'69 road runner front door emblem? #1595340
03/19/14 11:23 AM
03/19/14 11:23 AM
St. Louis
I
Imrare Offline OP
Imrare  Offline OP
I
St. Louis
I need to replace the "road runner" door emblem on my 1969 rr. However, the emblems on the car now have a "brushed" chrome (dull) look with a black background and the only new replacements I can find are gloss chrome with the black background. I am fairly certain the emblems on my rr are original, and I would like to keep the car as original as possible. Does anyone have any information on which type of emblem would be correct for a 1969 road runner?
Re: '69 road runner front door emblem? [Re: Imrare] #1595341
03/19/14 07:21 PM
03/19/14 07:21 PM
Omaha
road Offline
road  Offline
Omaha
Black is 1968. Colored began in 69.
Re: '69 road runner front door emblem? [Re: road] #1595342
03/19/14 07:27 PM
03/19/14 07:27 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Maybe you should read the OP's post again - slowly this time!
Re: '69 road runner front door emblem? [Re: Imrare] #1595343
03/19/14 07:28 PM
03/19/14 07:28 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
are you sure yours haven't just dulled over time what with washing, waxing and the sun? do you have a good pic of what yours look like now?
Re: '69 road runner front door emblem? [Re: Imrare] #1595344
03/20/14 03:01 PM
03/20/14 03:01 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
You are going to have to find good originals or see about getting your's restored , last time I paid attention to them the replacements were the later VOLARE RR stick on emblems .
Originals I'm pretty sure are brushed with the black background ...
Re: '69 road runner front door emblem? [Re: JohnRR] #1595345
03/20/14 03:24 PM
03/20/14 03:24 PM
Warrenton, VA
RoadRunnerJD Offline
Warrenton, VA
I pm'd the OP that I had some nice originals but did not receive any response.
Re: '69 road runner front door emblem? [Re: RoadRunnerJD] #1595346
03/20/14 04:15 PM
03/20/14 04:15 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
He's probably still reading thru thousands of PM's on his overheating problem
Re: '69 road runner front door emblem? [Re: Imrare] #1595347
03/20/14 10:56 PM
03/20/14 10:56 PM
NJ
70_FJ6_RR Offline
70_FJ6_RR  Offline
NJ
Then you need to restore your original emblems. I know the new road runner emblems in the Mopar plastic bags you will have to file the holes to get them to fit. They bend really easy too! And yes, they are brushed with black edges.
Re: '69 road runner front door emblem? [Re: JohnRR] #1595348
03/24/14 04:38 PM
03/24/14 04:38 PM
St. Louis
I
Imrare Offline OP
Imrare  Offline OP
I
St. Louis
JohnRR - why are you busting on me because of my overheating problem? You're right, I did receive close to 100 posts but I read them all quite expeditiously; that's all history now.
Re: '69 road runner front door emblem? [Re: 70_FJ6_RR] #1595349
03/24/14 04:49 PM
03/24/14 04:49 PM
St. Louis
I
Imrare Offline OP
Imrare  Offline OP
I
St. Louis
70FJ6 roadrunner,
Are you saying there are "brushed" emblems I can be bought but they need to be slightly modified, and they will look correct? If so, can you tell me where they can be purchased?
Re: '69 road runner front door emblem? [Re: Imrare] #1595350
03/24/14 05:26 PM
03/24/14 05:26 PM
Nashville, TN
MOPARMIKE69 Offline
MOPARMIKE69  Offline
Nashville, TN
70FJ6 roadrunner,
Any repop is not the same as the originals in several ways. Mostly Size, then finish and then pegs. The only way to really be correct with these is NOS or restored originals.
69 Road Runner vert
69 GTX hard top
70 Road Runner 4 speed
70 Hemi Cuda vert
Re: '69 road runner front door emblem? [Re: Imrare] #1595351
03/24/14 05:28 PM
03/24/14 05:28 PM
Nashville, TN
MOPARMIKE69 Offline
MOPARMIKE69  Offline
Nashville, TN
How did you finally fix the problem? Curious minds want to know.
69 Road Runner vert
69 GTX hard top
70 Hemi Cuda vert
Re: '69 road runner front door emblem? [Re: Imrare] #1595352
03/24/14 05:49 PM
03/24/14 05:49 PM
NJ
70_FJ6_RR Offline
70_FJ6_RR  Offline
NJ
70FJ6 roadrunner,
My fault, I should of specified that the originals are brushed. Reproductions are shiny. Any good chrome plater can do the brushed finish. It doesn't hurt to get some estimates on the origs rechromed. I recommend Advanced Plating in TN.
Re: '69 road runner front door emblem? [Re: MOPARMIKE69] #1595353
03/25/14 11:16 AM
03/25/14 11:16 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
what he said ...
Never did see the outcome of your latest fishing expedition on that potential problem.
I'm not busting on you , but I could if that would make you feel better?
Re: '69 road runner front door emblem? [Re: JohnRR] #1595354
03/25/14 12:52 PM
03/25/14 12:52 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
ere's my fear with these and I speak from experience. They are made of zinc diecast which is a very brittle material. If you try to bend it or bend it by accident (like while holding it to a buffer wheel !) it will snap in a heartbeat and repair is virtually impossible on an item that small.
The originals also have a very rough edge around the back which you need to retain for originality.
So if it were me ...
1) I would glass bead each piece myself to remove the black paint (or use paint stripper).
2) I would get a block of wood and drill holes to mount each piece in so that they can be held rigid to work on.
3) I would "sand" them to get the "brushed" finish I want
4) take them to a local plater and say "here, plate 'em - nickel & chrome only".
You'll have to explain why you're doing this. If they try to triple plate you'll lose the brushed finish after the first copper dip - which they always buff before the next step. What you want is just a nickel dip then the chrome and these will leave the "brushed" marks.
Redo the black yourself.
Re: '69 road runner front door emblem? [Re: MOPARMIKE69] #1595355
03/27/14 08:03 PM
03/27/14 08:03 PM
St. Louis
I
Imrare Offline OP
Imrare  Offline OP
I
St. Louis
Completely rebuilt the engine. Several different things were discovered during the rebuild that contributed to the overheating, things like, extremely lean carb setting, piston to wall clearance was very tight at one to one and a half thousandth, there was some debris in the bottom of the block, 2 cracks in the left side head, one bank of cylinders was bored slightly crooked when compared to the crank centerline, things like that, no one thing to point to so you can say "yea that was it", but a lot of little things that we feel contributed to the engine running hot. We ran the engine for 40 minutes on a test stand, with my radiator, and it didn't overheat, however, the conditions were not the same either. I won't be convinced the problem is fixed until I can run it (let it idle) on a 95 degree day and it doesn't overheat. I am in the process of reassembling the car now (I upgraded a few things since it was going to be down all winter)just waiting for decent weather to paint the engine (I will paint the engine outdoors) and drop it back in the car. I'll keep you advised.
Re: '69 road runner front door emblem? [Re: Imrare] #1595356
03/27/14 08:11 PM
03/27/14 08:11 PM
St. Louis
I
Imrare Offline OP
Imrare  Offline OP
I
St. Louis
This is what it looks like right now.
Re: '69 road runner front door emblem? [Re: Stanton] #1595357
03/27/14 08:22 PM
03/27/14 08:22 PM
St. Louis
I
Imrare Offline OP
Imrare  Offline OP
I
St. Louis
Thanks for the info Stanton. Based on this post here, someone contacted me and has provided me with an Original (1969) set of emblems. I haven't received them yet, and they are not NOS, but from the pics I saw, any deficiencies that would not be acceptable for a shown car, I believe I can fix with carful touch up. That's what keeps restoration interesting...
Thanks for the info Stanton. Based on this post here, someone contacted me and has provided me with an Original (1969) set of emblems. I haven't received them yet, and they are not NOS, but from the pics I saw, any deficiencies that would not be acceptable for a shown car, I believe I can fix with careful touch up. That's what keeps restoration interesting...
Re: '69 road runner front door emblem? [Re: Imrare] #1595358
03/28/14 12:10 PM
03/28/14 12:10 PM
N.E.Ohio
P
pacifica Offline
pacifica  Offline
P
N.E.Ohio
Hopefully your rebuilder increased the piston to cylinder wall clearance while you were in there?
