Need 904/ 727 shaft selector seal pn #1595799
03/20/14 04:14 PM
03/20/14 04:14 PM
Franklin CT
syleng1 Offline OP
syleng1  Offline OP
Franklin CT
On my 66, with a 904-6cyl trans when the car sits (converter drains back) my shift selector seal is leaking. Since I am going to pull the valve body to do this seal, I want to replace the throttle shaft seal as well.
Does anybody have a good part number for these I can get from Napa or Advanced /ect?
Thanks, Joe
Re: Need 904/ 727 shaft selector seal pn [Re: syleng1] #1595800
03/20/14 04:31 PM
03/20/14 04:31 PM
Washington State
70Duster440 Offline
70Duster440  Offline
Washington State
Don't know about local retailers, but if you go to a place like Bulkpart.com you can find the seals your need:
http://www.bulkpart.com/Merchant2/merchant.mvc?Screen=CTGY&Store_Code=2&Category_Code=A904
Throttle seal: 12349
Manual shift: 22072A
Re: Need 904/ 727 shaft selector seal pn [Re: syleng1] #1595801
03/20/14 06:54 PM
03/20/14 06:54 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Factory P/N is 2466842, the dealer should have it.
Re: Need 904/ 727 shaft selector seal pn [Re: syleng1] #1595802
03/20/14 07:04 PM
03/20/14 07:04 PM
Florida STAYcation
dOoC Offline
The village idiot's idiot
dOoC  Offline
Florida STAYcation
Thanks, Joe
BE SURE to clean up both shafts of rust and corrosion OR that will chew-up the new seals.
Re: Need 904/ 727 shaft selector seal pn [Re: 70Duster440] #1595803
03/20/14 11:30 PM
03/20/14 11:30 PM
Franklin CT
syleng1 Offline OP
syleng1  Offline OP
Franklin CT
I appreciate all the help. I checked with the commercial guy I buy from for my company and her is getting the above part numbers in for me tomorrow via UPS. The cost is like $10. Not bad as I hate to wait for parts like this to come in.
Thank you again for the help and the idea about polishing the shaft while the valve body is out.
Joe
Re: Need 904/ 727 shaft selector seal pn [Re: syleng1] #1595804
03/21/14 12:12 AM
03/21/14 12:12 AM
GEORGIA
barracuda7199 Offline
GEORGIA
Rock auto has them for .94!! I checked the local parts houses before and they want $8 bucks for the same seal!! Call Oriellys and check the price! While you have them on the phone price a front pump seal! Last time I did it was around $25!! That's robbery!
Re: Need 904/ 727 shaft selector seal pn [Re: barracuda7199] #1595805
03/21/14 12:42 AM
03/21/14 12:42 AM
Franklin CT
syleng1 Offline OP
syleng1  Offline OP
Franklin CT
Last summer I replaced all the seals but you guessed it the shifter seals. I am ok with places like Rock Auto but I hate to wait and honestly $7.00 more and I have it tomorrow is not bad. The $.98 is cheaper but with shipping it will be about $6.00 when I priced it. Plus if it is wrong... The guy at the counter is easy to send it back. Time is everything with me as I have limited chances to work on the car. It sat on the trailer all winter and there is a puddle underneath now. I hate to park it on the drive way with a seal leak.
Thanks for the input!
Joe
Re: Need 904/ 727 shaft selector seal pn [Re: syleng1] #1595806
03/21/14 01:44 AM
03/21/14 01:44 AM
I got about 20 of em in a baggie. If you can send metal in an envelope I can send you one
