questions on putting my 70 road runner on a rotisserie #1592259
03/12/14 11:50 PM
03/12/14 11:50 PM
south central nebraska
GI Moparman Offline OP
I'm stripping my 70 v code runner this weekend and I pretty much understand how to mount it. My question is about is there anything that I need to do as far as stiffening the body when the quarters, floor pan and trunk pan are removed while its on the rotisserie. It is going to the media blasters and figured I might as well remove all the metal that will be getting replaced before it goes. If there is anything I need to do, pics would sure help!!!!! Thanks guys!!!!!!
Re: questions on putting my 70 road runner on a rotisserie [Re: GI Moparman] #1592260
03/13/14 12:01 PM
03/13/14 12:01 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
No, no, no. Do not change large sheet metal panels while the vehicle is on the Rotisserie.
Especially quarter panels.
Master, again and still
Re: questions on putting my 70 road runner on a rotisserie [Re: DaveRS23] #1592261
03/13/14 12:16 PM
03/13/14 12:16 PM
British Columbia
chrisf Offline
chrisf  Offline
British Columbia
I agree. I know of a demon that had quarters and a bunch of sheetmetal work done while on a rotisserie. nothing fits and it needs to be cut back apart now.
Re: questions on putting my 70 road runner on a rotisserie [Re: DaveRS23] #1592262
03/13/14 12:18 PM
03/13/14 12:18 PM
Western New York
sixpackbee Offline
sixpackbee  Offline
Western New York
If you want the panels off for the blaster make youself a dolly to transport the shell to the blasters. When you get it home put it on a stable platform and replace your panels. After that go to the rotisserie for under side owrk ect. When doen with that return to the floor for bolt on panel alignment. The bodies actually flex quite a bit when suspended on a rotisserie.
1959 Bugeye Sprite
1967 Charger Black L code
1967 Coronet R/T Convert Green 440 auto bought from original owner
1968 Charger R/T Bronze 440 4 spd console AM/FM
1969 Super Bee WM21H B5 A40 D21 N96
1969 Barracuda Formula S 340 Convert pilot car
1969 Hemi Road Runner RM23J D32 Omaha orange 4.10 Dana N96 N85
1970 Super Bee WM23N FE5 V1X 3.91 axle package, N96
1970 Road Runner RM21N B3 V1X D13
1971 MG Midget
1971 Road Runner RM23H GW3, A57
1972 Road Runner RM23P FY1, D21
Re: questions on putting my 70 road runner on a rotisserie [Re: sixpackbee] #1592263
03/13/14 12:38 PM
03/13/14 12:38 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
A rotisserie is not for doing complete sheetmetal replacement, it is more suited to minor lower repairs, painting and assembly and detail work.
Re: questions on putting my 70 road runner on a rotisserie [Re: GI Moparman] #1592264
03/13/14 01:29 PM
03/13/14 01:29 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
NO, don't do that. Like said above do the sheet metal work on a platform. Those holes in the frame rails are there for a reason, build something and locate to the holes, and rails, and square it up. Also when you do put it on the rotisserie when not working on it or during transport turn the body on its side to take the stress off of it.
Re: questions on putting my 70 road runner on a rotisserie [Re: 71birdJ68] #1592265
03/13/14 03:04 PM
03/13/14 03:04 PM
Southeast Virginia
68jim Offline
68jim  Offline
Southeast Virginia
I agree with the comments above regarding the large panel replacement while the body is mounted on a rotisserie. Idealy the rotisserie is meant for short term use and is an awesome tool during a restoration. However, sometimes life will get in the way of those short term plans and as in my case it ended up being almost 6 years before taking it off the rig. I was worried about long term issues even with everything out of the car making it as light as I could. I made a center brace for my car - 68 Road Runner - and every time I finished for the day I would put the car back level and set up the brace. It was just some scrap steel and a scissor jack I found in a junkyard. I would set it up in the middle of the car and run the jack up to the body and give it an extra turn to take some stress off the ends. I wasn't sure if I really needed it but it gave me peace of mind and we had no issues putting the body back together. My car had been mini-tubbed long time ago and when I fixed those areas I just did one side at a time. The rest of the body did not require big panel replacement.
Even with this style center brace I would not attempt quarter panel replacement on a rotiserie.
Good luck with your project.
Re: questions on putting my 70 road runner on a rotisserie [Re: GI Moparman] #1592266
03/13/14 03:09 PM
03/13/14 03:09 PM
Rust Belt, SW PA
Silver70 Offline
Silver70  Offline
Rust Belt, SW PA
I lower my rotisserie so the car is supported on jack stands when I do quarters and other larger panels. I wouldn't be transporting it either on just a rotisserie after panels are removed.
68 Road Runner, 69 Belvedere, 71 Challenger Vert
340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z
66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
Re: questions on putting my 70 road runner on a rotisserie [Re: Silver70] #1592267
03/13/14 11:09 PM
03/13/14 11:09 PM
Shelby, Ohio
2
2abodymcodes Offline
Shelby, Ohio
i agree, don't replace any major metal while on the rotisserie. here is a picture of a jig i made to set my roadrunner on while i replaced frame rails, floor, quarters, ect..
Re: questions on putting my 70 road runner on a rotisserie [Re: 2abodymcodes] #1592268
03/13/14 11:11 PM
03/13/14 11:11 PM
Shelby, Ohio
2
Shelby, Ohio
i welded pins on the jig that fit up into the frame holes. when i replaced the frame rails they fell onto the pins and were lined up exact. the whole car went together nice and everything lined up.
Re: questions on putting my 70 road runner on a rotisserie [Re: 2abodymcodes] #1592269
03/14/14 12:39 AM
03/14/14 12:39 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
So at what stage was that car blasted?
Re: questions on putting my 70 road runner on a rotisserie [Re: 2abodymcodes] #1592270
03/14/14 12:46 AM
03/14/14 12:46 AM
Thanks guys, I apriciate all the input! I won't put quarters and floors in on the rotiserie! I was planning on setting it up on jack stands n leveling it all out befor welding in any panels. I will make supports for when I transport it so it can be on the rotiserie at the blasters. Want any and all rust/paint removed top and bottom.
Re: questions on putting my 70 road runner on a rotisserie [Re: GI Moparman] #1592271
03/14/14 02:09 PM
03/14/14 02:09 PM
Sacramento, Ca
Darius Offline
Darius  Offline
Sacramento, Ca
Just have the blaster hit the seams where you will be looking for spot welds on the panels you will be replacing. One benefit of this way is you get most of the sand out when you remove the panel plus it stays rigid for the transport
Driving modern convenience in classic beauty
Re: questions on putting my 70 road runner on a rotisserie [Re: Darius] #1592272
03/15/14 12:32 AM
03/15/14 12:32 AM
If I leave quarters and trunk floor on the body, won't be able to get to all the areas when blasting. Thinking about using rotiserie to stip undercoating off bottom of car but put back on to dollies bolted where fromt spring hanger is and to bumper area before transport.
Re: questions on putting my 70 road runner on a rotisserie [Re: GI Moparman] #1592273
03/15/14 02:26 AM
03/15/14 02:26 AM
Tracy, New Brunswick, Canada
magnumcharger Offline
I have had my Charger on a rotisserie for several years with no ill effects. However, when it came time to replace the quarter panels and rockers, I determined that the only way to sustain the original dimensions of the car was to properly support it, and use the actual factory diagram for measurements. I built this rolling body jig, which is similar in style to the ones at the AMD restoration shop. Each of the vertical posts supports the body at key locations, relative to the factory drawing.
