gas tank sender wire ??
#1592661
03/14/14 12:35 AM
03/14/14 12:35 AM
Posts: 15,487 Florida
scratchnfotraction
ok need to know how the 85 sender works with 2 wires. is 1 wire a ground since the tank is plastic and no clip on grounding strap from sender tube to metal fuel line. on of the wires has a tracer down it the other does not. could I take a test light and check them to see if it is a ground or a hot wire with key on? the sender in the new tank is supposed to be correct ohms for the dodge gauge but only has the 1 stud/terminal. thanks
Re: gas tank sender wire ??
[Re: scratchnfotraction]
#1592662
03/14/14 01:02 AM
03/14/14 01:02 AM
Posts: 12,291 Kent, Wa
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
My 81 FSM shows 2 wires for the sending unit. A white wire for the ground and a light blue wire for the sending unit power.
I am truckless..
#1592664
03/14/14 12:15 PM
03/14/14 12:15 PM
Guitar Jones
looks like mine is a light blue with black tracer and a yellow wire.
testing with a test light and key on??? does that tell me the hot from ground?
Yeah, it should. A DVOM would be better though.
[Re: Guitar Jones]
#1592665
03/14/14 12:21 PM
03/14/14 12:21 PM
Posts: 516 ND
dodgedon
ND
No, I dont think it should... The yellow wire is a ground. It goes to the rear on left frame rail. The blue goes to the gauge. If you ground this wire the gauge would swing to full. The gauge gets its power from the back of the dash. 5 volts. The sender limits the amount of ground to move the needle.
67 Charger 383 auto 75 Dodge CNT 800 CAT Diesel 2012 Ram Crew cab 5.7 4x4
[Re: poorboy]
#1592667
03/15/14 02:08 AM
03/15/14 02:08 AM
scratchnfotraction
If you ground the blue wire with a test light, you should get a dim pulsating light from the test light, and the gauge should go to full. Gene
got it hooked up,blue with tracer was the sender wire, yellow was the ground.
gauge is working but does not seem to be corret. but close.
I did not ground the yellow wire, so I will go back and ground that to the tank/bolt just for good measures.
