Turn signals not working properly #1596657
03/22/14 02:30 PM
03/22/14 02:30 PM
PA
70HemiGTX Offline OP
PA
OK. So my turnsignals didn't work on my 68 Dart. I put in a new switch and now they still don't work correctly. If I turn the 4-ways on they work fine. If I turn the directionals on, they will blink a few (3,4,5 or so) times then they will stop. They may start back up again but just at a sporadic blink. When they stop, you can hear the blinker relay do the first "tink", but not the second "tonk" (for lack of better words). When they stop the are dark, not illuminated. What am I missing???
Re: Turn signals not working properly [Re: 70HemiGTX] #1596658
03/22/14 02:48 PM
03/22/14 02:48 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
There are two flashers, the easy one to find and get to is for the hazards. The hard one to find and get to is for the turn signals.
The hard one ls bolted to the pass side of the ash tray housing on an A body, IIRC. I suppose you could pull the glove box liner out to get to it.
Don't be the exception.
Re: Turn signals not working properly [Re: Supercuda] #1596659
03/22/14 03:03 PM
03/22/14 03:03 PM
PA
PA
No problem getting at that one. It is zip tied to my roll cage bar under the dash. I'll try a new one.
Re: Turn signals not working properly [Re: 70HemiGTX] #1596660
03/22/14 04:04 PM
03/22/14 04:04 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Toss the old metal type and get one of the new electronic types.They are about 10 or 12 bucks at any parts store.they work great.My 65 had a problem that they were either too fast or too slow.It fixed that problem and they work great.Rocky
Chrysler Firepower
Re: Turn signals not working properly [Re: therocks] #1596661
03/22/14 04:34 PM
03/22/14 04:34 PM
PA
PA
That sounds like a plan! It seems I don't have a good enough ground on the cannister for it to work proplerly. I'm definitely trying one of the plastic ones.
Re: Turn signals not working properly [Re: 70HemiGTX] #1596662
03/22/14 04:56 PM
03/22/14 04:56 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Just an FYI, the canister does not require grounding.
Re: Turn signals not working properly [Re: TJP] #1596663
03/22/14 05:22 PM
03/22/14 05:22 PM
PA
PA
Ok, I thought it didn't also but wasn't sure. Thanks for the info.
Re: Turn signals not working properly [Re: 70HemiGTX] #1596664
03/22/14 06:32 PM
03/22/14 06:32 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
The old style flashers use a bi-metallic spring with contact points. when cool, the spring closes the points.
When you complete the circuit via the TS switch the current flows through the spring to the contact points. The current passing through the spring heats it up and causes it to spring open (TINK) and breaks the current flow through the contacts When the spring cools it closes the points again (tink) and re establishes current flow.
As previously mentioned you most likely have a bad flasher
Note that using LED lights will not draw enough current for the old style flashers to work.
Also note that a burn out bulb or bad ground can also cause problems as either can affect the amount of current passing through the spring thereby altering its "timing"
Re: Turn signals not working properly [Re: TJP] #2750259
03/08/20 08:32 PM
03/08/20 08:32 PM
Rancho Cordova, CA
Exit1965 Offline
Exit1965  Offline
Rancho Cordova, CA
Man I wish i had found this sooner. Just went through this on my 67 Dart, first thing I replaced the flasher near the fusebox thinking that it was for the turn signal. When that didn't work I pulled the wheel and replaced the switch ($60), no change obviously. Then I read here that the flasher I needed to replace was near the glovebox. Plugged the new flasher in there and viola, all work.
