gas tank sender wire ?? #1592661
03/14/14 12:35 AM
03/14/14 12:35 AM
scratchnfotraction Offline OP
ok need to know how the 85 sender works with 2 wires.
is 1 wire a ground since the tank is plastic and no clip on grounding strap from sender tube to metal fuel line.
on of the wires has a tracer down it the other does not.
could I take a test light and check them to see if it is a ground or a hot wire with key on?
the sender in the new tank is supposed to be correct ohms for the dodge gauge but only has the 1 stud/terminal.
thanks
Re: gas tank sender wire ?? [Re: scratchnfotraction] #1592662
03/14/14 01:02 AM
03/14/14 01:02 AM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
My 81 FSM shows 2 wires for the sending unit. A white wire for the ground and a light blue wire for the sending unit power.
I am truckless..
Re: gas tank sender wire ?? [Re: 340SHORTY] #1592663
03/14/14 11:41 AM
03/14/14 11:41 AM
looks like mine is a light blue with black tracer and a yellow wire.
testing with a test light and key on??? does that tell me the hot from ground?
Re: gas tank sender wire ?? [Re: scratchnfotraction] #1592664
03/14/14 12:15 PM
03/14/14 12:15 PM
Guitar Jones Offline
Yeah, it should. A DVOM would be better though.
'74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon!
Re: gas tank sender wire ?? [Re: Guitar Jones] #1592665
03/14/14 12:21 PM
03/14/14 12:21 PM
ND
dodgedon Offline
dodgedon  Offline
ND
No, I dont think it should... The yellow wire is a ground. It goes to the rear on left frame rail. The blue goes to the gauge. If you ground this wire the gauge would swing to full. The gauge gets its power from the back of the dash. 5 volts. The sender limits the amount of ground to move the needle.
67 Charger 383 auto
75 Dodge CNT 800 CAT Diesel
2012 Ram Crew cab 5.7 4x4
Re: gas tank sender wire ?? [Re: dodgedon] #1592666
03/14/14 04:07 PM
03/14/14 04:07 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
If you ground the blue wire with a test light, you should get a dim pulsating light from the test light, and the gauge should go to full. Gene
Re: gas tank sender wire ?? [Re: poorboy] #1592667
03/15/14 02:08 AM
03/15/14 02:08 AM
got it hooked up,blue with tracer was the sender wire, yellow was the ground.
gauge is working but does not seem to be corret. but close.
I did not ground the yellow wire, so I will go back and ground that to the tank/bolt just for good measures.
