Mounting Alum Kirkey Seats? #1593350
03/15/14 06:26 PM
03/15/14 06:26 PM
WI.
Scotts71chall Offline OP
WI.
How do you guys mount the Alum. Kirkey Pro Street seats to the stock floor pan?
Re: Mounting Alum Kirkey Seats? [Re: Scotts71chall] #1593351
03/15/14 07:08 PM
03/15/14 07:08 PM
San Diego CA
65 Hemi Offline
65 Hemi  Offline
San Diego CA
They make a bracket that mounts to the sides of the seat then the bracket flat mounts to the floor but you will need spacer because your floor is not flat. I bought 1" aluminum square stock from Home Depot and used as a spacer.
Doug
MOPAR or NO CAR!!!
1965 Dodge Coronet soon a 6.1 Hemi with a Magnson blower 810 hp on pump gas
1964 Dodge Polara 582" Indy alum Block 426-1RA heads,
1933 Plymouth PE all Steel, LT1 4L60E
1959 Plymouth Savoy 33,000 mile survivor
Old cars are never done. They are ongoing projects!
Re: Mounting Alum Kirkey Seats? [Re: Scotts71chall] #1593352
03/16/14 01:47 AM
03/16/14 01:47 AM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Off my roll cage.
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: Mounting Alum Kirkey Seats? [Re: 1967dartgt] #1593353
03/16/14 02:58 AM
03/16/14 02:58 AM
WI.
WI.
Any suggestions?
Re: Mounting Alum Kirkey Seats? [Re: Scotts71chall] #1593354
03/16/14 12:24 PM
03/16/14 12:24 PM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
I bought a set of the aluminum super stock A body mounts that we took an 1" or so height out of,we welded the bracket to the seat and use stock hole locations.
I had to be there of course to sit in the car so we knew where the brackets got welded to the seat and where i wanted it.
Re: Mounting Alum Kirkey Seats? [Re: Scotts71chall] #1593355
03/16/14 12:33 PM
03/16/14 12:33 PM
Janesville, WI
SpareParts Offline
SpareParts  Offline
Janesville, WI
I just did this last night. I bolted a couple metal strips down to the floor and some 1"x1" square tube to the seat and cut some pieces of the 1" to get the height I needed. Some cardboard was used also
Re: Mounting Alum Kirkey Seats? [Re: Scotts71chall] #1593356
03/16/14 12:33 PM
03/16/14 12:33 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
I bent some sheet metal to form a box with an offset in height to match the stock bracket and bolted the seat to it.
Re: Mounting Alum Kirkey Seats? [Re: Scotts71chall] #1593357
03/16/14 12:38 PM
03/16/14 12:38 PM
MR_P_BODY Offline
MR_P_BODY  Offline
If you put a back mount on it just make sure you give
it enough area and strength so you dont have a spear
sitting behind you
EDIT
I dont know if you want sliders or not but some squares
of steel for the floor so you spread the load are
needed
Re: Mounting Alum Kirkey Seats? [Re: Scotts71chall] #1593358
03/16/14 01:08 PM
03/16/14 01:08 PM
So. IL. USA
PLUM BAD Offline
PLUM BAD  Offline
So. IL. USA
Notched the square tube to fit over the subframe connecter.
Re: Mounting Alum Kirkey Seats? [Re: MR_P_BODY] #1593359
03/16/14 01:12 PM
03/16/14 01:12 PM
Motor City
6PKRTSE Online content
6PKRTSE  Online Content
Motor City
We made chromoly tubular mounts on my Challenger. And tied to the cage in the rear.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: Mounting Alum Kirkey Seats? [Re: 6PKRTSE] #1593360
03/16/14 01:18 PM
03/16/14 01:18 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I tied my seat mounts into the chassis also.. but I
dont have a stock floor pan... and I see some that just
mount the seat flat... tip that seat back so it supports
the back of your knees.. makes it much more comfortable
and your legs will thank you
Re: Mounting Alum Kirkey Seats? [Re: Scotts71chall] #1593361
03/16/14 01:19 PM
03/16/14 01:19 PM
off the grid
340B5 Offline
340B5  Offline
off the grid
I used 2 pieces of angle iron at each corner inverted w/each other and clamped together to get the height and recline set right, then welded them together. I used button head bolts through the seats so I wouldn't feel them.
Yeah, it's got a smallblock.
