76 cordoba disc brakes ???? #1592328
03/13/14 12:35 PM
03/13/14 12:35 PM
cmansell Offline OP
cmansell  Offline OP
I found a cordoba about to be scrapped due to storm damage collapsed the roof and was offered the disc brake setup to use for my 69 gtx. Anyone use this setup or any reason to stay away from it? Thanks Chuck.
Re: 76 cordoba disc brakes ???? [Re: cmansell] #1592329
03/13/14 12:51 PM
03/13/14 12:51 PM
Chuck if that is the 11&3/4" slider setup I will buy the adapter (horseshoe) brackets and the rotors. Does that ans your Q
Re: 76 cordoba disc brakes ???? [Re: cmansell] #1592330
03/13/14 01:44 PM
03/13/14 01:44 PM
AndyF Offline
AndyF  Offline
You can bolt those disc brakes on. The hoses won't work but there are a couple different ways to solve that problem. Either match the factory setup on the Cordoba, or change the calipers to work with your car.
Re: 76 cordoba disc brakes ???? [Re: AndyF] #1592331
03/13/14 02:05 PM
03/13/14 02:05 PM
cmansell Offline OP
cmansell  Offline OP
Will I have the same sway bar problems with this set up?
Re: 76 cordoba disc brakes ???? [Re: cmansell] #1592332
03/13/14 06:06 PM
03/13/14 06:06 PM
AndyF Offline
AndyF  Offline
Hang the calipers to the rear and use custom hoses.
This question has been asked and answered several hundred times on this board over the years so there are lots of pictures and posts to look at. I also covered the subject in my B-body book. (The B-body book also answers about 100 other popular questions from this forum.)
Re: 76 cordoba disc brakes ???? [Re: AndyF] #1592333
03/13/14 11:29 PM
03/13/14 11:29 PM
Marlboro, NY, USA
Rick_Ehrenberg Offline
Marlboro, NY, USA
Be sure to move the frame hardline bracket (tab) to the front, insuring that the flex hose crosses the steering axis.
Andy's book is great, also see the grandaddy...
Disc-O-tech
Rick
Re: 76 cordoba disc brakes ???? [Re: Rick_Ehrenberg] #1592334
03/15/14 11:55 AM
03/15/14 11:55 AM
Rome, Ga
sbhpcb Offline
sbhpcb  Offline
Rome, Ga
I used 78 cordoba spindles and caliper brackets on my 71 cuda. I hung the brackets to the rear and I used the rear of the steering axis Hose Perchs. Cass at Doctor Diff Told me about using 82 Dodge Diplomat calipers and 69 Camaro rubber hoses.
