Bypassing ballast ? #1595641
03/20/14 02:55 AM
03/20/14 02:55 AM
Balt. Md
3
383man Offline OP
383man  Offline OP
Balt. Md
I am curious if anyone has run the Mopar ign with the ballast resistor bypassed ? I know one of the Mopar mags said to do it as I never had since I felt it would maybe overheat and burn out the coil or Mopar ECU. Course you will have a hotter spark. So since one of mags was telling you do it I was wondering if anyone has and what the results were ? And if anyone even raced the car with it bypassed to see how it did ? Thanks , Ron
Re: Bypassing ballast ? [Re: 383man] #1595642
03/20/14 10:00 PM
03/20/14 10:00 PM
Minn
SportF Offline
SportF  Offline
Minn
I would bypass mine on a points 65 Plymouth, at the track only. I never noticed any problems, points or coil getting hot. But I don't know if it helped either. It was my understanding that it is just hard on the points, nothing else.
Re: Bypassing ballast ? [Re: 383man] #1595643
03/20/14 10:14 PM
03/20/14 10:14 PM
85086
moparpollack Offline
Lil Herman
Lil Herman
85086
Only when running an MSD box.
Re: Bypassing ballast ? [Re: moparpollack] #1595644
03/20/14 10:23 PM
03/20/14 10:23 PM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
I did on accident once. Switched from msd back to orange box when I sold my duster. Guy I sold it to burned up two coils (at my cost) before I realized I had bypassed it causing the issues.
Re: Bypassing ballast ? [Re: 383man] #1595645
03/20/14 10:28 PM
03/20/14 10:28 PM
Northern Indiana
Dunnuck Racing Offline
Northern Indiana
Here you go Ron. This was a Chrome box with a MSD Blaster 2 with the highest ohm resistor I could find that day versus no resistor.
Not worth risking burning anything up over it.
Keith
Re: Bypassing ballast ? [Re: dizuster] #1595646
03/22/14 09:01 AM
03/22/14 09:01 AM
Minn
SportF Offline
SportF  Offline
Minn
Well, here is a curious question, why would running 12 VDC through a coil with points burn it up when you could use the same coil with MSD and run a hundred volts through it and not burn it up?
Re: Bypassing ballast ? [Re: SportF] #1595647
03/22/14 09:21 AM
03/22/14 09:21 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I dont know where you get a hundred volts... but with
a coil designed for 12 volts the wire size inside
is larger... a coil thats designed for lesser voltage
has thinner wire size... sure it can take it for a
while but they do burn out... I have done it myself
and it finally did burn out... I had burn out the
ballast on one of my cars so to get home I jumped
the ballast but forgot about it till the coil quit
Re: Bypassing ballast ? [Re: MR_P_BODY] #1595648
03/22/14 12:00 PM
03/22/14 12:00 PM
Minn
SportF Offline
SportF  Offline
Minn
I have no doubt that coils have burnt out, but the real question is why. To get more spark out of a coil you have to put more in. And to quote from MSD install instructions, talking about the primary coil wire connections: "During cranking or while the engine is running, very high voltage will be present and no test equipment should be connected."
I believe it was my son whom hooked up an inductive pickup at the + coil and used an "O" scope to look at the voltage and it was 200+.
But that number may be wrong, but it was WAY higher than 12VDC.
Just a point of curiosity really, I have studied magnetism probably more than most, but you could study a small portion of magnetism for a lifetime, and still learn. It is a fascinating phenomenon.
Re: Bypassing ballast ? [Re: SportF] #1595649
03/22/14 12:17 PM
03/22/14 12:17 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Yes the 2 windings do create a higher voltage.. I assumed
you were talking the input voltage... yeah I liked
playing with magnetism a few years back but havent
played with it since(in a testing mode)
Re: Bypassing ballast ? [Re: MR_P_BODY] #1595650
03/22/14 01:09 PM
03/22/14 01:09 PM
Minn
SportF Offline
SportF  Offline
Minn
Well, actually the 200VDC I am talking about was the input voltage at the + connection. I actually remember a 400+ number as well, but whatever it was, it was huge!
Re: Bypassing ballast ? [Re: SportF] #1595651
03/22/14 04:42 PM
03/22/14 04:42 PM
Balt. Md
3
383man Offline OP
383man  Offline OP
Balt. Md
I have read that MSD units can pulse about 300 volts to the coil primary but the question here is the amps (current flow) that goes thru the coil. Its my understanding that the MSD units will pulse about the 300 volts very fast and even if you have a 1000 volts to the coil pos terminal it will still depend on how long the coil neg side is grounded to figure how many amps flow. 1000 volts at the coil but if no ground no current flow. Of course the more volts without changing ohms means more current flow but as I said the MSD pulses the voltage so fast that it cant be to much more current flow or it could burn something up.
I had thought I read in Mopar Action where they said its fine to bybass the ballast and I thought some people said they did it and thats mainly why I am asking. I would not think it would work real long but I never tried it. Ron
Re: Bypassing ballast ? [Re: 383man] #1595652
03/22/14 05:33 PM
03/22/14 05:33 PM
Wichita
GY3 Online content
GY3  Online Content
Wichita
Pretty sure it was Mopar Muscle.
I would never do it with a stock ecu but it's bypassed in my '63 with the MSD 6AL!
Re: Bypassing ballast ? [Re: 383man] #1595653
03/22/14 06:16 PM
03/22/14 06:16 PM
gregsdart Offline
gregsdart  Offline
Bypassing a ballast on the stock system jumps the juice up to 150 percent or there abouts of what it is designed to handle long term. The start circuit has no ballast so it will spark at low voltage in the cold with a weak battery.
Re: Bypassing ballast ? [Re: 383man] #1595654
03/22/14 09:19 PM
03/22/14 09:19 PM
Minn
SportF Offline
SportF  Offline
Minn
Current and volts is really power. And we all would have to admit by simply looking at a stock spark and an MSD spark that there is a heck of lot more power coming out of that coil with the MSD, eh?
Re: Bypassing ballast ? [Re: SportF] #1595655
03/23/14 08:57 AM
03/23/14 08:57 AM
australia
charger410 Offline
charger410  Offline
australia
Msd ignitions have a inverter power supply which steps 12v up to a regulated 300volts it's then timed with the coil to pulse on for a period of a couple of nano or micro seconds seconds, cant remember which off the top of my head as opposed to fractions of a second with a regular coil points.
The combined time the coils on for verses the voltage applied equals the total power consumed by the coil
So Msd's ignitions matched with coil puts out heaps higher voltage and current but for a shorter duration
Peter. Australian Charger, alloy block injected 410in, w9 na 9.03@148 leafs 3000lb
1967 barracuda 605 hemi Stage5 millennium 8.2@170
Re: Bypassing ballast ? [Re: charger410] #1595656
03/24/14 12:20 AM
03/24/14 12:20 AM
Balt. Md
3
383man Offline OP
383man  Offline OP
Balt. Md
Yes that is true. If you look at the coil wireing on an MSD system both the primary coil wires (pos & neg) go to the MSD box. The pos does not come from a ballast like a stock unit as thats so they can control the voltage in the coil primary and out to the ground through the MSD unit. And they can make it multi-spark when they want it to. I was just curious if anyone had run their car with the ballast bypassed on the basic Mopar electronic ign ? My thoughts are the coil or ECU may burn out and I was surprised to see a Mopar mag suggest that but I thought I heard some say they did it. It will give a hotter spark with 12 volts at the coil pos primary terminal with the eng running instead of the 5 to 7 that its gets through the ballast. So I was curious if anyone has done it. Ron
Re: Bypassing ballast ? [Re: SportF] #1595657
03/24/14 12:31 AM
03/24/14 12:31 AM
Balt. Md
3
383man Offline OP
383man  Offline OP
Balt. Md
When you think about it most coils in the standard ign with a dist have the coils primary and secondary windings hooked together at some point. Most I have seen hook together right as the pos primary wire goes into the coil. They join there on many and then the primary winding goes thhrough its windings on the outside of the secondary windings and then the primary wire goes out the neg coil terminal. The secondary goes through its windings inside of the primary windings and then to the center of the coil tower to fire the plugs. And since the primary are hooked at one point and the secondary windings generate over 20,000 volts it does not seem to far fetched to figure the primary winding volts to read higher then the 12 volts when the secondary winding is fireing the plug. Some of the high voltage may bleed to the primary winding and that may be why your son saw over 200 volts with the eng running at the primary coil pos terminal. Now of course not all coils hook the primary and secondary winding at any point like distibutor less ign with coil packs. On them both ends of the secondary windings go to a plug and does not hook to the primary winding anywhere. Ron
Re: Bypassing ballast ? [Re: 383man] #1595658
03/24/14 12:39 AM
03/24/14 12:39 AM
mt. pleasant, PA
Diplomat440 Offline
Diplomat440  Offline
mt. pleasant, PA
I've been wondering the same thing.
Thought about trying it and just keeping a spare coil in the car but I figured the ecu would be safe since its power doesn't run thru the ballast.
Re: Bypassing ballast ? [Re: Diplomat440] #1595659
03/24/14 01:16 AM
03/24/14 01:16 AM
North Dakota
Azzkikrcuda Offline
Azzkikrcuda  Offline
North Dakota
My setup is a Mopar Chrome box, MSD Blaster 2 coil and Mopar .25 Ohm ballast. I have been running this combo for years on the street with no problems.
Re: Bypassing ballast ? [Re: Diplomat440] #1595660
03/24/14 01:21 AM
03/24/14 01:21 AM
australia
charger410 Offline
charger410  Offline
australia
The Main output Transistor on your ignition Box will only be rated at 4 amps continuous, so if you bypass the Ballast resistor you'll probably find you might exceed that all thought I've never checked it. A standard coil would be rated around the same current capacity
If you were going to bypass the Ballast put an amp gauge, it will have to be able to hold peak readings, on the 12 volt side of coil and that will give you an idea.
For a race car you should be able to get away with it but for the street you would be pushing it
