Re: dana 60 problem
[Re: 71blackdemon]
#1595553
03/20/14 01:44 AM
03/20/14 01:44 AM
Posts: 43,311 Bend,OR USA
Cab_Burge
Pull the cover now(drain it first if it has a drain plug ![](/ubbthreads/images/graemlins/scope.gif) ) and see if there are any loose pieces floating around in it ![](/ubbthreads/images/graemlins/Twocents.gif) Let us know what you find, is the roads you drive on straight or curved when it starts making the problem?
Re: dana 60 problem
[Re: 71blackdemon]
#1595554
03/20/14 02:09 AM
03/20/14 02:09 AM
RapidRobert
put the rear axle up on 2 stands & have a helper run it up in gear while you safely have a look underneath. first as said open the cover & see if anything looks wonky or any big debris & I'd have it on stands for that too both for easier access & so you can turn the wheels
Re: dana 60 problem
[Re: 451Mopar]
#1595556
03/21/14 12:19 AM
03/21/14 12:19 AM
Posts: 1,751 Graham, WA
Polarapete
Graham, WA
![](/ubbthreads/images/graemlins/iagree.gif) That is about the only weak point I can think of in an OEM Dana 60...the tapered wheel bearings that must be greased. I read the initial post and waited for someone to chime in with a theory that sounded plausible and now I have read it ![](/ubbthreads/images/graemlins/bow.gif) Cab's and RapidRobert's inspection procedures probably would have found it, too. ![](/ubbthreads/images/graemlins/bow.gif)
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction 1998 Ram 2500 QuadCab, new daily driver. 2008 Honda Element 2014 Carry-On 7x14 Cargo Trailer
