440 Carb Recommendation #1594041
03/16/14 07:56 PM
03/16/14 07:56 PM
PA
RoadRunner73 Offline OP
PA
About to send my 440 to the machine shop to get worked over, nothing fancy just rebuilt. I'd like to get rid of the old thermoquad, any suggestion on a street carb, brand, model?
1973 Plymouth Road Runner
Re: 440 Carb Recommendation [Re: RoadRunner73] #1594042
03/16/14 08:02 PM
03/16/14 08:02 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
some of these,...
Re: 440 Carb Recommendation [Re: RoadRunner73] #1594043
03/16/14 08:37 PM
03/16/14 08:37 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
750 Holley 3310 vacuum secondary.
Works great on stock and mild 440's!
Re: 440 Carb Recommendation [Re: GY3] #1594044
03/16/14 08:40 PM
03/16/14 08:40 PM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
I'm a Holley guy, and on a fairly stock 440, I'd go with an Avenger series 770. I have had horrible luck with Eddy performer 750's, but heard that the 800 thunder series is a good piece.
Re: 440 Carb Recommendation [Re: lewtot184] #1594045
03/16/14 08:50 PM
03/16/14 08:50 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
some of these,...
i like how you think!
Re: 440 Carb Recommendation [Re: RoadRunner73] #1594046
03/16/14 09:24 PM
03/16/14 09:24 PM
Earth
Rob C Offline
Rob C  Offline
Earth
What will the 440 put out as far as HP?
What is your intended cam specs and gear ratio?
Older 440 cars came with small AFB carbs, (600 CFM) coupled with Hwy. gears. An old friends Imperial comes to mind. IIRC, it was a '67. Just talking out loud here. If your car is equipped with extra performance parts, that 3310 suggestion is a good idea.
Re: 440 Carb Recommendation [Re: Rob C] #1594047
03/16/14 09:32 PM
03/16/14 09:32 PM
mopar346 Offline
Let me tell ya about fat chicks!
mopar346  Offline
I would probably stick with the/a thermoquad, hard to bet in stock/mild applications. If set on a change I am hearing good things about the new Demon carbs, holley design, spreadbore compatible.
Careful, your character's showing!
Re: 440 Carb Recommendation [Re: mopar346] #1594048
03/16/14 09:36 PM
03/16/14 09:36 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
Holley 4175. Its a 650 CFM spreadbore. Direct bolt on to replace the T bogger. No adapter needed.
I am truckless..
Re: 440 Carb Recommendation [Re: RoadRunner73] #1594049
03/16/14 09:36 PM
03/16/14 09:36 PM
Georgia
Steve Bryant Offline
Georgia
So I have no strong preference at all, but I just rebuilt a 440 for my Cuda and we pulled 388 HP with a Edelbrock Performer 750 with Vacuum secondaries and an Electric choke. (Part 1411) So far, I like the carb quite a bit and you can get them used on Ebay for about $150.
My 440 is pretty tame. Bored .30 with 452 heads that were ported with valves cut back. Cam is .470 and the stock intake was replaced with a Edelbrock RPM Aluminum split-plane. Stock Exhaust manifolds. Overall, I was very impressed with the output.
Re: 440 Carb Recommendation [Re: Steve Bryant] #1594050
03/16/14 09:53 PM
03/16/14 09:53 PM
WI
Dcuda69 Offline
Dcuda69  Offline
WI
Hard to beat a 3310 on a street big block
Re: 440 Carb Recommendation [Re: Dcuda69] #1594051
03/16/14 09:58 PM
03/16/14 09:58 PM
Alberta Canada
PossessedDuster Offline
Alberta Canada
Playing the same game but with more cam, headders and edelbrock heads.
With the 3310 would you run the quickfuel metering blocks?
Also read good things about the street demon 750
Re: 440 Carb Recommendation [Re: lewtot184] #1594052
03/16/14 10:40 PM
03/16/14 10:40 PM
PA
PA
some of these,...
If I could afford those and they would have came on my 73 I'd be all for it!
Re: 440 Carb Recommendation [Re: lewtot184] #1594053
03/16/14 11:30 PM
03/16/14 11:30 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
some of these,...
thems great and I love mine, but if yo don't have a spare $2200, a godd old 750-850 Holley is the way to go.
Coming soon!!!!
Re: 440 Carb Recommendation [Re: RoadRunner73] #1594054
03/17/14 12:56 AM
03/17/14 12:56 AM
Chester, VA
tobnHisglory Offline
Chester, VA
If you are going for something that looks closer to a stock setup, a 750/850 holley with a short bowl conversion sitting on an earlier 70's square bore or m1 dual plane intake will fool a lot of people.
-Reggie
tobnHisglory2000@aol.com
Former Mopars: 73 Charger - 440/727, 68 D200 Camper Special 383/727, 67 Satellite, 71 Superbee, 73 RoadRunner,2009 Ram Quad Cab Hemi 4x4
Current Mopars: 2005 Ram Quad Cab Hemi 4x4, 73 Cuda FE5 318 manual
Re: 440 Carb Recommendation [Re: tobnHisglory] #1594055
03/17/14 01:42 AM
03/17/14 01:42 AM
Not2farfromNashville, TN
Rug_Trucker Offline
Rug_Trucker  Offline
Nothing wrong with a properly tuned TQ. Send it out to Scott Smith for a refurbish. Get the throttle bushed. Or stick it in a freezer style Ziplock if it is the original. That carb is an 850. All you'll ever need in a street car.
Or for a new square bore the Thunder 800 is easy to tune.
"The only thing to do for triumph of evil is for good men to do nothing"
"NUNQUAM NON PARATUS!"
Re: 440 Carb Recommendation [Re: Rug_Trucker] #1594056
03/17/14 12:31 PM
03/17/14 12:31 PM
Sweden
Mopar Guy Offline
Mopar Guy  Offline
Sweden
The six pack have ALOT of potencial on a 440 but expensive and if your building a stock 9,5 of lower compresion engine whit more or less stock cam i would surgest you stay whit a 750-800cfm 4 bbl carb on a dual plane intake to save your money but if you whant to do a street pounding engine and you have the money for the 3 nasty 2 bbl carbs and intake you will defenetly have some great moments whit them
Re: 440 Carb Recommendation [Re: Mopar Guy] #1594057
03/17/14 12:52 PM
03/17/14 12:52 PM
dogdays Offline
dogdays  Offline
Check out AndyF's AREngineering website for dyno articles. He made quite a bit of horsepower with the Edelbrock 800s.
As most high performance bigblocks came with Carter carbs, an Edelbrock 800 on a CH4b would look closer to stock than any Holley.
The 750 Street Demon will bolt on your stock TQ intake and should be a very good carb.
R.
Re: 440 Carb Recommendation [Re: dogdays] #1594058
03/17/14 02:18 PM
03/17/14 02:18 PM
Holland MI Ottawa
2
2boltmain Online content
2boltmain  Online Content
Holland MI Ottawa
Fish carburetor....Or is it Phish?
Keep old mopars alive.
Re: 440 Carb Recommendation [Re: 2boltmain] #1594059
03/18/14 09:24 AM
03/18/14 09:24 AM
Palmyra, NY
63stabamatic Offline
Palmyra, NY
I've been running the Eddy 1412 800 cfm for years, no problems. I would go with one of the newer AVS Eddy's now I think. The stock Carter AVS on the 69 GTX is a great carb.
Re: 440 Carb Recommendation [Re: 63stabamatic] #1594060
03/18/14 01:44 PM
03/18/14 01:44 PM
weymouth,mass.
meepmeep70 Offline
meepmeep70  Offline
weymouth,mass.
another for 6pak with a nice lid
