Clamp to stop distributor from hopping #1595739
03/20/14 02:25 PM
03/20/14 02:25 PM
San Diego
64dartsb Offline OP
64dartsb  Offline OP
San Diego
You know what I mean right? It's a 360. And I need that little clamp thing that goes on the distributor shaft so that it don't hop around down there.... You guys know where I can get one?
if your dreaming of your car then it's your dream car....
Re: Clamp to stop distributor from hopping [Re: 64dartsb] #1595740
03/20/14 02:58 PM
03/20/14 02:58 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Tractor supply 1/2" shaft collar.
http://www.tractorsupply.com/en/store/countylinereg%3B-set-collar-1-2-in-dia-pack-of-2
hardware stores electric motor supply places and so on.
I would tap another set screw in and use red loctite on them!
Hughes engines sells them.
http://www.hughesengines.com/Index/produ...mp;partid=25200
Re: Clamp to stop distributor from hopping [Re: 64dartsb] #1595741
03/20/14 04:29 PM
03/20/14 04:29 PM
While you're at it drive out the roll pin & take off the OE collar & add some 1/2" ID shims/flat washers ( www.speedwaymotors.com has a cheap set of em) to reduce the end play to .005" then replace the collar and drive the roll pin back in. Also see how much rotational play you have in the lower tang/intergear interface by lightly twisting the rotor back & forth, not hard enough to get into the springs. Peen the end of the tang to expand it slightly to reduce that. 3 deg of slop there means the ign can adv/retard 6 crank deg, which is way way too much
Re: Clamp to stop distributor from hopping [Re: RapidRobert] #1595742
03/20/14 06:28 PM
03/20/14 06:28 PM
petaluma,ca. u.s.a.
west Offline
west  Offline
petaluma,ca. u.s.a.
I didn't know about these.
On my 360 with an air gap I have to put the intake on before the dist. so I wouldn't be able to use it and still get may rear intake bolt in past the dist.
Re: Clamp to stop distributor from hopping [Re: west] #1595743
03/20/14 06:37 PM
03/20/14 06:37 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
Looking at the picture in the link, I can't tell what these collars do. Can someone explain it?
Re: Clamp to stop distributor from hopping [Re: burdar] #1595744
03/20/14 07:23 PM
03/20/14 07:23 PM
San Diego
64dartsb Offline OP
64dartsb  Offline OP
San Diego
You put it on the distributor and it stops the gear from hopping I think....
Thanks dudes
Re: Clamp to stop distributor from hopping [Re: 64dartsb] #1595745
03/20/14 07:31 PM
03/20/14 07:31 PM
San Diego
64dartsb Offline OP
64dartsb  Offline OP
San Diego
Just ordered it from Hughes and a new shaft/gear we'll see if that helps
Re: Clamp to stop distributor from hopping [Re: burdar] #1595746
03/20/14 07:42 PM
03/20/14 07:42 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
they help stop the dizzy shaft from moving up and down. helps to create a more accurate spark on the inside of the cap. lightly pull up on your rotor and you'll see if your dizzy is older.
Re: Clamp to stop distributor from hopping [Re: mikemee1331] #1595747
03/20/14 09:55 PM
03/20/14 09:55 PM
Slip the collar on with the tang protruding out the bottom slightly with the setscrew snug then install the dist which'll slide the collar up just the right amount & no more then remove the dist being carefull not to disturb the collars' vertical position on the shaft then tighten the setscrew appropriately & use some loctite then reinstall it in the eng. My prior post was on the OE collar higher up on the shaft with the roll pin thru it
Re: Clamp to stop distributor from hopping [Re: RapidRobert] #1595748
03/20/14 10:28 PM
03/20/14 10:28 PM
petaluma,ca. u.s.a.
west Offline
west  Offline
petaluma,ca. u.s.a.
I thought of that today in the car and wanted to edit my post .
thanks.
Re: Clamp to stop distributor from hopping [Re: RapidRobert] #1595749
03/21/14 12:17 AM
03/21/14 12:17 AM
WI
Dcuda69 Offline
Dcuda69  Offline
WI
Exactly how I did mine in my BB...timing is rock steady now!Been in there a few years.I was on the verge of spending big $$ on a MSD setup in an effort to stabilize my timing. It's always nice to come across a cheap fix for a change.
Re: Clamp to stop distributor from hopping [Re: Dcuda69] #1595750
03/21/14 11:00 AM
03/21/14 11:00 AM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
So this collar keeps the oil pump drive gear from bouncing? The plastic collar higher up on the distributor holds the distributor shaft from bouncing.
Re: Clamp to stop distributor from hopping [Re: burdar] #1595751
03/21/14 12:18 PM
03/21/14 12:18 PM
Ohio
jlatessa Offline
jlatessa  Offline
Ohio
So this is effective on big blocks too?
Thanks...Joe
Re: Clamp to stop distributor from hopping [Re: burdar] #1595752
03/21/14 12:24 PM
03/21/14 12:24 PM
I ain't sure if the intergear/shaft wants to come up but what works for me is (1) to remove the roll pin/collar & add shims to reduce that axial play to .005". (2) add the aftermarket collar down below (3) then if the rotational play on the rotor is anything more than a c hair I either peen the lower tang or I have even built up the recess in the top of the intergear with weld then dremel it out for a good fit. A pain but blueprinting is never easy & all the minor details add up & keeps me on top of the chebrolet boys & maintains Mopar superiority. Next on the check list is possibly adding a shim on the top shaft under the clip to reduce that axial play and to drill/tap the outer ends of the slot plate so I can add a setscrew (one on each end)) to be able to adj total thru the vac can window & do Nacho's trick of bending the magnet so the vac adv changes the reluctor gap as little as possible (as is there is too much change) & I'm considering adding one of those 60's spouts on the side so you can add drops of oil to lube the bushings tho they do seem to get lubed somehow adequately but I do reduce the play right there at that opening where the oil vapors enter to .005" by adding shims above the OE collar/roll pin. EDIT Big blocks, yes absolutely
Re: Clamp to stop distributor from hopping [Re: RapidRobert] #1595753
03/21/14 01:02 PM
03/21/14 01:02 PM
Sac, CA
mopowers Offline
mopowers  Offline
Sac, CA
When installing one of these collars, is it best to leave it tight against the gear, or leave a few thousanths for clearance??
Re: Clamp to stop distributor from hopping [Re: mopowers] #1595754
03/21/14 05:27 PM
03/21/14 05:27 PM
tight
Re: Clamp to stop distributor from hopping [Re: RapidRobert] #1595755
03/21/14 05:49 PM
03/21/14 05:49 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
The picture in the above link shows a .010 feeler gauge between the collar and the gear.
Re: Clamp to stop distributor from hopping [Re: burdar] #1595756
03/21/14 06:15 PM
03/21/14 06:15 PM
Yes & Dave Hughes knows way more than I do
Re: Clamp to stop distributor from hopping [Re: RapidRobert] #1595757
03/21/14 09:11 PM
03/21/14 09:11 PM
Valencia, España
NachoRT74 Online content
NachoRT74  Online Content
Valencia, España
I simply used a piece of leather into the driveshaft notch. This will absorv also impact and won't give you lot of pressure to the block bushing.
some ppl have uses garden hoses to the dist shaft to, like a preload spacer on 489s 8.75 axles.
Re: Clamp to stop distributor from hopping [Re: RapidRobert] #1595758
03/24/14 02:29 PM
03/24/14 02:29 PM
USA
3
360view Offline
Moparts resident spammer
360view  Offline
3
USA
Gimme a guess as to whether this is important on a
1992-2001 Magnum style V8
where the distributor is still used
but notches in the flexplate triggers the CPS to fire the coil?
Can the Magnum style distributor rotor to post clearances
be so far off from this "Hopping" that
"realworld" ignition spark initiation
is advanced or retarded?
Can the SMPI fuel injection timing be affected?
Is the hopping worst at high RPM and load?
