Re: 1965 426 street wedge original cam specs
[Re: lewtot184]
#1594722
03/18/14 02:35 PM
03/18/14 02:35 PM
Posts: 2,431 USA
SSAAHemiFan
USA
Thank you ! I would like to go a touch hotter but wanted to get a idea what came originally as a starting point. Smallest cam I have ever run in a BB street car I've owned is the 509 so all these sound mild to me. Looks like Lunati has alot of choices available
[Re: SSAAHemiFan]
#1594723
03/18/14 02:53 PM
03/18/14 02:53 PM
Posts: 3,916 usa
lewtot184
usa
Thank you !
on a 100% restored 426 wedge i'd be very careful about big cams with those exhaust manifolds. the intake manifold doesn't flow much air, a very small 4bbl, '516 heads that don' flow very good. my choices would be a mopar 272-.455, stock magnum, comp cams 21-304-5, or a summit 6401. any of these cams will need a valve spring change, but any cam change will need new springs.
[Re: lewtot184]
#1594724
03/18/14 02:59 PM
03/18/14 02:59 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
FWIW, I ran the old Street Hemi grind in my 64 413 with stock intake and exhaust manifolds. I did upgrade to 906 heads though. With the original 3.23 gears it was somewhat soft off the line, when I put in 4.10's it really woke the combo up. This was a stick car too.
