Bypassing ballast ?
#1595641
03/20/14 02:55 AM
03/20/14 02:55 AM
Posts: 27,421 Balt. Md
383man
Balt. Md
I am curious if anyone has run the Mopar ign with the ballast resistor bypassed ? I know one of the Mopar mags said to do it as I never had since I felt it would maybe overheat and burn out the coil or Mopar ECU. Course you will have a hotter spark. So since one of mags was telling you do it I was wondering if anyone has and what the results were ? And if anyone even raced the car with it bypassed to see how it did ? Thanks , Ron
Re: Bypassing ballast ?
[Re: 383man]
#1595643
03/20/14 10:14 PM
03/20/14 10:14 PM
moparpollack
Lil Herman
Lil Herman
85086
Only when running an MSD box.
[Re: SportF]
#1595647
03/22/14 09:21 AM
03/22/14 09:21 AM
Posts: 52,972 Romeo MI
MR_P_BODY
Well, here is a curious question, why would running 12 VDC through a coil with points burn it up when you could use the same coil with MSD and run a hundred volts through it and not burn it up?
I dont know where you get a hundred volts... but with a coil designed for 12 volts the wire size inside is larger... a coil thats designed for lesser voltage has thinner wire size... sure it can take it for a while but they do burn out... I have done it myself and it finally did burn out... I had burn out the ballast on one of my cars so to get home I jumped the ballast but forgot about it till the coil quit
[Re: SportF]
#1595649
03/22/14 12:17 PM
03/22/14 12:17 PM
MR_P_BODY
I have no doubt that coils have burnt out, but the real question is why. To get more spark out of a coil you have to put more in. And to quote from MSD install instructions, talking about the primary coil wire connections: "During cranking or while the engine is running, very high voltage will be present and no test equipment should be connected." I believe it was my son whom hooked up an inductive pickup at the + coil and used an "O" scope to look at the voltage and it was 200+. But that number may be wrong, but it was WAY higher than 12VDC. Just a point of curiosity really, I have studied magnetism probably more than most, but you could study a small portion of magnetism for a lifetime, and still learn. It is a fascinating phenomenon.
Yes the 2 windings do create a higher voltage.. I assumed you were talking the input voltage... yeah I liked playing with magnetism a few years back but havent played with it since(in a testing mode)
[Re: SportF]
#1595651
03/22/14 04:42 PM
03/22/14 04:42 PM
383man
Balt. Md
I have read that MSD units can pulse about 300 volts to the coil primary but the question here is the amps (current flow) that goes thru the coil. Its my understanding that the MSD units will pulse about the 300 volts very fast and even if you have a 1000 volts to the coil pos terminal it will still depend on how long the coil neg side is grounded to figure how many amps flow. 1000 volts at the coil but if no ground no current flow. Of course the more volts without changing ohms means more current flow but as I said the MSD pulses the voltage so fast that it cant be to much more current flow or it could burn something up. I had thought I read in Mopar Action where they said its fine to bybass the ballast and I thought some people said they did it and thats mainly why I am asking. I would not think it would work real long but I never tried it. Ron
[Re: 383man]
#1595653
03/22/14 06:16 PM
03/22/14 06:16 PM
Posts: 10,008 Frostbitefalls MN (Rocky&Bullw...
gregsdart
Bypassing a ballast on the stock system jumps the juice up to 150 percent or there abouts of what it is designed to handle long term. The start circuit has no ballast so it will spark at low voltage in the cold with a weak battery.
[Re: SportF]
#1595655
03/23/14 08:57 AM
03/23/14 08:57 AM
Posts: 159 australia
charger410
australia
Msd ignitions have a inverter power supply which steps 12v up to a regulated 300volts it's then timed with the coil to pulse on for a period of a couple of nano or micro seconds seconds, cant remember which off the top of my head as opposed to fractions of a second with a regular coil points. The combined time the coils on for verses the voltage applied equals the total power consumed by the coil So Msd's ignitions matched with coil puts out heaps higher voltage and current but for a shorter duration
Peter. Australian Charger, alloy block injected 410in, w9 na 9.03@148 leafs 3000lb
1967 barracuda 605 hemi Stage5 millennium 8.2@170
[Re: charger410]
#1595656
03/24/14 12:20 AM
03/24/14 12:20 AM
383man
Balt. Md
Yes that is true. If you look at the coil wireing on an MSD system both the primary coil wires (pos & neg) go to the MSD box. The pos does not come from a ballast like a stock unit as thats so they can control the voltage in the coil primary and out to the ground through the MSD unit. And they can make it multi-spark when they want it to. I was just curious if anyone had run their car with the ballast bypassed on the basic Mopar electronic ign ? My thoughts are the coil or ECU may burn out and I was surprised to see a Mopar mag suggest that but I thought I heard some say they did it. It will give a hotter spark with 12 volts at the coil pos primary terminal with the eng running instead of the 5 to 7 that its gets through the ballast. So I was curious if anyone has done it. Ron
[Re: Diplomat440]
#1595660
03/24/14 01:21 AM
03/24/14 01:21 AM
charger410
australia
The Main output Transistor on your ignition Box will only be rated at 4 amps continuous, so if you bypass the Ballast resistor you'll probably find you might exceed that all thought I've never checked it. A standard coil would be rated around the same current capacity If you were going to bypass the Ballast put an amp gauge, it will have to be able to hold peak readings, on the 12 volt side of coil and that will give you an idea. For a race car you should be able to get away with it but for the street you would be pushing it
