Clamp to stop distributor from hopping
#1595739
03/20/14 02:25 PM
03/20/14 02:25 PM
Posts: 363 San Diego
64dartsb
San Diego
You know what I mean right? It's a 360. And I need that little clamp thing that goes on the distributor shaft so that it don't hop around down there.... You guys know where I can get one?
if your dreaming of your car then it's your dream car....
Re: Clamp to stop distributor from hopping
[Re: 64dartsb]
#1595741
03/20/14 04:29 PM
03/20/14 04:29 PM
RapidRobert
While you're at it drive out the roll pin & take off the OE collar & add some 1/2" ID shims/flat washers ( www.speedwaymotors.com has a cheap set of em) to reduce the end play to .005" then replace the collar and drive the roll pin back in. Also see how much rotational play you have in the lower tang/intergear interface by lightly twisting the rotor back & forth, not hard enough to get into the springs. Peen the end of the tang to expand it slightly to reduce that. 3 deg of slop there means the ign can adv/retard 6 crank deg, which is way way too much
[Re: burdar]
#1595744
03/20/14 07:23 PM
03/20/14 07:23 PM
64dartsb
San Diego
You put it on the distributor and it stops the gear from hopping I think....
Thanks dudes
[Re: 64dartsb]
#1595745
03/20/14 07:31 PM
03/20/14 07:31 PM
64dartsb
San Diego
Just ordered it from Hughes and a new shaft/gear we'll see if that helps
[Re: burdar]
#1595746
03/20/14 07:42 PM
03/20/14 07:42 PM
Posts: 4,154 bethlehem pa
mikemee1331
bethlehem pa
Looking at the picture in the link, I can't tell what these collars do. Can someone explain it?
they help stop the dizzy shaft from moving up and down. helps to create a more accurate spark on the inside of the cap. lightly pull up on your rotor and you'll see if your dizzy is older.
[Re: mikemee1331]
#1595747
03/20/14 09:55 PM
03/20/14 09:55 PM
RapidRobert
Slip the collar on with the tang protruding out the bottom slightly with the setscrew snug then install the dist which'll slide the collar up just the right amount & no more then remove the dist being carefull not to disturb the collars' vertical position on the shaft then tighten the setscrew appropriately & use some loctite then reinstall it in the eng. My prior post was on the OE collar higher up on the shaft with the roll pin thru it
[Re: RapidRobert]
#1595748
03/20/14 10:28 PM
03/20/14 10:28 PM
Posts: 4,233 petaluma,ca. u.s.a.
west
petaluma,ca. u.s.a.
I thought of that today in the car and wanted to edit my post . thanks.
[Re: RapidRobert]
#1595749
03/21/14 12:17 AM
03/21/14 12:17 AM
Posts: 4,950 WI
Dcuda69
WI
Exactly how I did mine in my BB...timing is rock steady now!Been in there a few years.I was on the verge of spending big $$ on a MSD setup in an effort to stabilize my timing. It's always nice to come across a cheap fix for a change.
[Re: burdar]
#1595752
03/21/14 12:24 PM
03/21/14 12:24 PM
RapidRobert
I ain't sure if the intergear/shaft wants to come up but what works for me is (1) to remove the roll pin/collar & add shims to reduce that axial play to .005". (2) add the aftermarket collar down below (3) then if the rotational play on the rotor is anything more than a c hair I either peen the lower tang or I have even built up the recess in the top of the intergear with weld then dremel it out for a good fit. A pain but blueprinting is never easy & all the minor details add up & keeps me on top of the chebrolet boys & maintains Mopar superiority. Next on the check list is possibly adding a shim on the top shaft under the clip to reduce that axial play and to drill/tap the outer ends of the slot plate so I can add a setscrew (one on each end)) to be able to adj total thru the vac can window & do Nacho's trick of bending the magnet so the vac adv changes the reluctor gap as little as possible (as is there is too much change) & I'm considering adding one of those 60's spouts on the side so you can add drops of oil to lube the bushings tho they do seem to get lubed somehow adequately but I do reduce the play right there at that opening where the oil vapors enter to .005" by adding shims above the OE collar/roll pin. EDIT Big blocks, yes absolutely
[Re: burdar]
#1595756
03/21/14 06:15 PM
03/21/14 06:15 PM
RapidRobert
Yes & Dave Hughes knows way more than I do
[Re: RapidRobert]
#1595757
03/21/14 09:11 PM
03/21/14 09:11 PM
Posts: 6,096 Valencia, España
NachoRT74
Valencia, España
I simply used a piece of leather into the driveshaft notch. This will absorv also impact and won't give you lot of pressure to the block bushing.
some ppl have uses garden hoses to the dist shaft to, like a preload spacer on 489s 8.75 axles.
