Re: Need 904/ 727 shaft selector seal pn
[Re: syleng1]
#1595801
03/20/14 06:54 PM
03/20/14 06:54 PM
Posts: 25,894 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Factory P/N is 2466842, the dealer should have it.
[Re: syleng1]
#1595802
03/20/14 07:04 PM
03/20/14 07:04 PM
Posts: 30,456 Florida STAYcation
dOoC
The village idiot's idiot
Florida STAYcation
On my 66, with a 904-6cyl trans when the car sits (converter drains back) my shift selector seal is leaking. Since I am going to pull the valve body to do this seal, I want to replace the throttle shaft seal as well.
Does anybody have a good part number for these I can get from Napa or Advanced /ect?
Thanks, Joe
BE SURE to clean up both shafts of rust and corrosion OR that will chew-up the new seals.
[Re: 70Duster440]
#1595803
03/20/14 11:30 PM
03/20/14 11:30 PM
Posts: 765 Franklin CT
syleng1
Franklin CT
Don't know about local retailers, but if you go to a place like Bulkpart.com you can find the seals your need:
http://www.bulkpart.com/Merchant2/merchant.mvc?Screen=CTGY&Store_Code=2&Category_Code=A904
Throttle seal: 12349
Manual shift: 22072A
I appreciate all the help. I checked with the commercial guy I buy from for my company and her is getting the above part numbers in for me tomorrow via UPS. The cost is like $10. Not bad as I hate to wait for parts like this to come in. Thank you again for the help and the idea about polishing the shaft while the valve body is out.
Joe
[Re: barracuda7199]
#1595805
03/21/14 12:42 AM
03/21/14 12:42 AM
syleng1
Franklin CT
Rock auto has them for .94!! I checked the local parts houses before and they want $8 bucks for the same seal!! Call Oriellys and check the price! While you have them on the phone price a front pump seal! Last time I did it was around $25!! That's robbery!
Last summer I replaced all the seals but you guessed it the shifter seals. I am ok with places like Rock Auto but I hate to wait and honestly $7.00 more and I have it tomorrow is not bad. The $.98 is cheaper but with shipping it will be about $6.00 when I priced it. Plus if it is wrong... The guy at the counter is easy to send it back. Time is everything with me as I have limited chances to work on the car. It sat on the trailer all winter and there is a puddle underneath now. I hate to park it on the drive way with a seal leak. Thanks for the input! Joe
[Re: syleng1]
#1595806
03/21/14 01:44 AM
03/21/14 01:44 AM
RapidRobert
I got about 20 of em in a baggie. If you can send metal in an envelope I can send you one
