Wiring Harness #1592406
03/13/14 04:37 PM
03/13/14 04:37 PM
Ohio
jimm69 Offline OP
jimm69  Offline OP
Ohio
I am replacing a 318 in a 69 B Body with a 440. Year one shows a different wiring harness for a 318 vs a 383/440. Anybody know the difference? If I wanted to purchase all new wiring harnesses for under the hood including the forward light harness, engine harness, and A/C harness, who gives the best deal? is there a packagage available instead of buying all 3 pieces individually? also, what do you call the plastic plugs on the inner fenders that the wiring harness snaps into? does anybody reproduce them?
Re: Wiring Harness [Re: jimm69] #1592407
03/13/14 07:27 PM
03/13/14 07:27 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
Year One has the best harness, or maybe Frank Baldason, they may be from the same vender. Don't buy from Evans though. Really, please don't say you don't know the difference between a 318, and 440.
Re: Wiring Harness [Re: jimm69] #1592408
03/15/14 01:18 AM
03/15/14 01:18 AM
Wausau,Wisconsin
Kilrbee Offline
Kilrbee  Offline
Wausau,Wisconsin
The difference in the engine harness is the location of the coil wire. the 318 is in the rear of the engine while the big block one is in the front of the engine.
Re: Wiring Harness [Re: Kilrbee] #1592409
03/17/14 10:38 AM
03/17/14 10:38 AM
Ohio
jimm69 Offline OP
jimm69  Offline OP
Ohio
Thanks to both of you for your responses. I think I am just going to bite the bullet and order new harnesses as mine are brittle anyway and would prefer to not put crummy looking wiring under a freshly restore engine compartment.
Re: Wiring Harness [Re: jimm69] #1592410
03/17/14 11:22 AM
03/17/14 11:22 AM
Ridgeland Wi
mopars_1 Offline
mopars_1  Offline
Ridgeland Wi
mega parts gets M&H harnesses also and usually get better prices than yearone...
megapartsusa.com
1971 Plymouth Duster 340 auto
1937 Plymouth PT50
1969 Dodge Dart Swinger 340 4 speed
2013 Ram laramie 2500 hemi
2008 Harley FLSTSB springer
Re: Wiring Harness [Re: mopars_1] #1592411
03/17/14 04:21 PM
03/17/14 04:21 PM
DELAWARE
bee71mopar Offline
bee71mopar  Offline
DELAWARE
Ive used evanswiring.com and havent had any issues and they are pretty reasonably priced..
