Re: Mounting Alum Kirkey Seats?
[Re: Scotts71chall]
#1593351
03/15/14 07:08 PM
03/15/14 07:08 PM
Posts: 984 San Diego CA
65 Hemi
San Diego CA
They make a bracket that mounts to the sides of the seat then the bracket flat mounts to the floor but you will need spacer because your floor is not flat. I bought 1" aluminum square stock from Home Depot and used as a spacer.
Doug
MOPAR or NO CAR!!! 1965 Dodge Coronet soon a 6.1 Hemi with a Magnson blower 810 hp on pump gas 1964 Dodge Polara 582" Indy alum Block 426-1RA heads, 1933 Plymouth PE all Steel, LT1 4L60E 1959 Plymouth Savoy 33,000 mile survivor Old cars are never done. They are ongoing projects!
[Re: 1967dartgt]
#1593353
03/16/14 02:58 AM
03/16/14 02:58 AM
Posts: 554 WI.
Scotts71chall
WI.
Any suggestions?
[Re: Scotts71chall]
#1593357
03/16/14 12:38 PM
03/16/14 12:38 PM
Posts: 52,972 Romeo MI
MR_P_BODY
If you put a back mount on it just make sure you give it enough area and strength so you dont have a spear sitting behind you EDIT I dont know if you want sliders or not but some squares of steel for the floor so you spread the load are needed
[Re: MR_P_BODY]
#1593359
03/16/14 01:12 PM
03/16/14 01:12 PM
Posts: 4,566 Motor City
6PKRTSE
Motor City
We made chromoly tubular mounts on my Challenger. And tied to the cage in the rear.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: 6PKRTSE]
#1593360
03/16/14 01:18 PM
03/16/14 01:18 PM
MR_P_BODY
I tied my seat mounts into the chassis also.. but I dont have a stock floor pan... and I see some that just mount the seat flat... tip that seat back so it supports the back of your knees.. makes it much more comfortable and your legs will thank you
[Re: Scotts71chall]
#1593361
03/16/14 01:19 PM
03/16/14 01:19 PM
Posts: 1,532 off the grid
340B5
off the grid
I used 2 pieces of angle iron at each corner inverted w/each other and clamped together to get the height and recline set right, then welded them together. I used button head bolts through the seats so I wouldn't feel them.
Yeah, it's got a smallblock.
