Stock LOOKING 383 needs more HP #159569
12/01/08 01:46 PM
12/01/08 01:46 PM
Ball Ground GA
TrueTripleX Offline OP
Ball Ground GA
OK motor experts, I need some help on a 68 Charger. I want to keep the 383 LOOKING stock, but want more HP. What combination of components can someone recommend to maximize HP. I would like something near 475 (and pleasse stop laughing). What can I do to get the most and still keep the motor LOOKING stock (no high rise intake, etc.). Thanks
Re: Stock LOOKING 383 needs more HP [Re: TrueTripleX] #159570
12/01/08 02:08 PM
12/01/08 02:08 PM
CT
GTX MATT Offline
GTX MATT  Offline
CT
496 stroker kit
440 Source Stealth heads or a good porting to your heads
DC .528
9.5:1 compression
850 CFM Edelbrock or Holley a minimum, if you want the stock Carter look its going to cost you some power but your best choice would be to find a 750 or a Carter that came off of a 440HP engine.
This would probably get you there.
If you dont want to stroke it youre probably SOL, 450 might be doable but 475 is a stretch on the street.
Re: Stock LOOKING 383 needs more HP [Re: GTX MATT] #159571
12/01/08 02:17 PM
12/01/08 02:17 PM
Cleveland
sunroofgtx Offline
sunroofgtx  Offline
Cleveland
Add a cleaned up, painted Street Dominator intake to match the stroker assembly. Balanced. Thrown on an engine dyno to tweak. Oh ya, some good ignition components.
Join the quickest team in motorsports. Team FireCore. CustomWiresets.com
Re: Stock LOOKING 383 needs more HP [Re: TrueTripleX] #159572
12/01/08 02:24 PM
12/01/08 02:24 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
First question: HOW MUCH MONEY DO YOU HAVE TO SPEND???
Re: Stock LOOKING 383 needs more HP [Re: BradH] #159573
12/01/08 02:33 PM
12/01/08 02:33 PM
IL
71383beep Offline
71383beep  Offline
IL
I agree with stroking. You'll need it for that kind of hp.
I would say aftermarket heads, stroked to a minimum 426 or larger, SD intake and an 850 Demon or Holley.
make sure your compression is no less than 10:1 too.
the SD intake is short and looks good when painted you can also keep the stock aircleaner.
You'll probable NEED to have headers though which obviously aren't stock.
IMHO it is easier to do this with a stroked 400 and externally they look the same.
I am running 400 with mine and I can probably squeeze another 10 to 20 with easier mods like cam and heads mainly. But I doubt I could see 475 without pulling more CI's.
'73 GK6 Challenger Rallye - 340 4-Speed
Re: Stock LOOKING 383 needs more HP [Re: 71383beep] #159574
12/01/08 05:40 PM
12/01/08 05:40 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
Agreed with all above, and if you're still running say, the 323 gears, it will still SCREAM!
Re: Stock LOOKING 383 needs more HP [Re: buildanother] #159575
12/01/08 06:07 PM
12/01/08 06:07 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
If you want it to look stock and make any power, you will have to junk your stock manifolds. Can you live with headers? If not, you will NEED a set of HP manifolds. Holley SD intake is a good one, if you grind off the lettering and paint it, it would pass for stock to the casual observer(especially once it's tucked under your air cleaner). 528 cam would be a good choice IMO.
Re: Stock LOOKING 383 needs more HP [Re: TrueTripleX] #159576
12/01/08 08:32 PM
12/01/08 08:32 PM
God's Country Maryland
GODSCOUNTRY340 Offline
A '68 383 came with 906 heads. Get them off there and find a set of '67 915 heads, these are closed chambered and will raise your compression another point. Have them ported and install 2.14/ 1.81 valves. Be sure to clearance the tops of the cylinders where the valves open. You can do this yourself by using an old head gasket as a guide. Chamfer the bore out to match the gasket but only go 1/4" deep into the cylinder to stay above where the rings travel. Stealth heads don't look stock, as soon as you look in the area of the heat crossover at the center of the intake manifold, you're busted. Go with a solid lift cam and as stated above, find an aluminum intake and paint it. A 3800 stall converter will help too.
Re: Stock LOOKING 383 needs more HP [Re: TrueTripleX] #159577
12/01/08 08:49 PM
12/01/08 08:49 PM
Chesapeake Va
BobK Offline
BobK  Offline
Chesapeake Va
How's this for relatively stock looking? Stroked 400 (now 470 ) Stealth heads, with port work, Edelbrock intake,
1964 Plymouth Fury x 2
1964 Plymouth Sport Fury
Re: Stock LOOKING 383 needs more HP [Re: BobK] #159578
12/01/08 09:44 PM
12/01/08 09:44 PM
Manitoba, Canada
Manitoba, Canada
Looks very stockish to me. Take a spare stock air cleaner, graft a drop-base onto it and the average car guy would not know the difference? Would it hold up to the toughest judges, of course not. But it would fool most regular joes.
Re: Stock LOOKING 383 needs more HP [Re: DaytonaTurbo] #159579
12/01/08 10:37 PM
12/01/08 10:37 PM
CT
GTX MATT Offline
GTX MATT  Offline
CT
I dont think hes going to want the SD, I like them but I would never mistake one for stock myself. If youve got the air grabber style air cleaner it hides alot though. I think if you go with the big stroker kit to the 499 you can make your power with the .528 and a well ported set of 906s with the manifolds and stock intake as long as you give it enough CFM with something like the 850 AVS Edelbrock sells, an AVS Edelbrock on a MoPar is generally considered a stock replacement type deal, in fact any carb replacement on any MoPar is something I never think of as a true modification, its almost a tuning item. I like the Carters but they dont really make anything big enough for even a mild 440.
If you run manifolds go with the .528 if you use something off the shelf, its one of the best DC cams and it works well with manifolds from what I hear from alot of guys who know theyre stuff. My only big block had manifolds on it but it was a 440, different case. I like the look though and when I finally get a big block in the Satellite I'd be tempted to run them. Headers are just worth so much power though, on a stock 383 youre looking at 25+ horse for a decent set of cheap Hooker or Hedmans.
Re: Stock LOOKING 383 needs more HP [Re: BradH] #159580
12/01/08 11:08 PM
12/01/08 11:08 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Re: Stock LOOKING 383 needs more HP [Re: BSB67] #159581
12/01/08 11:22 PM
12/01/08 11:22 PM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
TO heck with all of these expensive hard parts just but a plate kit and hit the big red button.
Re: Stock LOOKING 383 needs more HP [Re: Jeremiah] #159582
12/02/08 11:08 AM
12/02/08 11:08 AM
IL
71383beep Offline
71383beep  Offline
IL
Assuming this is a stock worn out 383 I would not recommend just nitrousing it. Good Nitrous motors are built to handle it with better bottom ends and such.
It'll work for the short term, but I would not bet on the motor staying together for too long.
Re: Stock LOOKING 383 needs more HP [Re: 71383beep] #159583
12/02/08 01:26 PM
12/02/08 01:26 PM
Columbia, CT
moper Offline
moper  Offline
Columbia, CT
well it doesnt look stock. but I ran 175hp plate on a stock 2bbl lower end in my C body for a couple years. Had a blast in it too... If I could just find a green 4dr Newport with green interior, black top, and AC. I miss the old barge.
more to the point, 475 from a 383 is very hard to do in stock apprearing form. I would start with a 400 and go larger stroke as mentionned. A 470 can make 475 pretty easy with stock looking stuff. Not stock looking or sounding, but stock looking.
