounting location [Re: bigtimeauto] #1597034
03/23/14 03:21 PM
03/23/14 03:21 PM
On the parachute mount
N
n20mstr Online content
n20mstr  Online Content
N
Calm down bob.....lol it's only a rad overflow can !
Mine is mounted under the inner fender behind the headlight. Never seems to have anything in it ? In the rear is safest....any fluid spilled will behind your rear tires...but then it's in front of the next racer coming down the track....lmao !
....BAD A$$ STREET CAR.....
Re: Over flow/Catch cans mounting location [Re: n20mstr] #1597035
03/24/14 12:07 AM
03/24/14 12:07 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I have never heard of anyone having their catch can in the trunk. Does the NHRA rulebook say anything about it being in the trunk ? Ron
Re: Over flow/Catch cans mounting location [Re: 383man] #1597036
03/24/14 12:11 AM
03/24/14 12:11 AM
MR_P_BODY Offline
MR_P_BODY  Offline
All it says is that you are required to have one and
the size of it... you can put it anywhere
Re: Over flow/Catch cans mounting location [Re: n20mstr] #1597037
03/24/14 12:13 AM
03/24/14 12:13 AM
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
yeah I forgot what website I was on
Re: Over flow/Catch cans mounting location [Re: bigtimeauto] #1597038
03/24/14 12:27 AM
03/24/14 12:27 AM
MR_P_BODY Offline
MR_P_BODY  Offline
You dont like it here.... then stay over on the
other ones that you like... pretty simple
Re: Over flow/Catch cans mounting location [Re: MR_P_BODY] #1597039
03/24/14 12:33 AM
03/24/14 12:33 AM
N
N
Lmao ! There you go bob......
Anyone want to discuss parachute mounting ?
Re: Over flow/Catch cans mounting location [Re: n20mstr] #1597040
03/24/14 12:39 AM
03/24/14 12:39 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Heah.. all I said was if he didnt like it.. its no
big deal... I just dont understand it if someone doesnt
care for a place why they continue to use it... I
know you guys from Joshs site tend to think this place
is too much goody two shoes.. since I was over there for
quite some time
Re: Over flow/Catch cans mounting location [Re: n20mstr] #1597041
03/24/14 12:40 AM
03/24/14 12:40 AM
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
funny part is they all have the catch cans and chutes mounted the same, guess i'm just doing this car building thingy wrong wrong
Re: Over flow/Catch cans mounting location [Re: DemonDust] #1597042
03/24/14 12:41 AM
03/24/14 12:41 AM
Az
Crizila Offline
Crizila  Offline
Az
Lets call it a coolant recovery tank and put it right next to the rad.
Fastest 300
Re: Over flow/Catch cans mounting location [Re: MR_P_BODY] #1597043
03/24/14 12:57 AM
03/24/14 12:57 AM
N
N
quite some time
Mr p......we all started on this site ...
Just having fun with bob, sorry to offend you. Lighten up a little
I like both boards, they both work for me
Re: Over flow/Catch cans mounting location [Re: n20mstr] #1597044
03/24/14 01:03 AM
03/24/14 01:03 AM
MR_P_BODY Offline
MR_P_BODY  Offline
quite some time
I dont have any problems.. its all good by me
