1965 426 street wedge original cam specs #1594719
03/18/14 02:53 AM
03/18/14 02:53 AM
USA
SSAAHemiFan Offline OP
USA
Anyone have the original cam specs for a 1965 426 street wedge ?
I have found a couple posted online but they didn't match each other
I am looking for something close in specs, It will be for a 100% restored engine - 4 speed with 3:91 gear
Considered running the MP Hemi cam but the intake ports and original carb are so small it may be overkill ?
Thank you
Re: 1965 426 street wedge original cam specs [Re: SSAAHemiFan] #1594720
03/18/14 04:05 AM
03/18/14 04:05 AM
Probally the same cam as in the 413 and maybe the 361 and 383 four barrel motors, maybe not.I do remember them idling real smooth, no rump or distinct idle at all
Re: 1965 426 street wedge original cam specs [Re: Cab_Burge] #1594721
03/18/14 11:31 AM
03/18/14 11:31 AM
usa
lewtot184 Offline
lewtot184  Offline
usa
268/268-.430 lift, 110lsa
Re: 1965 426 street wedge original cam specs [Re: lewtot184] #1594722
03/18/14 02:35 PM
03/18/14 02:35 PM
USA
USA
Thank you !
I would like to go a touch hotter but wanted to get a idea what came originally as a starting point.
Smallest cam I have ever run in a BB street car I've owned is the 509 so all these sound mild to me.
Looks like Lunati has alot of choices available
Re: 1965 426 street wedge original cam specs [Re: SSAAHemiFan] #1594723
03/18/14 02:53 PM
03/18/14 02:53 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
Thank you !
on a 100% restored 426 wedge i'd be very careful about big cams with those exhaust manifolds. the intake manifold doesn't flow much air, a very small 4bbl, '516 heads that don' flow very good. my choices would be a mopar 272-.455, stock magnum, comp cams 21-304-5, or a summit 6401. any of these cams will need a valve spring change, but any cam change will need new springs.
Re: 1965 426 street wedge original cam specs [Re: lewtot184] #1594724
03/18/14 02:59 PM
03/18/14 02:59 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
FWIW, I ran the old Street Hemi grind in my 64 413 with stock intake and exhaust manifolds. I did upgrade to 906 heads though. With the original 3.23 gears it was somewhat soft off the line, when I put in 4.10's it really woke the combo up. This was a stick car too.
Don't be the exception.
Re: 1965 426 street wedge original cam specs [Re: Supercuda] #1594725
03/18/14 09:28 PM
03/18/14 09:28 PM
USA
USA
Thanks - Yes the intake ports are pitifully small - I was looking at something around 275/.477/108 at the most
Thanks again
Re: 1965 426 street wedge original cam specs [Re: SSAAHemiFan] #1594726
03/18/14 11:01 PM
03/18/14 11:01 PM
dogdays Offline
dogdays  Offline
Two thoughts:
1. As wonderful as the Max Wedge motors were, the regular 426 found in street cars was just a midpoint between 413s and 440s. Nothing more. So the camshaft is probably nothing special either.
2. Contrary to opinion expressed above, if one has smaller ports, one crutches the smaller ports by using MORE camshaft duration. Case in point, the Buick nailhead exhaust port barely flows more than 100cfm, and the stock exhaust lobe on the 401s was something like 238* @ 50 lift.
R.
