Re: dana 60 problem
[Re: 71blackdemon]
#1595553
03/20/14 01:44 AM
03/20/14 01:44 AM
Posts: 43,218 Bend,OR USA
Cab_Burge
Pull the cover now(drain it first if it has a drain plug ) and see if there are any loose pieces floating around in it Let us know what you find, is the roads you drive on straight or curved when it starts making the problem?
Re: dana 60 problem
[Re: 71blackdemon]
#1595554
03/20/14 02:09 AM
03/20/14 02:09 AM
RapidRobert
put the rear axle up on 2 stands & have a helper run it up in gear while you safely have a look underneath. first as said open the cover & see if anything looks wonky or any big debris & I'd have it on stands for that too both for easier access & so you can turn the wheels
Re: dana 60 problem
[Re: 451Mopar]
#1595556
03/21/14 12:19 AM
03/21/14 12:19 AM
Posts: 1,751 Graham, WA
Polarapete
Graham, WA
That is about the only weak point I can think of in an OEM Dana 60...the tapered wheel bearings that must be greased. I read the initial post and waited for someone to chime in with a theory that sounded plausible and now I have read it Cab's and RapidRobert's inspection procedures probably would have found it, too.
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction 1998 Ram 2500 QuadCab, new daily driver. 2008 Honda Element 2014 Carry-On 7x14 Cargo Trailer
