65 Altered Wheelbase Help #1593863
03/16/14 02:43 PM
03/16/14 02:43 PM
Arizona
410mopar Offline OP
410mopar  Offline OP
Arizona
Does anyone have access to an original 1965 Chrysler altered wheelbase factory car? I need some measurements.
1) At the aft end of the new front frame rails: What is the distance that the rails extend below the torsion bar cross member?
2) At the forward end of the new front frame rails: If a bar is placed across the bottom side of the rails from one side to the other, what is gap between the bar and the bottom of the lower radiator support?
3) At the aft end of the front frame rails there is a ½” bolt hole in the side of the rail about 2” from the end. What is the exact location of that bolt hole?
4) What is the distance from the bottom of the torsion bar cross member to the center line of the torsion bar.
410mopar
Re: 65 Altered Wheelbase Help [Re: 410mopar] #1593864
03/16/14 04:02 PM
03/16/14 04:02 PM
Cab_Burge Online work
Cab_Burge  Online Work
I beleive the altered wheelbase cars evolve from a little axle movement forward to more, several times
Re: 65 Altered Wheelbase Help [Re: Cab_Burge] #1593865
03/16/14 04:29 PM
03/16/14 04:29 PM
Phoenix, AZ
MoparBilly Offline
MoparBilly  Offline
Phoenix, AZ
Re: 65 Altered Wheelbase Help [Re: MoparBilly] #1593866
03/16/14 05:07 PM
03/16/14 05:07 PM
Arizona
410mopar Offline OP
410mopar  Offline OP
Arizona
I have gathered up most all the information there is out there, except for the original plans. Most recent altered wheelbase cars are not done like the factory cars. I'm trying to duplicate a factory car. As I was fitting up the new front rails some of my measurement didn't seem right, so I need the answers to my question before I begin welding.
Re: 65 Altered Wheelbase Help [Re: 410mopar] #1593867
03/16/14 06:48 PM
03/16/14 06:48 PM
Western Md.
skicker Offline
"The Champ"
skicker  Offline
"The Champ"
Western Md.
...FAFO...
Re: 65 Altered Wheelbase Help [Re: skicker] #1593868
03/16/14 09:13 PM
03/16/14 09:13 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
There is no set science,these cars were built with the plus/minus factor and tweaked to try to make things fit and work.Sometimes they did and sometime they didn't and some took a lot of refining to get them to go down the track.Find (if you can)two original (Amblewagon) units and you will see a lot of varaiations between them,similar to the Hurst Darts and Cudas.We are talking Chrysler and their contractors,these we hand assembled not done on a exacting scienced production line.Some of the originals were bodys proped on concrete blocks while the metamorphasising was being done.Some were half finished and fine tuned by Alexander Bros/Branister as well as the racers who recieved them.
Re: 65 Altered Wheelbase Help [Re: B G Racing] #1593869
03/16/14 11:39 PM
03/16/14 11:39 PM
geezer acres rest home
dakotawilly Offline
dakotawilly  Offline
I am not sure,but maybe big daddy has one in the museum,if not,id bet he knows of one somewhere.try e-mailing...marlene@garlits.com.......
SFI 25.5 depends,no leak,even at 213 mph....
Re: 65 Altered Wheelbase Help [Re: dakotawilly] #1593870
03/17/14 02:47 AM
03/17/14 02:47 AM
Graham, WA
P
Polarapete Offline
Polarapete  Offline
P
Graham, WA
Years ago there was a guy in Seattle that was building new versions of these altered wheelbase early B-bodies. I parked two cars side by side at our Spring Roundup in 2001. One was a clean old stocker and one was a AWB piece with a big block. I was just a guy on the parking crew then, I don't know if they drove or were trailerd in. I think the guy was named Rich Lefebre (sp?)and some time ago HOT ROD built an AWB Nova and raced one of Rich's creations. He may be still around, but I have not seen the car since.
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction
1998 Ram 2500 QuadCab, new daily driver.
2008 Honda Element
2014 Carry-On 7x14 Cargo Trailer
Re: 65 Altered Wheelbase Help [Re: Polarapete] #1593871
03/17/14 02:49 AM
03/17/14 02:49 AM
Graham, WA
P
Polarapete Offline
Polarapete  Offline
P
Graham, WA
And here is the next victim
2008 Honda Element
Re: 65 Altered Wheelbase Help [Re: Polarapete] #1593872
03/17/14 03:10 AM
03/17/14 03:10 AM
Graham, WA
P
Polarapete Offline
Polarapete  Offline
P
Graham, WA
I found a link to a lot of pictures and the cars that Rich was building back in 2001
http://1962to1965mopar.ornocar.com/lefebvre65.html
I was close on the last name... Lefebvre
2008 Honda Element
