Body filler Rage vs Bondo #1592519
03/13/14 06:16 PM
03/13/14 06:16 PM
Harrisburg Pa. 17112
moparmikethree Offline OP
I know in the past Bondo was not that good of a body filler but it was cheap. Has their quality gotten any better? I like using RAGE but i just paid $62.00 for a gallon. What does the numbers on the side of a Rage can indicate? 105 110 120 ?
Re: Body filler Rage vs Bondo [Re: moparmikethree] #1592520
03/13/14 06:45 PM
03/13/14 06:45 PM
Michigan Troll
blk00rt Offline
blk00rt  Offline
Michigan Troll
I know my local paint store their house brand is actually rage in a different can. It runs down the same line just a different packaging. The price is about 60% of rage too. You might want to see if your local supply house has a house brand and who makes it.
Rob Dunn
1976 Dart Sport 360
2000 dakota RT 408 with 150 nitrous
2013 Dodge Ram 1500 Hemi
2009 Jeep Patriot
Re: Body filler Rage vs Bondo [Re: blk00rt] #1592521
03/13/14 06:47 PM
03/13/14 06:47 PM
Bethel Ct
AdamR Offline
AdamR  Offline
Bethel Ct
Bondo is heavy. Avoid it.
Re: Body filler Rage vs Bondo [Re: moparmikethree] #1592522
03/13/14 06:56 PM
03/13/14 06:56 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
What is Rage? And do you know what it is based on? Bondo is polyester based, which shrinks, and crakes, and is heavy. I know of a filler that is not polyester based and weighs less than 4 lbs. a gallon, but is $$$$ Tell me about this Rage please.
Re: Body filler Rage vs Bondo [Re: moparmikethree] #1592523
03/13/14 07:25 PM
03/13/14 07:25 PM
Washington State
70Duster440 Offline
70Duster440  Offline
Washington State
I've got a buddy in the paint/body supply business. He sold my son a gallon of filler simply called "Gold" (Pro Line Performance Products) and was told it's the exact same product as Evercoat Rage Gold but at a much lower price than the Evercoat label. Just compared a can of each and the ingredients (and numbers) and packaged weight are identical.
The Evercoat fillers are "lighter" and easier to sand than Bondo. Primarily poly resin and styrene (+talc and other ingedients).
Re: Body filler Rage vs Bondo [Re: 70Duster440] #1592524
03/14/14 12:35 PM
03/14/14 12:35 PM
Chicago Burbs
sthemi Offline
sthemi  Offline
Chicago Burbs
on my current project , I was nearly complete but needed a couple of quarts to finish it..
Bought some Bondo at Advance... WOW what a Pain to finish out.
By the time I got it sanded down, the money I didn't spend for Rage was quickly replaced by money on Sandpaper, electricity for the air compressor, time spent sanding and then... it had tons of pinholes that took extra time and material to fix..
bottom line, spend the money...Rage Gold. Say NO to
Re: Body filler Rage vs Bondo [Re: sthemi] #1592525
03/14/14 03:16 PM
03/14/14 03:16 PM
Rust Belt, SW PA
Silver70 Offline
Silver70  Offline
Rust Belt, SW PA
I use Evercoat Lightweight filler, costs about 15 at the local carquest. I can't justify spending 50 plus when 90% of it ends up as dust on the floor.
68 Road Runner, 69 Belvedere, 71 Challenger Vert
340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z
66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
Re: Body filler Rage vs Bondo [Re: Silver70] #1592526
03/14/14 05:27 PM
03/14/14 05:27 PM
Tulsa, Oklahoma
Charger_440 Offline
Charger_440  Offline
Tulsa, Oklahoma
Every guy is going to have their go-to product...As far as non metallic fillers go, I like Rage Xtreme. it's easy to work with and to finish out. it covers easier than Bondo. you dont have to worry so much about the pin holes like you do with actual bondo. I feel that it is well worth the price for the time and frustration it saves.
In a conversation with a Wyoming State Patrolman... "A 318 ??!!! But I clocked you at 142 mph!!!"
Re: Body filler Rage vs Bondo [Re: Charger_440] #1592527
03/14/14 07:34 PM
03/14/14 07:34 PM
So. Illinois
bronze69 Offline
bronze69  Offline
So. Illinois
I have recently started using Evercoat's Quantum line of fillers, and absolutely love it. It uses temperature specific catalyst instead of the regular old hardener, and more of it. (2 tubes to a half gallon) It can easily be sanded with 120 grit paper, 80 grit makes it real easy. Evercoat Quantum Filler
Re: Body filler Rage vs Bondo [Re: bronze69] #1592528
03/14/14 07:55 PM
03/14/14 07:55 PM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
I use Rage & 3M Platinum
Re: Body filler Rage vs Bondo [Re: bronze69] #1592529
03/14/14 07:57 PM
03/14/14 07:57 PM
Lakewood, Colorado
herkamer Offline
herkamer  Offline
Lakewood, Colorado
Quantum is definitely the best filler I've ever used. Sands like butter and you don't need a glaze or finishing putty because it will finish out perfectly. It's also different because it's a hybrid epoxy/polyester filler, so it can go direct to metal. All the epoxy-prime-before-bodywork fanboys will disagree, but since it can there is no reason not to do it.
Matt
69 Dart Swinger 340
83 W350, Megasquirted with 46RH
Old news: 72 Demon street/race mobile
Latest: 70 Duster backhalf car
and even more
Re: Body filler Rage vs Bondo [Re: herkamer] #1592530
03/17/14 04:16 PM
03/17/14 04:16 PM
Does anyone know what the numbers on the side of the Rage can mean?
Like 105, 120, 125,
