Painting dash frame and steering column. What paint? #1596476
03/22/14 02:32 AM
03/22/14 02:32 AM
Tri-Cities, Washington
V
VITC_GTX Offline OP
VITC_GTX  Offline OP
V
Painting the dash frame and steering column in my '71 Satellite.
Do the column and dash use the same paint?
I just can't ask for "flat black". Is there some kind of description that I should use to ask for the paint?
I've heard of SEM interior paint????
Re: Painting dash frame and steering column. What paint? [Re: VITC_GTX] #1596477
03/22/14 03:00 AM
03/22/14 03:00 AM
Spokane Valley, WA
Big Bad Bee Offline
Big Bad Bee  Offline
Spokane Valley, WA
Hey Van,
I used SEM on the bee. Painted the plastic and the steering column with it. I've used SEM in a spray bomb and also custom mixed in the can. If you apply it with a detail gun you won't be sorry. it flows great. SEM makes a surface prep for plastic surfaces. For metal you can shoot it right over primer. SEM makes primer in a spray bomb too. the sheen looks really nice. I'm don't know if it's accurate but it's a like an egg shell to semi gloss look. The stuff flows like a dream and is really tough. Buy yourself a can of the black interior paint and play around with it.
I’m listening.
Re: Painting dash frame and steering column. What paint? [Re: VITC_GTX] #1596478
03/22/14 03:04 AM
03/22/14 03:04 AM
Seattle, WA.
E
edp Offline
edp  Offline
E
Seattle, WA.
SEM hot rod black - catalyzed matte finish, looks awesome. If you only want to bomb can it then buy SEM color coat products - single stage spray paint, still pretty good stuff.
the dash pad is SEM colorcoat, the dash frame and all metal is Hot Rod Black
Re: Painting dash frame and steering column. What paint? [Re: VITC_GTX] #1596479
03/22/14 03:06 AM
03/22/14 03:06 AM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
See factory service manual, page 12-9 here:
http://www.mymopar.com/index.php?pid=109
It is a bit misleading in that the interior uses both some exterior paint and some non-exterior paint. Just know that some exterior paint is used in the interior. All the parts are listed for each gloss.
Re: Painting dash frame and steering column. What paint? [Re: Big Bad Bee] #1596480
03/22/14 03:59 AM
03/22/14 03:59 AM
V
VITC_GTX Offline OP
VITC_GTX  Offline OP
V
Hey Lindy.
Thanks for the info!
Van
Re: Painting dash frame and steering column. What paint? [Re: edp] #1596481
03/22/14 04:01 AM
03/22/14 04:01 AM
V
VITC_GTX Offline OP
VITC_GTX  Offline OP
V
Wow edp, looks awesome!
How about we just trade dashes. I get a great looking dash quickly and you get the opportunity to do it again!! Win/win!!!!
Re: Painting dash frame and steering column. What paint? [Re: kentj340] #1596482
03/22/14 04:02 AM
03/22/14 04:02 AM
V
VITC_GTX Offline OP
VITC_GTX  Offline OP
V
Thanks for the link. I appreciate it!
Thanks to all.
Re: Painting dash frame and steering column. What paint? [Re: VITC_GTX] #1596483
03/22/14 09:17 AM
03/22/14 09:17 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
I used what is in the FSM, It's DIA 9288? lacquer and matched my original dashes perfectly. Can still get lacquer around here.
It's a wonderful paint, I used it on all my interior pieces on my 71 and many other things. It has just the right finish.
Re: Painting dash frame and steering column. What paint? [Re: VITC_GTX] #1596484
03/22/14 10:51 AM
03/22/14 10:51 AM
Seattle, WA.
E
edp Offline
edp  Offline
E
Seattle, WA.
No problem, just bring that orange beast in your Avatar & we'll swap straight across !
Re: Painting dash frame and steering column. What paint? [Re: VITC_GTX] #1596485
03/22/14 04:22 PM
03/22/14 04:22 PM
Washington State
70Duster440 Offline
70Duster440  Offline
Washington State
At the time I did my dash frame, column, interior door, and metal sail panels with Sikkens Ralley Black - also a two part that looks like the hot rod black (low or semi-gloss). I just didn't care for the factory suede which is quite flat. Not quite as glossy as it looks in the flash photos below. BUT, if authenticity is important, then stick with the suedes.
And I love SEM Landau Black in a rattle can for the plastics.
Re: Painting dash frame and steering column. What paint? [Re: VITC_GTX] #1596486
03/22/14 05:30 PM
03/22/14 05:30 PM
Morristown Tn.
71birdJ68 Online content
71birdJ68  Online Content
Morristown Tn.
The dash frame is a swede texture, and the column I think is smoother.
PM sent.
Re: Painting dash frame and steering column. What paint? [Re: VITC_GTX] #1596487
03/24/14 10:44 AM
03/24/14 10:44 AM
Nashville, TN
MOPARMIKE69 Offline
MOPARMIKE69  Offline
Nashville, TN
Do you just want it to look nice and finished or do you want it to look factory original. If just nice all the paints listed will work. If you want it original, only one paint will work. Very hard to come by but the difference is visable. Here is the original suede laquer paint used by the factory on the dash and steering column.
69 Road Runner vert
69 GTX hard top
70 Road Runner 4 speed
70 Hemi Cuda vert
Re: Painting dash frame and steering column. What paint? [Re: VITC_GTX] #1596488
03/24/14 11:27 AM
03/24/14 11:27 AM
Spokane Washington
P
pro-streeter Offline
P
Spokane Washington
SEM is the product I use. Start by prepping the surface with scotch brite or if possible strip it. Use Wax and Grease remover etch prime all bare metal then apply SEM 38363 Sand free to promote adhesion. Top coat with SEM 15013 Landau Black. I have used this process 2 times now and the result is great. Try a test piece before you do the whole dash so you have an idea of the final finish. I have taken mine to several shows and have had rave reviews of the final product. SEM product lays out soooo nice.
Re: Painting dash frame and steering column. What paint? [Re: VITC_GTX] #1596489
03/24/14 01:22 PM
03/24/14 01:22 PM
Omaha Ne
TJP Online content
TJP  Online Content
Omaha Ne
Re: Painting dash frame and steering column. What paint? [Re: VITC_GTX] #1596490
03/24/14 03:14 PM
03/24/14 03:14 PM
GMP440 Offline
GMP440  Offline
Did a restoration on a 68' Roadrunner 1 1/2 years ago. We used Rustleum satin black reduced with acetone on the dash frame and steering column. Came out great, still looks great.
Re: Painting dash frame and steering column. What paint? [Re: GMP440] #1596491
03/25/14 04:13 PM
03/25/14 04:13 PM
Rust Belt, SW PA
Silver70 Offline
Silver70  Offline
Rust Belt, SW PA
I use sem in the spray can unless it's an all out resto. I used a can on a 69 gtx that still had the original dash paint, while touching it up, it's almost an exact match.
68 Road Runner, 69 Belvedere, 71 Challenger Vert
340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z
66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
Re: Painting dash frame and steering column. What paint? [Re: VITC_GTX] #1596492
03/25/14 04:52 PM
03/25/14 04:52 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
I've used semi-flat not semi-gloss I think they also call it satin.
Coming soon!!!!
Re: Painting dash frame and steering column. What paint? [Re: Silver70] #1596493
03/29/14 07:53 PM
03/29/14 07:53 PM
Partridge, KY
Hoop Offline
Hoop  Offline
Partridge, KY
I used satin on my column, looks good, but Witch one looks more like factory semi-gloss or satin?
Re: Painting dash frame and steering column. What paint? [Re: Hoop] #1596494
03/30/14 01:27 AM
03/30/14 01:27 AM
mopar346 Offline
Let me tell ya about fat chicks!
mopar346  Offline
PPG DP90 in my AAR as recommended by Batalson. Looks awesome.
Careful, your character's showing!
