Mopar 225 #1595491
03/19/14 08:55 PM
03/19/14 08:55 PM
CA
David Lee Offline OP
CA
I know its crazy but I want to build a good 225 to go bracket racing. What is the best year block of these engines. I assume the engines that came in the eighties were thinner wall castings.
thanks
Ah...so many pedestrians, so little time...
Re: Mopar 225 [Re: David Lee] #1595492
03/20/14 12:06 AM
03/20/14 12:06 AM
Maryland
Dads426 Offline
Dads426  Offline
Maryland
I would start here: SlantSix.org
2012 422 Allstars NSS Champion
2013 422 Allstars NSS Champion
2014 422 Allstars NSS Champion
Re: Mopar 225 [Re: Dads426] #1595493
03/22/14 05:16 PM
03/22/14 05:16 PM
Missouri
slantracer Offline
slantracer  Offline
Missouri
Forged crank '75 and older, up the compression.
Build a mild 60-62 Valiant or Lancer and run 12:50's all day and not work on it.
Get more involved, run 10:90's and work on it all the time.
Be different, not just another too many cylinder race car!
Re: Mopar 225 [Re: slantracer] #1595494
03/22/14 06:30 PM
03/22/14 06:30 PM
Bowling Green, KY
cudaboy Offline
cudaboy  Offline
Bowling Green, KY
What would it take to get one to run 11.50's? There are a couple of tracks that run that index and i think that is what i am shooting for.
Dennis
Re: Mopar 225 [Re: cudaboy] #1595495
03/22/14 06:36 PM
03/22/14 06:36 PM
communist bloc of new jersey
jamesc Offline
jamesc  Offline
Dennis
imho first thing i would want is a flyweight car to put it in
i had a nice /6 in parts that i sold years ago and wish i had kept it. was adapting one of the old buick turbos to it.
Re: Mopar 225 [Re: cudaboy] #1595496
03/22/14 07:57 PM
03/22/14 07:57 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Dennis
A super light car first thing... I dont recall how
the old 4 bbl manifolds worked... but thats something
to think about(if you can find them now days)
Re: Mopar 225 [Re: MR_P_BODY] #1595497
03/23/14 02:43 AM
03/23/14 02:43 AM
Park Forest, IL
slantzilla Online content
slantzilla  Online Content
Park Forest, IL
11:50's on motor is a tough nut to crack, especially when conditions are hot or humid.
Forged or cast crank don't really matter, one is just about as good as the other. Good piston/rod combos are easier to find for a forged crank though.
As with most any motor headwork is the key. A Slant is tricky, because it is very easy to overport the head and all that does is creates reversion problems. It is also easy to put too big of valves in it, The small bore really shrouds a big intake valve.
Compression needs to stay around 11.5ish or it will eat head gaskets like crazy.
Cam is pretty critical too. Too much and it's a pig, too little and you leave a lot of power on the table.
Alcohol is almost a must too.
A rollerized 904 is almost a must for that fast unless you run a stick. A stick can be worth almost 1/2 second, but consistency may suffer and breakage will visit often.
As everyone has already said, you need a LIGHT car. 2000-2100 would be ideal, but hard to get to without a tube chassis car or a 61-62 Valiant/Lancer.
Finding little things that will get you a couple hundredths here and there will become a passion. Your weather station will be your best friend and worst enemy on the same day.
Plan B is build a fairly stock motor and turbo it. Consistency will suck, but it will be rocket fast and relatively trouble free when you get it dialed in.
If you're like most of us Slant racers you will follow plan A, and then wonder "Why in the hell did I ever do this when a smallblock would have been easier and cheaper?".
Re: Mopar 225 [Re: slantzilla] #1595498
03/23/14 10:43 AM
03/23/14 10:43 AM
Missouri
slantracer Offline
slantracer  Offline
Missouri
I don't think Slantzilla is right about most slant guys wished they had gone V8.
He thinks that because his stuff is not running!
It's fun not to take the easy way out.
We have broken one engine in 23 years of racing and they aren't any more expensive than any other engine to build. Just don't get stupid with your money.
Re: Mopar 225 [Re: slantzilla] #1595499
03/23/14 11:18 AM
03/23/14 11:18 AM
Bowling Green, KY
cudaboy Offline
cudaboy  Offline
Bowling Green, KY
Well, that's what I am looking for, so I guess I'm heading in the right direction. It also wouldn't have to be n/a, I could spray it a bit as long as it didn't hurt consistency.
It probably just another one of my pipe dreams though, who knows.
Dennis
Re: Mopar 225 [Re: slantzilla] #1595500
03/23/14 11:37 AM
03/23/14 11:37 AM
Bowling Green, KY
cudaboy Offline
cudaboy  Offline
Bowling Green, KY
I recently came across an old friend that I haven't seen or heard from in 21 years on FABO. That is what he did with his Valiant. I don't think his is a race only car though. I am looking forward to seeing it this spring.
Dennis
Re: Mopar 225 [Re: slantracer] #1595501
03/23/14 05:33 PM
03/23/14 05:33 PM
Park Forest, IL
Park Forest, IL
That's because I don't have deep pockets like you Southern boys.
You guys still have the Valiant? That would be a great car for this guy.
Re: Mopar 225 [Re: slantzilla] #1595502
03/24/14 03:58 PM
03/24/14 03:58 PM
dogdays Offline
dogdays  Offline
To the OP:
Your assumption that later slant six blocks would have thinner walls isn't correct. There seems to be no best year for blocks, if you are going to spend major bucks on a block I'd sonic check it first. And because Slants are bore-limited, I'd look for one that could be bored out more if your are going NA.
BUT, from my point of view, the easiest way to get a Slanty into the 11s is with a turbocharger. And that will work with stock displacement. Looking at the engine's layout, it seems made for a turbo, plenty of room for everything.
There is a lot of info on the Web, just start doing searches and you'll come up with plenty.
R.
Re: Mopar 225 [Re: dogdays] #1595503
03/26/14 08:34 PM
03/26/14 08:34 PM
Pangaea
B5 Bee Offline
B5 Bee  Offline
Pangaea
To the OP:
R.
Bore limited? How much? All blocks are bore limited.
Just about any slant block will go +.100. I know of one that went +.190 without hardblock.
Re: Mopar 225 [Re: B5 Bee] #1595504
03/27/14 04:41 AM
03/27/14 04:41 AM
Park Forest, IL
Park Forest, IL
To the OP:
R.
The +.190 block is still running. It's in a buddy's Dakota truck.
I have seen quite a few go +.135". Anything over +.100" should be sonic checked.
Re: Mopar 225 [Re: slantzilla] #1595505
03/27/14 01:37 PM
03/27/14 01:37 PM
dogdays Offline
dogdays  Offline
By bore limited I meant it has an awfully small bore. I didn't think that would be so hard to understand.
On most engines the bore is not the major area to gain cubic inches, the stroke is. So you add stroke.
On the 225 the stroke is already quite long, it had to be that way in order to make any cubic inches at all, because the bores are so small Kind of like the 5.4 ford modular engine.
In that case, it becomes much more important to be able to increase the bore by a lot to gain size. That's why I suggested sonic checking blocks to find one that could take a substantial overbore.
It's good to hear that cylinder walls are generally thick and a significant overbore is possible. Should make it easier to get more power out of a naturally aspirated engine.
The turbo, however, will cover a lack of displacement quite well.
R.
