Torsion Bar Installation #1596940
03/22/14 09:46 PM
03/22/14 09:46 PM
McHenry, Illinois
RAUPLEMINZE454 Offline OP
McHenry, Illinois
Hey guys,
Is there a place to find a step by step or even a video on how to install torsion bars. I have a 1971 Demon that I have to install the entire front suspension, k member, and drive train.
Thanks in advance,
Brian
Re: Torsion Bar Installation [Re: RAUPLEMINZE454] #1596941
03/22/14 10:09 PM
03/22/14 10:09 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
get an FSM..
I am truckless..
Re: Torsion Bar Installation [Re: RAUPLEMINZE454] #1596942
03/22/14 10:13 PM
03/22/14 10:13 PM
Georgia
magiccuda Offline
magiccuda  Offline
Georgia
Back of on the adjusting bolts slide them in. Adjust the height as needed. There is a left and right on the bars. I use a big cable clamp on mine to have something to tap on. Or you can buy a tool made to install them.
Re: Torsion Bar Installation [Re: RAUPLEMINZE454] #1596943
03/22/14 10:15 PM
03/22/14 10:15 PM
Seattle, WA.
E
edp Offline
edp  Offline
E
Seattle, WA.
the factory service manual has a process outlined in it, you might find the correct year you can download from here....
http://www.mymopar.com/index.php?pid=109
biggest thing would be make sure the tension off the LCA's is released prior to trying to do anything - if you dont know how to do that just ask someone will tell you.
Re: Torsion Bar Installation [Re: edp] #1596944
03/22/14 10:22 PM
03/22/14 10:22 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
bars have left and right...must be clocked correctly in engage rear sockets...and front pivot must be aligned to allow the t bar to engage the front socket while remained correctly clocked to enter rear sockets...
not that difficult..
Tony
70 AARCuda Vitamin C
Re: Torsion Bar Installation [Re: 70AARcuda] #1596945
03/22/14 10:24 PM
03/22/14 10:24 PM
Seattle, WA.
E
edp Offline
edp  Offline
E
Seattle, WA.
oh yeah, and that!
Re: Torsion Bar Installation [Re: 70AARcuda] #1596946
03/22/14 10:28 PM
03/22/14 10:28 PM
McHenry, Illinois
McHenry, Illinois
Thanks guys! They are firm feel's if that makes any difference. Does the manual have pictures for a step by step?
Re: Torsion Bar Installation [Re: RAUPLEMINZE454] #1596947
03/22/14 10:40 PM
03/22/14 10:40 PM
Seattle, WA.
E
edp Offline
edp  Offline
E
Seattle, WA.
bar type shouldn't affect install method, they still have to go in....
when I installed mine I slathered them with anti seize as well
Re: Torsion Bar Installation [Re: edp] #1596948
03/22/14 10:49 PM
03/22/14 10:49 PM
Mesa, Arizona
dart4forte Offline
dart4forte  Offline
Mesa, Arizona
Whatever you do don't take a hammer to them. Get a correct installation tool.
Re: Torsion Bar Installation [Re: dart4forte] #1596949
04/09/14 02:28 PM
04/09/14 02:28 PM
McHenry, Illinois
McHenry, Illinois
Hey Guys,
I was able to get the torsion bars installed on the 1971 Demon. It looked a little intimidating but was pretty straight forward. I only ran into one problem when we had to wire brush the inside of the sub frame receptacles because the were filled with sand and paint from the media blast and painting. I used anti seize on each end of the torsion bars (940 firm feels).
I also installed the upper A-arms and shocks.
I would have installed the MP Power Disc Brake Kit also but I ran into a problem. When I installed the spindle and tried to tighten the castle nut to the upper ball joint the shaft kept spinning. I noticed this because the zerk fitting kept spinning. So what is the trick to installing the spindle and keeping that upper ball joint shaft still while tightening the castle nut?
Re: Torsion Bar Installation [Re: RAUPLEMINZE454] #1596950
04/09/14 03:01 PM
04/09/14 03:01 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
Just in case you haven't read the book yet, before you install the boots, pack the recess with grease.
Re: Torsion Bar Installation [Re: 71birdJ68] #1596951
04/09/14 04:01 PM
04/09/14 04:01 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Drive the end of the A arm down so the ball joint stud is in the spindle tight.
Re: Torsion Bar Installation [Re: stumpy] #1596952
04/09/14 09:17 PM
04/09/14 09:17 PM
IN
ahy Offline
ahy  Offline
IN
Looks nice!
Re: Torsion Bar Installation [Re: ahy] #1596953
04/18/14 07:40 PM
04/18/14 07:40 PM
McHenry, Illinois
McHenry, Illinois
Thanks guys!!!
Re: Torsion Bar Installation [Re: RAUPLEMINZE454] #1596954
04/18/14 09:47 PM
04/18/14 09:47 PM
Greer, SC
TooMany62s Offline
TooMany62s  Offline
Greer, SC
Also, if you removed or rebuilt the lower control arms don't tighten the mounting bolts until the car is sitting at ride height.
Re: Torsion Bar Installation [Re: TooMany62s] #1596955
04/19/14 12:09 AM
04/19/14 12:09 AM
McHenry, Illinois
McHenry, Illinois
With weight on them?
Re: Torsion Bar Installation [Re: RAUPLEMINZE454] #1596956
04/19/14 01:26 AM
04/19/14 01:26 AM
Greer, SC
TooMany62s Offline
TooMany62s  Offline
Greer, SC
Yes, snug the mounting nut but don't torque it to spec until you have the car at ride height. I can copy the correct pages from the manual and email them to you. PM me here if you want me to do that.
